I have a small memory card attached to my asus router usb and set up as an ftp/samba share on the network.
I was hoping to add the ftp server location to my motioneye upload settings to access them easily but cannot get it to connect at all.
I can access the storage from my browser and file explorer.
Also turned on the anonymous log in also just to test. Still won’t connect.
Tried with and without the prefix ftp://
port 21? Tried some other ports.
Have you tried it without the location (can you access the / directory)?
Other than that, I’d check the FTP server settings … Connecting from the browser (generally port 80) and explorer doesn’t necessarily speak to the FTP server settings being correct.
Unfortunately the location field is mandatory. Still struggling
Logs:
File "/usr/lib/python2.7/site-packages/motioneye/uploadservices.py", line 854, in test_access
conn = self._get_conn(create=True)
File "/usr/lib/python2.7/site-packages/motioneye/uploadservices.py", line 911, in _get_conn
self._conn.connect(self._server, port=self._port)
File "/usr/lib/python2.7/ftplib.py", line 135, in connect
self.sock = socket.create_connection((self.host, self.port), self.timeout)
File "/usr/lib/python2.7/socket.py", line 557, in create_connection
for res in getaddrinfo(host, port, 0, SOCK_STREAM):
gaierror: [Errno -2] Name does not resolve
Yeah that does appear to be a configuration issue on the server side. Is the username “userlogin”? Are you certain it’s configured to listen on port 21 (which is indeed the standard port)? Are you able to test/connect with a different FTP client?
