Good Morning,
i have often see the CuxD line in the cofiguration.yaml.
Ok, what is the right way to import the FS20 Devices from the raspberrymatic CCU to hasso?
Then you have seen incorrect configurations where people have tried it without success. I don’t know of any way to use FS20 devices with Home Assistant unfortunately.
You still need raspberrymatic for the classic HomeMatic devices. So if you have one machine with Home Assistant (OS) + the raspberrymatic add-on, you need another separate machine where you can run the CUL-mqtt service. That of course would only work if you have a CUL-dongle. But as stated above, I have no experience with this and can’t tell if this will actually work. To be honest, I’d rather recommend you replace the FS20 devices with ones that are supported already.
No. As mentioned above, there is nothing (that I know of) that can talk to CuxD using Python (which is what Home Assistant is coded in).
