So you can see - under the HASS OS, there is nothing.
I looked at that as well. I should not have to go down that ârabbit holeâ - as finding an OID for specific things is like pulling teeth from an angry crocodile. LOL
The OS - depending on which one - sees it. I have even booted with a LIVE ALPINE LINUX USB - and it will also have the needed info - just in another file. Under that OS - it stores it here:
/sys/class/thermal/thermal_zone0/temp
Using the following in sersors.yaml - I can pull it.
# - platform: command_line
command: "cat /sys/class/thermal/thermal_zone0/temp"
# If errors occur, make sure configuration file is encoded as UTF-8
unit_of_measurement: "°C"
value_template: "{{ value | multiply(0.001) | round(1) }}"
The point I am making is that the developers have STRIPPED OUT key features of the ALPINE LINUX they built HASS OS from, and they need to put it back.
Thought I would throw this into the mix as well. I tried PROXMOX on this same box. Simple enough, used this: Installing Home Assistant OS using Proxmox 7
When I looked at the âHostâ shell, it also had the CPU TEMP in a location where I could find it - but inside the HA, no such luck. I was soooo happy, then THOR Slammed his axe into my head.
Well proxmox is debian, so no surprises there
I donât think I have seen the list of modules recommended by sensors-detect on debian.
Thanks @bearhntr for the detailed posts in response to my questions.
I am pretty sure as a result I can say that the k10temp kernel driver is what is needed in the case of your motherboard. Time for a little kernel education (forgive me if you know this).
Drivers are optionally compiled when a kernel is compiled. For example the kernel for a x86 machine would not bother compiling drivers that were only intended for a rpi.
The drivers that are compiled can either be compiled into the kernel, or compiled as modules. On debian the kernel is heavily modularised, as you can see from the number of modules that are loaded from your lsmod output. (lsmod lists the modules presently loaded in the kernel.)
HAOS has less modules loaded. It does not have the k10temp module loaded. This could be because
HAOS compiles the k10temp driver into the kernel as opposed to as a module; or
HAOS simply doesnât compile k10temp into the kernel or as a module; or
HAOS doesnât correctly read the hardware and therefore does not load the k10temp module or driver
TL;DR - Now we are pretty sure what we are looking for, post an issue on the HAOS github,
I appreciate yourâs and everyone elseâs assistance.
a) I have partial understand of what you mentioned - as I am a computer nut, just not a LINUX guru.
b) No Idea how to report this, as I have multiple times addressed this as a BUG - only to be told the following (from one of the developers):
*Thank you for reaching out.*
*This is not a bug report for development, this is a support question and is not related to the function of command_line, but is related to how you use the command line integration itself.*
*We use GitHub for tracking issues, not for providing support.*
*If you are in need of support, you should try our [Community Forum](https://community.home-assistant.io/) or join our [Discord chat server](https://discord.gg/c5DvZ4e).*
*You are more likely to get the answer you are looking for in those places.*
c) What I do not understand - and I would fix on my own - is how to get those drivers/modules/firmware into the HASS OS (and make them stick). I have tested this hardware with a UBUNTU Live, DEBIAN 11 Live and even an ALPINE Live bootable USB (this is what HASS OS is based on) â all of them pull the CPU Temp (while not always into the same âpathâ, but I can track it down.
This is Interesting:
Just not sure why I would want to put HA in a VM - not sure what else I would do with the box.
Here is lsmod
alpine:~# lsmod
Module Size Used by
nls_utf8 16384 1
nls_cp437 20480 1
vfat 24576 1
fat 90112 1 vfat
ipv6 643072 18
af_packet 53248 0
btusb 49152 0
btrtl 24576 1 btusb
btbcm 24576 1 btusb
btintel 40960 1 btusb
bluetooth 520192 5 btrtl,btintel,btbcm,btusb
ecdh_generic 16384 1 bluetooth
ecc 40960 1 ecdh_generic
psmouse 155648 0
serio_raw 16384 0
pcspkr 16384 0
efi_pstore 16384 0
r8169 102400 0
realtek 28672 1
mdio_devres 16384 1 r8169
snd_hda_codec_realtek 159744 1
libphy 163840 3 r8169,mdio_devres,realtek
snd_hda_codec_generic 94208 1 snd_hda_codec_realtek
snd_hda_codec_hdmi 69632 1
sp5100_tco 16384 0
ledtrig_audio 16384 1 snd_hda_codec_generic
i2c_piix4 24576 0
fam15h_power 16384 0
k10temp 16384 0
snd_hda_intel 53248 0
snd_intel_dspcfg 24576 1 snd_hda_intel
snd_intel_sdw_acpi 16384 1 snd_intel_dspcfg
snd_hda_codec 167936 4 snd_hda_codec_generic,snd_hda_codec_hdmi,snd_hda_intel,snd_hda_codec_realtek
snd_hda_core 114688 5 snd_hda_codec_generic,snd_hda_codec_hdmi,snd_hda_intel,snd_hda_codec,snd_hda_codec_realtek
snd_hwdep 20480 1 snd_hda_codec
snd_pcm 139264 4 snd_hda_codec_hdmi,snd_hda_intel,snd_hda_codec,snd_hda_core
snd_timer 45056 1 snd_pcm
snd 114688 8 snd_hda_codec_generic,snd_hda_codec_hdmi,snd_hwdep,snd_hda_intel,snd_hda_codec,snd_hda_codec_realtek,snd_timer,snd_pcm
soundcore 16384 1 snd
amdgpu 7393280 0
mfd_core 16384 1 amdgpu
iommu_v2 24576 1 amdgpu
gpu_sched 45056 1 amdgpu
radeon 1708032 1
hwmon 32768 4 k10temp,amdgpu,radeon,fam15h_power
i2c_algo_bit 16384 2 amdgpu,radeon
drm_ttm_helper 16384 2 amdgpu,radeon
ttm 81920 3 amdgpu,radeon,drm_ttm_helper
input_leds 16384 0
mousedev 24576 0
amd_freq_sensitivity 16384 0
kvm_amd 143360 0
ccp 102400 1 kvm_amd
kvm 1069056 1 kvm_amd
irqbypass 16384 1 kvm
crct10dif_pclmul 16384 1
ghash_clmulni_intel 16384 0
aesni_intel 380928 0
hp_wmi 20480 0
platform_profile 16384 1 hp_wmi
sparse_keymap 16384 1 hp_wmi
rfkill 28672 2 hp_wmi,bluetooth
wmi_bmof 16384 0
crypto_simd 16384 1 aesni_intel
cryptd 24576 2 crypto_simd,ghash_clmulni_intel
wmi 32768 2 hp_wmi,wmi_bmof
evdev 28672 15
button 20480 0
acpi_cpufreq 20480 0
tpm_infineon 20480 0
tpm_tis 16384 0
tpm_tis_core 24576 1 tpm_tis
tpm 90112 3 tpm_tis,tpm_infineon,tpm_tis_core
rng_core 16384 2 ccp,tpm
efivarfs 16384 1
uas 28672 0
hid_generic 16384 0
usbhid 45056 0
hid 147456 2 usbhid,hid_generic
crc32_pclmul 16384 0
ahci 45056 0
libahci 45056 1 ahci
libata 299008 2 libahci,ahci
ohci_pci 16384 0
ohci_hcd 49152 1 ohci_pci
xhci_pci 20480 0
xhci_pci_renesas 16384 1 xhci_pci
xhci_hcd 278528 1 xhci_pci
ehci_pci 16384 0
ehci_hcd 69632 1 ehci_pci
simpledrm 16384 0
drm_kms_helper 319488 3 amdgpu,radeon,simpledrm
cfbfillrect 16384 1 drm_kms_helper
syscopyarea 16384 1 drm_kms_helper
cfbimgblt 16384 1 drm_kms_helper
sysfillrect 16384 1 drm_kms_helper
sysimgblt 16384 1 drm_kms_helper
fb_sys_fops 16384 1 drm_kms_helper
cfbcopyarea 16384 1 drm_kms_helper
cec 53248 1 drm_kms_helper
drm 647168 8 gpu_sched,drm_kms_helper,amdgpu,radeon,drm_ttm_helper,simpledrm,ttm
i2c_core 106496 7 drm_kms_helper,i2c_algo_bit,amdgpu,radeon,psmouse,i2c_piix4,drm
drm_panel_orientation_quirks 24576 1 drm
agpgart 49152 3 radeon,ttm,drm
loop 40960 0
ext4 954368 1
crc32c_generic 16384 0
crc32c_intel 24576 2
crc16 16384 2 bluetooth,ext4
mbcache 16384 1 ext4
jbd2 167936 1 ext4
usb_storage 77824 4 uas
usbcore 303104 10 xhci_hcd,ohci_hcd,ehci_pci,usbhid,usb_storage,ehci_hcd,btusb,xhci_pci,ohci_pci,uas
usb_common 16384 3 xhci_hcd,ohci_hcd,usbcore
sd_mod 53248 4
t10_pi 16384 1 sd_mod
scsi_mod 221184 4 sd_mod,usb_storage,uas,libata
alpine:~# uname -a
Linux alpine 5.15.62-1-lts #2-Alpine SMP Thu, 25 Aug 2022 06:18:18 +0000 x86_64 Linux
and
alpine:~# find /sys | grep temp1_input
/sys/devices/pci0000:00/0000:00:18.3/hwmon/hwmon1/temp1_input
/sys/devices/pci0000:00/0000:00:01.0/hwmon/hwmon0/temp1_input
and
/sys/kernel/debug/kvm/directed_yield_attempted
/sys/kernel/debug/kvm/halt_attempted_poll
/sys/kernel/debug/tracing/events/amdgpu_dm/amdgpu_dm_atomic_state_template
/sys/kernel/debug/tracing/events/amdgpu_dm/amdgpu_dm_atomic_state_template/format
/sys/kernel/debug/tracing/events/amdgpu_dm/amdgpu_dm_atomic_state_template/trigger
/sys/kernel/debug/tracing/events/amdgpu_dm/amdgpu_dm_atomic_state_template/filter
/sys/kernel/debug/tracing/events/amdgpu_dm/amdgpu_dm_atomic_state_template/id
/sys/kernel/debug/tracing/events/amdgpu_dm/amdgpu_dm_atomic_state_template/enable
/sys/kernel/debug/tracing/events/thermal/thermal_temperature
/sys/kernel/debug/tracing/events/thermal/thermal_temperature/format
/sys/kernel/debug/tracing/events/thermal/thermal_temperature/trigger
/sys/kernel/debug/tracing/events/thermal/thermal_temperature/filter
/sys/kernel/debug/tracing/events/thermal/thermal_temperature/id
/sys/kernel/debug/tracing/events/thermal/thermal_temperature/enable
/sys/devices/pnp0/00:08/temp_deactivated
/sys/devices/pnp0/00:08/tpm/tpm0/temp_deactivated
/sys/devices/platform/hp-wmi/hddtemp
/sys/devices/pci0000:00/0000:00:18.3/hwmon/hwmon1/temp1_crit
/sys/devices/pci0000:00/0000:00:18.3/hwmon/hwmon1/temp1_crit_hyst
/sys/devices/pci0000:00/0000:00:18.3/hwmon/hwmon1/temp1_max
/sys/devices/pci0000:00/0000:00:01.0/hwmon/hwmon0/temp1_crit
/sys/devices/pci0000:00/0000:00:01.0/hwmon/hwmon0/temp1_crit_hyst
/sys/bus/pci/drivers/k10temp
/sys/bus/pci/drivers/k10temp/uevent
/sys/bus/pci/drivers/k10temp/0000:00:18.3
/sys/bus/pci/drivers/k10temp/bind
/sys/bus/pci/drivers/k10temp/new_id
/sys/bus/pci/drivers/k10temp/remove_id
/sys/bus/pci/drivers/k10temp/unbind
/sys/bus/pci/drivers/k10temp/module
/sys/firmware/efi/esrt/entries/entry0/last_attempt_version
/sys/firmware/efi/esrt/entries/entry0/last_attempt_status
/sys/module/k10temp
/sys/module/k10temp/initsize
/sys/module/k10temp/uevent
/sys/module/k10temp/notes
/sys/module/k10temp/notes/.note.Linux
/sys/module/k10temp/notes/.note.gnu.build-id
/sys/module/k10temp/notes/.note.gnu.property
/sys/module/k10temp/taint
/sys/module/k10temp/parameters
/sys/module/k10temp/parameters/force
/sys/module/k10temp/holders
/sys/module/k10temp/refcnt
/sys/module/k10temp/coresize
/sys/module/k10temp/drivers
/sys/module/k10temp/drivers/pci:k10temp
/sys/module/k10temp/initstate
/sys/module/k10temp/sections
/sys/module/k10temp/sections/.orc_unwind
/sys/module/k10temp/sections/__param
/sys/module/k10temp/sections/.note.Linux
/sys/module/k10temp/sections/.strtab
/sys/module/k10temp/sections/__mcount_loc
/sys/module/k10temp/sections/.exit.text
/sys/module/k10temp/sections/.bss
/sys/module/k10temp/sections/.orc_unwind_ip
/sys/module/k10temp/sections/.return_sites
/sys/module/k10temp/sections/.gnu.linkonce.this_module
/sys/module/k10temp/sections/.symtab
/sys/module/k10temp/sections/.rodata
/sys/module/k10temp/sections/.init.text
/sys/module/k10temp/sections/.note.gnu.build-id
/sys/module/k10temp/sections/.text
/sys/module/k10temp/sections/.data
/sys/module/k10temp/sections/__bug_table
/sys/module/k10temp/sections/.rodata.str1.1
/sys/module/k10temp/sections/.parainstructions
/sys/module/k10temp/sections/.text.unlikely
/sys/module/k10temp/sections/.note.gnu.property
/sys/module/k10temp/sections/.retpoline_sites
/sys/module/k10temp/sections/.rodata.str1.8
/sys/module/hwmon/holders/k10temp
Haos is not based on alpine. It is based on buildroot.
What you are seeing is the ssh addon, which is Docker container based on alpine.
All you need to do is read the docs which state
Home Assistant Operating System is not based on a regular Linux distribution like Ubuntu. It is built using Buildroot and it is optimized to run Home Assistant. It targets single board compute (SBC) devices like the Raspberry Pi or ODROID but also supports x86-64 systems with UEFI.
ummmmmâŚok. know nothing about Docker containers
Where is this HAOS gitHub you reference. I think I have posted this problem just about everywhere.
Sorry to be âdaftâ and I appreciate all your help. I just really would like to get this CPU temp thing working in a true-blue HASS OS install.
The link is in my last post.
tl;dr
I think the problem is that every processor and even every motherboard measure temperature differently.
I have three Intel NUCS here, one of them running Home Assistant OS generic x-86. I cannot find anywhere that describes where on the NUC are the three thermal_zones except that Zone3 is at the base of the CPU socket. And even that information is anecdotal. It is eventually the same as hwmon/temp1_input
For my âhomeâ page in Home Assistant, I made a sensor in sensors.yaml:
name: CPU temp1 input
command: "cat /sys/class/hwmon/hwmon1/temp1_input"
I didnât have to install anything, this was all in generic X-86 HAOS.
Needless. Your local network credentials are completely useless to a hacker unless they are ON your local network. There are probably thousands of Home Assistant installations on 192.168.10.6.
Agreed - but my system has External AccessâŚand also IPV6.
I just do that to ânot put it out thereâ.
Yes Sir⌠I have used this many times when I was running DEBIAN 11 / HA Supervised. Now that I have gone to Generic x86 (full HASS OS install) â the folder and file does not exist. Cannot report on something not there. There is nothing in the hwmon
folder - and the thermal folder looks like this:
and the cooling_device# folders all look like this:
