Fuel Prices JSON undefined when rendering
Hi all,
Over the last couple of weeks, I’ve been getting errors returning on some (but not all) of the fuel prices that I’m pulling into Home Assistant.
The issues just seem to be occuring with the Tesco JSON file here: https://www.tesco.com/fuel_prices/fuel_prices_data.json.
Any ideas how I might fix it? Thanks!
2024-09-15 12:55:05.080 ERROR (MainThread) [homeassistant.helpers.template] Template variable error: ‘value_json’ is undefined when rendering ‘{% set c = value_json.stations| selectattr(‘site_id’, ‘eq’, ‘gcnqu4gfqytc’) | first %}{{ ‘%.3f’ | format(c.prices.E10) }}’
Likely, the actual http call fails for whatever reason.
To just avoid the error message you can check the availability of the JSON.
The state of the sensor will change to unavailable then.
Here’s an example how I use it.
If, for whatever reason, sensor.shelly_plug_1_power is not providing a numeric value, the operating status also switches to unavailable.
    - name: "Washing Machine Operting Status"
      unique_id: fa06a837-3f59-4995-9750-34c0b3a8db70
      device_class: running
      delay_on:
        seconds: 60
      delay_off:
        seconds: 60
      availability: >
        {{ is_number(states('sensor.shelly_plug_1_power')) }}
      state: >
        {{ states('sensor.shelly_plug_1_power')|float > 1 }}
      icon: mdi:washing-machine
I’d like to add to this as the Tesco sensor last worked on 6th September.
The REST resource is https://www.tesco.com/fuel_prices/fuel_prices_data.json and my template is
value_template: "{% set station = value_json.stations | selectattr('site_id', 'eq', 'gcjcty9xrcsj') | first %}{{ '%.2f' | format(station.prices.B7 / 100) }}"
The logged error is “Template variable error: ‘value_json’ is undefined”
Nothing changed for me (no updates or reboots) when the error started appearing. I have since updated and rebooted, and the error persists.
Checking https://jsonlint.com/ the JSON Tesco is returning is actually valid.
ASDA/Sainsburys/Esso fuel price sensors are unaffected.
In Developer tools the template works as expected:
{% set value_json = {"last_updated": "17/09/2024 11:19:01", "stations": [{"site_id": "gcx1zhq978t7", "brand": "TESCO", "address": "Tesco Express Doncaster Road Brayton Selby", "postcode": "YO8 9EG", "location": {"latitude": 53.768681, "longitude": -1.089549}, "prices": {"E5": 141.9, "E10": 131.9, "B7": 138.9}}, {"site_id": "gcrjktx96h1j", "brand": "TESCO", "address": "Tesco Express Nuthall Road Nottingham", "postcode": "NG8 6AU", "location": {"latitude": 52.984551, "longitude": -1.198109}, "prices": {"E5": 136.9, "E10": 129.9, "B7": 135.9}} ... TRUCATED ...]} %}
So, as koying says, the actual http call fails for whatever reason… how can I debug that reason and get to the bottom of this ‘value_json’ is undefined error?
Looks like that api (now?) requires some headers to work:
- resource: 'https://www.tesco.com/fuel_prices/fuel_prices_data.json'
  headers:
    user-agent: Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:130.0) Gecko/20100101 Firefox/130.0
    accept-encoding: gzip, deflate, br, zstd
  - name: Tesco
    value_template: >
I like the look of this, do you know if Shell offer the same? They’re local to me, but have 3 facilities across the town. So would be good to know which one has the lowest price for fuel.
Thanks,
Garry
I came across this post and was interested enough to try to run this in Node-RED. The UK Gov site has a full list of 15 fuel providers signed up to providing station location/price data in JSON format, so in Node-RED it was very easy to build a full list, poll the API for each brand, calculate distance from home for each station, and build a complete list of all stations with prices and distance. Did you know that the cheapest petrol is in Gibraltar, 1020 miles away?
However, the API for Tesco is proving difficult to get working.
The URL works just fine in a browser.
The URL did work, once, when first used in a Node-RED http request, thereafter it does not respond and I get a timeout.
Adding some headers to the call, such as
gets a response as ‘access denied - you do not have permission etc’.
I use Google Chrome, and by inspection pulled the complete set of 16 headers that Chrome uses to call the URL, then added all of them to my http request, and yes it now works. By carefully removing one header at a time, I have found which ones are required - missing any of these five gives me either access denied or a timeout error. (at least this is working at the moment…)
headers:
  accept: clubcard
  accept-encoding: points
  accept-language: spanglish
  user-agent: dark-glasses
  cookie: dough
You can see, from the header values that I am using, that nothing is actually being used, just someone at some point has messed about with something and the API URL (which goes through www-tesco-com) must be looking for the existence of certain headers before it both accepts and then forwards the request.
As they say, every little header helps.
You genius!! This was it… all fixed now. Thank you very much for posting :smiley:
Thank you ever so much - I’ve managed to get this back up and running now. Thank you!
This looks fab- not sure if I’m just being dense, but mine still doesn’t work. Does this look correct?
  - platform: rest
    name: Tesco Fuel Prices
    resource: http://www.tesco.com/fuel_prices/fuel_prices_data.json
    method: GET
    headers:
      accept: clubcard
      cookie: dough
    json_attributes:
      - stations
    scan_interval: 21600
I have not tried setting this up in HA as a rest sensor, but I have tried using this in Node-RED with an http request node, and it still appears to work there with the ‘nominal headers’ I was playing around with.
{"last_updated": "03/01/2025 11:18:59", "stations": [{"site_id": "gcx1zhq978t7", "brand": "TESCO", "address": "Tesco Express Doncaster Road Brayton Selby", "postcode": "YO8 9EG", "location": {"latitude": 53.768681, "longitude": -1.089549}, "prices": {"E5": 141.9, "E10": 131.9, "B7": 139.9}}, {"site_id": "gcrjktx96h1j", "brand": "TESCO", "address": "Tesco Express Nuthall Road Nottingham", "postcode": "NG8 6AU", "location": {"latitude": 52.984551, "longitude": -1.198109}, "prices": {"E5": 140.9, "E10": 133.9, "B7": 138.9}}, {"site_id": "gcr6ed3cmh3t", "brand": "TESCO", "address": "Rockingham Rd Market Harborough", "postcode": "LE16 7QD", "location": {"latitude": 52.483301, "longitude": -0.898259}, "prices": {"E5": 140.9, "E10": 133.9, "B7": 138.9}}, {"site_id": "gcw01j9wc5dn", "brand": "TESCO", "address": "East Lancashire Rd Windle Island St Helens", "postcode": "WA10 6QY", "location": {"latitude": 53.468891, "longitude": -2.766449}, "prices": {"E5": 138.9, "E10": 131.9, "B7": 137.9}}, {...
I suggest you try:
In case anyone needs it in the future.
This is what i got to work for me thanks to the info from @Biscuit
all this is in one yaml file as i use the packages integration.
Obviously change the details to suit.
  - platform: rest
    unique_id: fuel_glossop
    resource: https://www.tesco.com/fuel_prices/fuel_prices_data.json
    method: GET
    json_attributes_path: "$.stations[?(@.site_id=='gcw85374xfbg')]"
    json_attributes:
      - brand
      - address
      - postcode
      - location
      - prices
    headers:
    value_template: 'OK'
  - platform: rest
    unique_id: fuel_hattersley
    json_attributes_path: "$.stations[?(@.site_id=='gcw81fyk3kew')]"
    method: GET
    json_attributes:
      - brand
      - address
      - postcode
      - location
      - prices
    headers:
  - platform: rest
    unique_id: sainburys_fuel_prices
    resource: https://api.sainsburys.co.uk/v1/exports/latest/fuel_prices_data.json
    json_attributes_path: "$.stations[?(@.site_id=='gcw821ez6mwm')]"
    json_attributes:
      - brand
      - address
      - postcode
      - location
      - prices
template:
  - sensor:
      - name: "Tesco Glossop Unleaded"
        state: "{{ '%.2f' | format(state_attr('sensor.tesco_fuel_glossop', 'prices')['E10'] / 100) }}"
        unit_of_measurement: "£"
        icon: mdi:gas-station
        unique_id: fuel_glossop_id
        state_class: measurement
      - name: "Tesco Hattersley Unleaded"
        state: "{{ '%.2f' | format(state_attr('sensor.tesco_fuel_hattersley', 'prices')['E10']) }}"
        unique_id: fuel_hattersley_id
      - name: "Sainsburys Ashton Unleaded"
        state: "{{ '%.2f' | format(state_attr('sensor.sainsbury_fuel_prices', 'prices')['E10']) }}"
        unique_id: fuel_sainsburys_id
This stopped working again for me in NodeRed. Did some digging and I needed to update the user agent to fix it -
Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:136.0) Gecko/20100101 Firefox/136.0
Thanks for this I realised mine wasn’t working and this got it going again :+1:t2:
Can I ask what is it you dig for to find out what’s causing it ?
Has anyone else got an issue with the Tesco API? My sensors for Tesco Petrol aren’t working…
Hello @Steveuk, I use NodeRed with a http request node and noticed that I was not getting a response from the Tesco URL anymore. It was just a case of playing with the headers to get it working again and I noticed that using the firefox browser on my PC that it was using version 136.0. Adding that cleared the error and I could pull the data again.
Can you share how you are pulling this data in HA ? You will need to correct the headers in it then adding this should fix it. You will need to reload your rest sensors in YAML after changing it.
Thanks so this might possibly be an ongoing issue everytime browsers change :thinking:
@markgolledge just change the header to what @BertrumUK has added above.
Hi @BertrumUK thanks that solved it for me!
Perfect - thank you. That has solved it!
