Full cli path to configuration.yaml
I have looked everywhere and I can’t find the full path to configuration.yaml.
I have enter CLI and then entered login and I’m in but I need to full path to configuration.yaml I badly need my settings from a old machine that have lost network interface.
That depends what the install method was and what container you are in when using the cli.
https://www.home-assistant.io/docs/configuration/#editing-configurationyaml
I have installed it with the image for proxmox, I have tried to find it with the ~/.homeassistant but I can’t find that folder so what’s the full path? ~ is a shortcut for home folder
You have Home Assistant OS - the image as you call it.
Your path is /config
hmm, that don’t seem to work either
When you typed:
login
You dropped out of the home assistant container into the os.
From the ha > prompt:
cd /config
ls
You are on the OS shell. The config folder is at /mnt/data/supervisor/homeassistant.
Typing /config tries to run that as a command, you need to use cd to change directory, as Tom shows.
Indeed, when you connect via Proxmox, you get the OS Shell.
