I’ve reached my point of frustration with my 3 Yale Assure 2 locks. I have YRD450-ZW3 zwave modules in them (from eBay). My issue is that they are not updating the state, when locked or unlocked directly at the door. I can unlock them through HA and they work wonderfully, but if I unlock using the code or fingerprint, that is not updating HA. Here is what I recently changed:
- Replaced my ZWave controller with Zooz ZST39 800 Series (updated firmware to FW 1.50, SDK 7.22.1)
- Repaired all devices (2 of the Yale locks had to be reset because they would not exclude from the prior controller)
My HA instance is a VM in proxmox, so when I initial pair the locks, it is not easy to move the USB stick close to the lock. I bought a 60’ USB extension cable, ran that through my house and paired the various locks directly to the controller in S2 mode.
When the lock is unlocked locally, without fail, I can open up Z-Wave JS UI add-on, go to the device, and hit Refresh on the Door Lock v4 section, and low and behold, it updates from Locked to Unlocked. Once I do this, if I then manually change the lock state, it updates a few times, but eventually it stops updating.
I forced one lock to route through a nearby Inovelli Z-Wave switch (also S2). None of the locks are “that far” from the controller:
Garage: Maybe 50’, through one exterior wall
Front Door: Maybe 50’, through a few interior walls. Longest distance from an S2 device to the front lock is perhaps 20’.
Side Door: Maybe 40’, through a few interior walls. Longest distance from an S2 device to the side lock is perhaps 30’.
Here’s my ZWave JS UI network map filtered to the three locks:
I see reviews online that people like these and find them to be reliable, which makes me think I need to change something, but I"m about at the point where the something to be changed is the locks themselves. Any ideas to increase the reliability? Thanks!
