Frontend unresponsive after hitting Delete button in UI
Hi all,
I have an instance of HAOS running in Proxmox as VM. Some time ago (I would say several month, it’s really hard to say when because I regulary update HA and did not use this feature often) I started to experience “Connection lost. Reconnecting…” on the frontend.
Only recently I have tracked down when it happens and I’m able to reproduce this 100% of the time - when I try to delete something e.g. automation, integration, scene - when you use the 3 dot icon and select the red delete action. The action is performed as it can be seen in the frontend (item disappears from the list) but then when you try to navigate somewhere else (or after 10-30 seconds without any action at all) you get “Connection lost. Reconnecting…”
It recovers from this issue itself after several minutes and you can do anything you want until you hit the Delete button and the issue happens again.
I can do whatever I want - open new browser window - no luck, try other browser - no luck, restart the VM - no luck… but the HA itself is running and is responsive, ping to HAOS works, automations work, SMB share is accessible etc.
Now the strangest part (at least to me). When you open the frontend (browser or companion app) on another computer, tablet, mobile whatever it works - until you hit the Delete button on that device, then the issue appears on that device as well and again it recovers itself after few minutes.
I have set the log level to debug but I can’t see anything wrong (attached below, at time 11:12:19.098 the delete action is requested). I have tried different devices (computer, tablet, mobile) different OSes (windows, ios), different browsers (Firefox, Chrome, Edge) still the same. I have set up new VM with fresh install of HAOS and it happens there as well, without any modification and add-on installation - just create automation on clean installation, save it, hit delete and it is there - connection lost.
Would anyone have any suggestion?
2024-10-14 11:12:13.481 DEBUG (MainThread) [homeassistant.components.zeroconf] service_update: type=_airplay._tcp.local. name=lukas-macbook._airplay._tcp.local. state_change=ServiceStateChange.Removed
2024-10-14 11:12:13.481 DEBUG (MainThread) [homeassistant.components.zeroconf] service_update: type=_raop._tcp.local. name=76C85AF3B011@lukas-macbook._raop._tcp.local. state_change=ServiceStateChange.Removed
2024-10-14 11:12:14.608 DEBUG (MainThread) [homeassistant.components.websocket_api.http.connection] [140239031681232] lukas from 172.27.110.251 (Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:131.0) Gecko/20100101 Firefox/131.0): Received {'type': 'ping', 'id': 89}
2024-10-14 11:12:14.608 DEBUG (MainThread) [homeassistant.components.websocket_api.http.connection] [140239031681232] lukas from 172.27.110.251 (Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:131.0) Gecko/20100101 Firefox/131.0): Sending b'{"id":89,"type":"pong"}'
2024-10-14 11:12:14.641 DEBUG (MainThread) [async_upnp_client.traffic.ssdp] Received packet from ('172.27.5.70', 47738): b'M-SEARCH * HTTP/1.1\r\nHOST: 239.255.255.250:1900\r\nMAN: "ssdp:discover"\r\nST: upnp:rootdevice\r\nMX: 5\r\n\r\n'
2024-10-14 11:12:14.641 DEBUG (MainThread) [async_upnp_client.server] Received M-SEARCH from: ('172.27.5.70', 47738), headers: {'HOST': '239.255.255.250:1900', 'MAN': '"ssdp:discover"', 'ST': 'upnp:rootdevice', 'MX': '5', '_host': '172.27.5.70', '_timestamp': datetime.datetime(2024, 10, 14, 11, 12, 14, 641866), '_remote_addr': ('172.27.5.70', 47738), '_port': 47738, '_local_addr': ('0.0.0.0', 1900)}
2024-10-14 11:12:14.641 DEBUG (MainThread) [async_upnp_client.server] Deferring response for 5 seconds
2024-10-14 11:12:14.642 DEBUG (MainThread) [async_upnp_client.server] Sending SSDP packet, transport: None, socket: <socket.socket fd=58, family=2, type=2, proto=0, laddr=('0.0.0.0', 60152)>, target: ('172.27.5.70', 47738)
2024-10-14 11:12:14.642 DEBUG (MainThread) [async_upnp_client.traffic.ssdp] Sending SSDP packets, target: ('172.27.5.70', 47738), data: [b'HTTP/1.1 200 OK\r\nCACHE-CONTROL:max-age=1800\r\nDATE:Mon, 14 Oct 2024 09:12:14 GMT\r\nSERVER:async-upnp-client/0.40.0 UPnP/2.0 Server/1.0\r\nST:upnp:rootdevice\r\nUSN:UUID:9928D21D-19B6-4F9A-B342-FA2EC1FF253E::upnp:rootdevice\r\nEXT:\r\nLOCATION:http://172.27.5.241:40000/device.xml\r\nBOOTID.UPNP.ORG:1728895960\r\nCONFIGID.UPNP.ORG:1\r\n\r\n']
2024-10-14 11:12:14.663 DEBUG (MainThread) [homeassistant.helpers.http] Serving /api/hassio_ingress/6LXUND5TVXxicvF08eO0fAGHSuQ1nA0Ut9YmKnJ5sw8/stable-3542bd157b0ccc8bf732acdb03d4d69d85f48ea9 to 172.27.110.251 (auth: False)
2024-10-14 11:12:17.729 DEBUG (MainThread) [homeassistant.helpers.http] Serving /api/hassio_ingress/6LXUND5TVXxicvF08eO0fAGHSuQ1nA0Ut9YmKnJ5sw8/stable-3542bd157b0ccc8bf732acdb03d4d69d85f48ea9 to 172.27.110.251 (auth: False)
2024-10-14 11:12:18.205 DEBUG (MainThread) [async_upnp_client.server] Sending SSDP packet, transport: None, socket: <socket.socket fd=58, family=2, type=2, proto=0, laddr=('0.0.0.0', 60152)>, target: ('172.27.5.70', 47738)
2024-10-14 11:12:18.205 DEBUG (MainThread) [async_upnp_client.traffic.ssdp] Sending SSDP packets, target: ('172.27.5.70', 47738), data: [b'HTTP/1.1 200 OK\r\nCACHE-CONTROL:max-age=1800\r\nDATE:Mon, 14 Oct 2024 09:12:14 GMT\r\nSERVER:async-upnp-client/0.40.0 UPnP/2.0 Server/1.0\r\nST:upnp:rootdevice\r\nUSN:UUID:9928D21D-19B6-4F9A-B342-FA2EC1FF253E::upnp:rootdevice\r\nEXT:\r\nLOCATION:http://172.27.5.241:40000/device.xml\r\nBOOTID.UPNP.ORG:1728895960\r\nCONFIGID.UPNP.ORG:1\r\n\r\n']
2024-10-14 11:12:19.086 DEBUG (MainThread) [homeassistant.components.http.auth] Authenticated 172.27.110.251 for /api/config/automation/config/1728897110826 using bearer token
2024-10-14 11:12:19.086 DEBUG (MainThread) [homeassistant.helpers.http] Serving /api/config/automation/config/1728897110826 to 172.27.110.251 (auth: True)
2024-10-14 11:12:19.098 DEBUG (MainThread) [homeassistant.core] Bus:Handling <Event entity_registry_updated[L]: action=remove, entity_id=automation.tst2>
2024-10-14 11:12:19.099 DEBUG (MainThread) [homeassistant.core] Bus:Handling <Event state_changed[L]: entity_id=automation.tst2, old_state=<state automation.tst2=on; id=1728897110826, last_triggered=None, mode=single, current=0, friendly_name=TST2 @ 2024-10-14T11:11:53.831000+02:00>, new_state=None>
2024-10-14 11:12:19.099 DEBUG (Recorder) [homeassistant.components.recorder.core] Processing task: <Event state_changed[L]: entity_id=automation.tst2, old_state=<state automation.tst2=on; id=1728897110826, last_triggered=None, mode=single, current=0, friendly_name=TST2 @ 2024-10-14T11:11:53.831000+02:00>, new_state=None>
2024-10-14 11:12:19.099 DEBUG (Recorder) [homeassistant.components.recorder.core] Processing task: <Event entity_registry_updated[L]: action=remove, entity_id=automation.tst2>
2024-10-14 11:12:19.100 DEBUG (Recorder) [homeassistant.components.recorder.pool.RecorderPool] Connection <sqlite3.Connection object at 0x7f8c0e07c6d0> checked out from pool
2024-10-14 11:12:19.100 DEBUG (MainThread) [homeassistant.components.websocket_api.http.connection] [140239031681232] lukas from 172.27.110.251 (Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:131.0) Gecko/20100101 Firefox/131.0): Sending b'[{"type":"event","event":{"r":["automation.tst2"]},"id":3},{"type":"event","event":{"event_type":"entity_registry_updated","data":{"action":"remove","entity_id":"automation.tst2"},"origin":"LOCAL","time_fired":"2024-10-14T09:12:19.098989+00:00","context":{"id":"01JA54SGCTH2TVCEGRWZEHD52Y","parent_id":null,"user_id":null}},"id":4}]'
2024-10-14 11:12:19.101 DEBUG (MainThread) [homeassistant.components.websocket_api.http.connection] [140237825187776] lukas from 172.27.110.251 (Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:131.0) Gecko/20100101 Firefox/131.0): Sending b'[{"type":"event","event":{"r":["automation.tst2"]},"id":19},{"type":"event","event":{"event_type":"entity_registry_updated","data":{"action":"remove","entity_id":"automation.tst2"},"origin":"LOCAL","time_fired":"2024-10-14T09:12:19.098989+00:00","context":{"id":"01JA54SGCTH2TVCEGRWZEHD52Y","parent_id":null,"user_id":null}},"id":20},{"type":"event","event":{"event_type":"entity_registry_updated","data":{"action":"remove","entity_id":"automation.tst2"},"origin":"LOCAL","time_fired":"2024-10-14T09:12:19.098989+00:00","context":{"id":"01JA54SGCTH2TVCEGRWZEHD52Y","parent_id":null,"user_id":null}},"id":38}]'
2024-10-14 11:12:19.105 DEBUG (MainThread) [homeassistant.components.websocket_api.http.connection] [140239031681232] lukas from 172.27.110.251 (Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:131.0) Gecko/20100101 Firefox/131.0): Received {'type': 'config/entity_registry/list_for_display', 'id': 90}
2024-10-14 11:12:19.105 DEBUG (MainThread) [homeassistant.components.websocket_api.http.connection] [140239031681232] lukas from 172.27.110.251 (Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:131.0) Gecko/20100101 Firefox/131.0): Sending b'{"id":90,"type":"result","success":true,"result":{"entity_categories":{"0":"config","1":"diagnostic"},"entities":[{"ei":"sensor.sun_next_dawn","pl":"sun","lb":[],"di":"4d0f0fb89a1b0b1d3fe9dfe652098e65","tk":"next_dawn","ec":1,"hn":true,"en":"Next dawn"},{"ei":"sensor.sun_next_dusk","pl":"sun","lb":[],"di":"4d0f0fb89a1b0b1d3fe9dfe652098e65","tk":"next_dusk","ec":1,"hn":true,"en":"Next dusk"},{"ei":"sensor.sun_next_midnight","pl":"sun","lb":[],"di":"4d0f0fb89a1b0b1d3fe9dfe652098e65","tk":"next_midnight","ec":1,"hn":true,"en":"Next midnight"},{"ei":"sensor.sun_next_noon","pl":"sun","lb":[],"di":"4d0f0fb89a1b0b1d3fe9dfe652098e65","tk":"next_noon","ec":1,"hn":true,"en":"Next noon"},{"ei":"sensor.sun_next_rising","pl":"sun","lb":[],"di":"4d0f0fb89a1b0b1d3fe9dfe652098e65","tk":"next_rising","ec":1,"hn":true,"en":"Next rising"},{"ei":"sensor.sun_next_setting","pl":"sun","lb":[],"di":"4d0f0fb89a1b0b1d3fe9dfe652098e65","tk":"next_setting","ec":1,"hn":true,"en":"Next setting"},{"ei":"update.home_assistant_supervisor_update","pl":"hassio","lb":[],"di":"d9794fcc73a5f10ee22b75a9b88e7b5e","ec":0,"hn":true,"en":"Update"},{"ei":"update.home_assistant_core_update","pl":"hassio","lb":[],"di":"1612b8e28925b053fb8b18a25e892e4f","ec":0,"hn":true,"en":"Update"},{"ei":"update.home_assistant_operating_system_update","pl":"hassio","lb":[],"di":"b09b8c33e232a3fb586cf924fb1e41dd","ec":0,"hn":true,"en":"Update"},{"ei":"person.lukas","pl":"person","lb":[],"en":"lukas"},{"ei":"todo.shopping_list","pl":"shopping_list","lb":[],"tk":"shopping_list","hn":true,"en":"Shopping List"},{"ei":"tts.google_translate_en_com","pl":"google_translate","lb":[],"en":"Google Translate en com"},{"ei":"update.matter_server_update","pl":"hassio","lb":[],"di":"742c44bea051ef497667f2bf9d18ed56","ec":0,"hn":true,"en":"Update"},{"ei":"update.file_editor_update","pl":"hassio","lb":[],"di":"b674e53bc73632893dedd31ac987800a","ec":0,"hn":true,"en":"Update"},{"ei":"update.studio_code_server_update","pl":"hassio","lb":[],"di":"f40ed35d1ef1781fff5cc5a5fea03dc5","ec":0,"hn":true,"en":"Update"},{"ei":"todo.tst","pl":"local_todo","lb":[],"hn":true,"en":"Tst"},{"ei":"todo.tst2","pl":"local_todo","lb":[],"ic":"mdi:list-status","hn":true,"en":"Tst2"},{"ei":"automation.tst","pl":"automation","lb":[],"en":"TST"}]}}'
2024-10-14 11:12:19.105 DEBUG (MainThread) [homeassistant.components.websocket_api.http.connection] [140237825187776] lukas from 172.27.110.251 (Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:131.0) Gecko/20100101 Firefox/131.0): Received {'type': 'config/entity_registry/list_for_display', 'id': 69}
2024-10-14 11:12:19.106 DEBUG (MainThread) [homeassistant.components.websocket_api.http.connection] [140237825187776] lukas from 172.27.110.251 (Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:131.0) Gecko/20100101 Firefox/131.0): Sending b'{"id":69,"type":"result","success":true,"result":{"entity_categories":{"0":"config","1":"diagnostic"},"entities":[{"ei":"sensor.sun_next_dawn","pl":"sun","lb":[],"di":"4d0f0fb89a1b0b1d3fe9dfe652098e65","tk":"next_dawn","ec":1,"hn":true,"en":"Next dawn"},{"ei":"sensor.sun_next_dusk","pl":"sun","lb":[],"di":"4d0f0fb89a1b0b1d3fe9dfe652098e65","tk":"next_dusk","ec":1,"hn":true,"en":"Next dusk"},{"ei":"sensor.sun_next_midnight","pl":"sun","lb":[],"di":"4d0f0fb89a1b0b1d3fe9dfe652098e65","tk":"next_midnight","ec":1,"hn":true,"en":"Next midnight"},{"ei":"sensor.sun_next_noon","pl":"sun","lb":[],"di":"4d0f0fb89a1b0b1d3fe9dfe652098e65","tk":"next_noon","ec":1,"hn":true,"en":"Next noon"},{"ei":"sensor.sun_next_rising","pl":"sun","lb":[],"di":"4d0f0fb89a1b0b1d3fe9dfe652098e65","tk":"next_rising","ec":1,"hn":true,"en":"Next rising"},{"ei":"sensor.sun_next_setting","pl":"sun","lb":[],"di":"4d0f0fb89a1b0b1d3fe9dfe652098e65","tk":"next_setting","ec":1,"hn":true,"en":"Next setting"},{"ei":"update.home_assistant_supervisor_update","pl":"hassio","lb":[],"di":"d9794fcc73a5f10ee22b75a9b88e7b5e","ec":0,"hn":true,"en":"Update"},{"ei":"update.home_assistant_core_update","pl":"hassio","lb":[],"di":"1612b8e28925b053fb8b18a25e892e4f","ec":0,"hn":true,"en":"Update"},{"ei":"update.home_assistant_operating_system_update","pl":"hassio","lb":[],"di":"b09b8c33e232a3fb586cf924fb1e41dd","ec":0,"hn":true,"en":"Update"},{"ei":"person.lukas","pl":"person","lb":[],"en":"lukas"},{"ei":"todo.shopping_list","pl":"shopping_list","lb":[],"tk":"shopping_list","hn":true,"en":"Shopping List"},{"ei":"tts.google_translate_en_com","pl":"google_translate","lb":[],"en":"Google Translate en com"},{"ei":"update.matter_server_update","pl":"hassio","lb":[],"di":"742c44bea051ef497667f2bf9d18ed56","ec":0,"hn":true,"en":"Update"},{"ei":"update.file_editor_update","pl":"hassio","lb":[],"di":"b674e53bc73632893dedd31ac987800a","ec":0,"hn":true,"en":"Update"},{"ei":"update.studio_code_server_update","pl":"hassio","lb":[],"di":"f40ed35d1ef1781fff5cc5a5fea03dc5","ec":0,"hn":true,"en":"Update"},{"ei":"todo.tst","pl":"local_todo","lb":[],"hn":true,"en":"Tst"},{"ei":"todo.tst2","pl":"local_todo","lb":[],"ic":"mdi:list-status","hn":true,"en":"Tst2"},{"ei":"automation.tst","pl":"automation","lb":[],"en":"TST"}]}}'
2024-10-14 11:12:19.106 DEBUG (MainThread) [homeassistant.components.websocket_api.http.connection] [140237825187776] lukas from 172.27.110.251 (Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:131.0) Gecko/20100101 Firefox/131.0): Received {'type': 'config/entity_registry/list', 'id': 70}
- Core 2024.10.2
- Supervisor 2024.10.0
- Operating System 13.1
- Frontend 20241002.3
