Full list of theme.yaml lines
Hi all,
Does someone have the full theme example file? Where all lines are add that you can change in your needs?
Here is mine. Noctis is my favorite. It’s the last one in the code.
https://pastebin.com/ErmaxPg7
Add to frontend.yaml
what I mean is a standart template where all possible lines like this:
      # Text
      text-color: '#ffffff'
      primary-text-color: 'var(--text-color)'
      text-primary-color: 'var(--text-color)'
      secondary-text-color: "#BAC0C6"
      text-medium-light-color: '#A0A2A8'
      text-medium-color: '#80828A'
      primary-color: 'var(--secondary-text-color)'
is shown. Lots of themes have some of them, other have different once.
I want a standard full list, everything in it. Then I can edit my own theme :slight_smile:
I’ve not seen something like you are describing. I use Chrome’s DevTools to see what CSS fields are available for modifying.
Maybe im not clear what I mean.
We have a default theme in HA, you can create your own theme for HA. But what are the possible lines to edit for your own theme. So a theme example file that show all standard possible lines that you can use to make it your own. I
Im now combine some themes and filter it. Get a long list of possible edible lines:
template:
#  var(--disabled-text-color) # Use this when you want use a different variable for same line
#  background: "center / cover no-repeat url("/local/background.jpg") fixed"
# TEXT
  primary-text-color: "rgba(255, 255, 255, 1)"
  secondary-text-color: "rgba(190, 190, 190, 1)"
  text-primary-color: "rgba(255, 255, 255, 1)"
  disabled-text-color: "rgba(0, 0, 0, 1)"
# MAIN INTERFACE COLORS
  primary-color: "rgba(0, 0, 0, 1)"
  dark-primary-color: "rgba(0, 0, 0, 1)"
  light-primary-color: "rgba(0, 0, 0, 1)"
  accent-color: "rgba(0, 255, 0, 1)"
# table lines around sidebar
  divider-color: "rgba(0, 190, 0, 1)"
  scrollbar-thumb-color: 'rgba(0, 0, 0, 1)’
  error-color: '#db4437'
  error-state-color: 'var(--error-color)'
 # CARDS
  ha-card-border-radius: "5px"
  ha-card-box-shadow: "inset 1px 1px 1px 1px var(--border-color)"
  ha-card-header-color: "rgba(255, 255, 255, 1)"
 # STATES AND BADGES
  state-icon-active-color: "rgba(0, 0, 0, 1)"
  state-icon-color: "rgba(0, 0, 0, 1)"
  state-icon-unavailable-color: "rgba(0, 0, 0, 1)"
 # BACKGROUND AND SIDEBAR
  card-background-color: "rgba(0, 0, 0, 1)"
  primary-background-color: "rgba(90, 90, 90, 1)"
  secondary-background-color: "rgba(90, 90, 90, 1)"
# SIDEBAR MENU
  sidebar-text-color: "rgba(255, 255, 0, 1)"
  sidebar-background-color: "rgba(100, 255, 100, 1)"
  sidebar-icon-color: "rgba(0, 255, 255, 1)"
  sidebar-selected-icon-color: "rgba(255, 255, 255, 1)"
  sidebar-selected-text-color: "rgba(255, 255, 255, 1)"
  sidebar-selected-background-color: "rgba(0, 0, 0, 1)"
 # CONTROLS
  switch-checked-color: "rgba(0, 0, 0, 1)"
  switch-unchecked-color: "rgba(0, 0, 0, 1)"
  switch-checked-button-color: "rgba(166, 0, 255, 1)"
  switch-unchecked-button-color: "rgba(0, 0, 0, 1)"
  switch-checked-track-color: "rgba(0, 0, 0, 1)"
  switch-unchecked-track-color: "rgba(0, 0, 0, 1)"
  slider-color: rgba(0, 0, 0, 1)"
  slider-secondary-color: rgba(0, 0, 0, 1)"
  slider-bar-color: 'var(--disabled-text-color)'
# FOR LABEL BADGE
  label-badge-background-color: "rgba(0, 0, 0, 1)"
  label-badge-text-color: "rgba(0, 0, 0, 1)"
  label-badge-blue: "rgba(0, 0, 255, 1)"
  label-badge-green: "rgba(0, 255, 0, 1)"
  label-badge-red: "rgba(255, 0, 0, 1)"
  label-badge-yellow: "rgba(255, 255, 0, 1)"
  label-badge-grey: "rgba(125, 125, 125, 1)"
# Paper-styles color.html dependency is stripped on build.
# When a default paper-style color is used, it needs to be copied
# from paper-styles/color.html to here.
  paper-grey-50: "rgba(0, 0, 0, 1)"
  paper-grey-200: "rgba(0, 0, 0, 1)"
  paper-grey-400: "rgba(0, 0, 0, 1)"
# for paper-spinner
  google-blue-500: "var(--make-blue)"
  google-green-500:  "var(--make-green)"
  google-red-500: "rgba(0, 0, 0, 1)"
  google-yellow-500: "rgba(0, 0, 0, 1)"
  paper-spinner-color: "rgba(0, 0, 0, 1)"
# for paper-slider
  paper-blue-400: "rgba(0, 0, 0, 1)"
  paper-green-400: "rgba(0, 0, 0, 1)"
  paper-orange-400: "rgba(0, 0, 0, 1)"
# opacity for dark text on a light background
  dark-divider-opacity: "0"
  dark-disabled-opacity: '0.38' #or hint text or icon
  dark-secondary-opacity: '0.54'
  dark-primary-opacity: '0.87'
# opacity for light text on a dark background
  light-divider-opacity: "0"
  light-disabled-opacity: '0.3' # or hint text or icon
  light-secondary-opacity: '0.7'
  light-primary-opacity: '1.0'
# derived colors, to keep existing themes mostly working
  paper-card-background-color: "rgba(0, 0, 0, 1)"
  paper-listbox-background-color: "rgba(0, 0, 0, 1)"
  paper-item-icon-active-color: "rgba(0, 0, 0, 1)"
  paper-item-icon-color: "rgba(0, 0, 0, 1)"
  table-row-alternative-background-color: "rgba(166, 0, 255, 1)"
  table-row-background-color: "rgba(166, 0, 255, 1)"
# set our slider style
  paper-slider-knob-color: "rgba(0, 0, 0, 1)"
  paper-slider-knob-start-color: "rgba(0, 0, 0, 1)"
  paper-slider-pin-color: "rgba(0, 0, 0, 1)"
  paper-slider-active-color: "rgba(0, 0, 0, 1)"
  paper-slider-secondary-color: "rgba(0, 0, 0, 1)"
  paper-slider-container-color: "rgba(0, 0, 0, 1)"
  ha-paper-slider-pin-font-size: '15px'
# set data table style
  data-table-background-color: "rgba(0, 0, 0, 1)"
# Change some parts in developer tools
  paper-dialog-background-color: "rgba(0,255,0,1)"
  paper-dialog-color: "rgba(0, 0, 0, 1)"
# rgb
  rgb-primary-color: 'rgb(3, 169, 244)'
  rgb-accent-color: 'rgb(255, 152, 0)'
  rgb-primary-text-color: 'rgb(33, 33, 33)'
  rgb-secondary-text-color: 'rgb(114, 114, 114)'
  rgb-text-primary-color: 'rgb(255, 255, 255)'
# mwc
  mdc-theme-primary: "rgba(0, 0, 0, 1)"
  mdc-theme-secondary: 'var(--accent-color)'
  mdc-theme-background: 'var(--primary-background-color)'
  mdc-theme-surface: 'var(--paper-card-background-color, var(--card-background-color))'
# mwc text styles
  mdc-theme-on-primary: 'var(--text-primary-color)'
  mdc-theme-on-secondary: 'var(--text-primary-color)'
  mdc-theme-on-surface: 'var(--primary-text-color)'
# app header background color
  app-header-background-color: "rgba(0, 0, 255, 1)"
  app-header-text-color: 'var(--text-primary-color)'
# UNKNOWN LINES
  accent-medium-color: "rgba(0, 0, 0, 1)"
  background-card-color: "rgba(0, 0, 0, 1)"
  background-color-2: "rgba(0, 0, 0, 1)"
  background-image: "center / cover no-repeat url('/local/background.jpg') fixed"
# Controls the base (and accent) color hue (0-360) | 0=Red 60=Yellow 120=Green 180=Cyan 240=Blue 300=Magenta 360=Red
  base-hue: "120"
# Controls the saturation of the theme (0%-100%) | 0%=Grey 100%=Full Saturation
  base-sat: "80%"
  border-color: "rgba(0, 0, 0, 1)"
  ch-active-tab-color: "var(--accent-color)"
  ch-all-tabs-color: "var(--sidebar-icon-color)"
  ch-background: "var(--background-color)"
  ch-notification-dot-color: "var(--accent-color)"
  ch-tab-indicator-color: "var(--accent-color)"
  ha-label-badge-color: "rgba(0, 0, 0, 1)"
  huesat: "var(--base-hue), var(--base-sat),"
  iron-overlay-backdrop-background-color: "rgba(0, 0, 0, 1)"
  label-badge-border-color: "rgba(0, 0, 0, 1)"
  make-disable: "rgba(0, 0, 0, 1)"
  make-carbon: "rgba(30,30,30,1)"
  make-light-carbon: "rgba(40,40,40,1)"
  make-grey: "rgba(150,150,150,1)"
  make-blue: "rgba(0,0,255,1)"
  make-green: "rgba(0,255,0,1)"
  make-orange: "rgba(255,127,0,1)"
  make-red: "rgba(255,0,0,1)"
  make-white: "rgba(255,255,255,1)"
  make-yellow: "rgba(255,255,0,1)"
  paper-button-color:  "rgba(0, 0, 0, 1)"
  paper-button-ink-color: "rgba(0, 0, 0, 1)"
  paper-card-header-color: "rgba(0, 0, 0, 1)"
  paper-dialog-button-color: "rgba(0, 0, 0, 1)"
  primary-font-family: "Gill Sans"
  paper-font-body_-_font-family: "var(--primary-font-family)"
  paper-font-body1_-_font-family: "var(--primary-font-family)"
  paper-font-body1_-_font-weight: "500"
  paper-font-caption_-_font-family: "var(--primary-font-family)"
  paper-font-common-base_-_font-family: "var(--primary-font-family)"
  paper-font-headline_-_font-family: "var(--primary-font-family)"
  paper-font-headline_-_font-weight: "500"
  paper-font-headline_-_letter-spacing: "-0.5px"
  paper-font-subhead_-_font-family: "var(--primary-font-family)"
  paper-font-title_-_font-family: "var(--primary-font-family)"
  paper-icon-button-active-color: "rgba(0, 0, 0, 1)"
  paper-icon-button-inactive-color: "rgba(0, 0, 0, 1)"
  paper-item-icon_-_color: "rgba(0, 0, 0, 1)"
  paper-item-selected_-_background-color: "rgba(0, 0, 0, 1)"
  paper-listbox-color: "rgba(0, 0, 0, 1)"
  paper-progress-secondary-color: "rgba(0, 0, 0, 1)"
  paper-slider-disabled-active-color: "rgba(0, 0, 0, 1)"
  paper-slider-disabled-secondary-color: "rgba(0, 0, 0, 1)"
  paper-tabs-selection-bar-color: "rgba(0, 0, 0, 1)"
  paper-toggle-button-checked-bar-color: "rgba(0, 0, 0, 1)"
  paper-toggle-button-checked-button-color: "rgba(0, 0, 0, 1)"
  paper-toggle-button-checked-ink-color: "rgba(0, 0, 0, 1)"
  paper-toggle-button-unchecked-bar-color: "rgba(0, 0, 0, 1)"
  paper-toggle-button-unchecked-button-color: "rgba(0, 0, 0, 1)"
  paper-toggle-button-unchecked-ink-color: "rgba(0, 0, 0, 1)"
  shadow-elevation-16dp_-_box-shadow: "inset 0px 0px 0px 4px hsl(var(--huesat) 28%)"
  shadow-elevation-2dp_-_box-shadow: "inset 0px 0px 0px 4px hsl(var(--huesat) 18%)"
  sidebar-text_-_background: "rgba(0, 0, 0, 1)"
  sidebar-text_-_color: "rgba(0, 0, 0, 1)"
  text-dark-color: "rgba(255, 255, 255, 1)"
  text-medium-color: "rgba(255, 255, 255, 1)"
  text-medium-light-color: "rgba(255, 255, 255, 1)"
Can someone tell me if the lines below
# UNKNOWN LINES
are custom created lines to use them in a
part, or they actual a line to change something in the theme?
Did you ever find a full list? I would love to see that as well.
Was looking for the theme info of the default backend theme but didn’t find it. Here I have a theme that looks very complete to edit:
When you use HA 0.113x you need change these lines:
paper-card-background-color to ha-card-background or card-background-color
demo_template:
# TEXT
  lovelace-background: 'center / cover no-repeat url("/local/background.jpg") fixed' #Background-image
  primary-text-color: '#212121'
  secondary-text-color: '#727272'
  text-primary-color: '#ffffff'
  disabled-text-colour: '#bdbdbd'
  primary-color: '#03a9f4'
  dark-primary-color: '#0288d1'
  light-primary-color: '#b3e5fC'
  accent-color: '#ff9800'
  divider-color: 'rgba(0, 0, 0, .12)'
  scrollbar-thumb-color: 'rgb(194, 194, 194)'
  ################################# # CARDS #################################
  ha-card-border-radius: "15px"
  ha-card-box-shadow: "inset 0px 0px 2px 2px var(--border-color)"
  ################################# # STATES AND BADGES #################################
  state-icon-color: '#44739e'
  state-icon-active-color: '#FDD835'
  state-icon-unavailable-color: 'var(--disabled-text-color)'
  ################################# # BACKGROUND AND SIDEBAR #################################
  card-background-color: '#ffffff'
  primary-background-color: '#fafafa'
  secondary-background-color: '#e5e5e5' #behind the cards on state
  ################################# # SIDEBAR MENU #################################
  sidebar-text-color: 'var(--primary-text-color)'
  sidebar-background-color: 'var(--paper-listbox-background-color)' #backward compatible with existing themes
  sidebar-icon-color: 'rgba(0, 0, 0, 0.5)'
  sidebar-selected-text-color: 'var(--primary-color)'
  sidebar-selected-icon-color: 'var(--primary-color)'
  ################################# # CONTROLS #################################
  switch-checked-color: 'var(--primary-color)'
  switch-unchecked-color: 'var(--accent-color)'
  switch-checked-button-color: 'var(--switch-checked-color, var(--paper-grey-50))'
  switch-checked-track-color: 'var(--switch-checked-color, #000000)'
  switch-unchecked-button-color: 'var(--switch-unchecked-color, var(--paper-grey-50))'
  switch-unchecked-track-color: 'var(--switch-unchecked-color, #000000)'
  slider-color: 'var(--primary-color)'
  slider-secondary-color: 'var(--light-primary-color)'
  ################################# # FOR LABEL BADGE #################################
  label-badge-background-color: 'white'
  label-badge-text-color: 'rgb(76, 76, 76)'
  label-badge-red: '#DF4C1E'
  label-badge-blue: '#039be5'
  label-badge-green: '#0DA035'
  label-badge-yellow: '#f4b400'
  label-badge-grey: 'var(--paper-grey-500)'
  paper-grey-50: '#fafafa'  # default for: --mwc-switch-unchecked-button-color
  paper-grey-200: '#eeeeee' # for ha-date-picker-style
  paper-grey-500: '#9e9e9e' # --label-badge-grey
# for paper-spinner
  google-red-500: '#db4437'
  google-blue-500: '#4285f4'
  google-green-500: '#0f9d58'
  google-yellow-500: '#f4b400'
  paper-spinner-color: 'var(--primary-color)'
# for paper-slider
  paper-green-400: '#66bb6a'
  paper-blue-400: '#42a5f5'
  paper-orange-400: '#ffa726'
  dark-divider-opacity: '0.12'
  light-divider-opacity: '0.12'
  paper-slider-knob-color: 'var(--slider-color)'
  paper-slider-knob-start-color: 'var(--slider-color)'
  paper-slider-pin-color: 'var(--slider-color)'
  paper-slider-active-color: 'var(--slider-color)'
  paper-slider-secondary-color: 'var(--slider-secondary-color)'
  paper-slider-container-color: 'var(--slider-bar-color)'
  ha-paper-slider-pin-font-size: '55px'
  data-table-background-color: 'var(--card-background-color)'
# rgb
# mwc
# mwc text styles
Quite a lot of useful info can be found here:
Is this yours? If not, could you point me to the source? Thanks!
Sorry dont know where i got this… Somewhere on the net…
Thanks, that has a lot of them. This will be helpful.
Thanks, I will be giving that a look.
I regex-ed this list out of html output. I’m sure they will change over time.
--accent-color
--app-header-background-color
--app-header-text-color
--app-toolbar-font-size
--chip-background-color
--dark-disabled-opacity
--dark-divider-opacity
--dark-primary-color
--dark-primary-opacity
--dark-secondary-opacity
--dark-theme-base-color
--data-table-background-color
--divider-color
--energy-battery-in-color
--energy-battery-out-color
--energy-gas-color
--energy-grid-consumption-color
--energy-grid-return-color
--energy-non-fossil-color
--energy-solar-color
--error-color
--error-state-color
--ha-card-border-radius
--ha-card-header-font-size
--header-height
--info-color
--input-disabled-fill-color
--input-disabled-ink-color
--input-disabled-line-color
--input-dropdown-icon-color
--input-fill-color
--input-hover-line-color
--input-idle-line-color
--input-ink-color
--input-label-ink-color
--input-outlined-disabled-border-color
--input-outlined-hover-border-color
--input-outlined-idle-border-color
--label-badge-background-color
--label-badge-blue
--label-badge-green
--label-badge-grey
--label-badge-red
--label-badge-text-color
--label-badge-yellow
--layout_-_display
--layout-around-aligned_-_align-content
--layout-around-aligned_-_-ms-align-content
--layout-around-aligned_-_-ms-flex-line-pack
--layout-around-aligned_-_-webkit-align-content
--layout-around-justified_-_justify-content
--layout-around-justified_-_-ms-flex-pack
--layout-around-justified_-_-webkit-justify-content
--layout-baseline_-_align-items
--layout-baseline_-_-ms-flex-align
--layout-baseline_-_-webkit-align-items
--layout-between-aligned_-_align-content
--layout-between-aligned_-_-ms-align-content
--layout-between-aligned_-_-ms-flex-line-pack
--layout-between-aligned_-_-webkit-align-content
--layout-block_-_display
--layout-center_-_align-items
--layout-center_-_-ms-flex-align
--layout-center_-_-webkit-align-items
--layout-center-aligned_-_align-content
--layout-center-aligned_-_-ms-align-content
--layout-center-aligned_-_-ms-flex-line-pack
--layout-center-aligned_-_-webkit-align-content
--layout-center-center_-_align-items
--layout-center-center_-_justify-content
--layout-center-center_-_-ms-flex-align
--layout-center-center_-_-ms-flex-pack
--layout-center-center_-_-webkit-align-items
--layout-center-center_-_-webkit-justify-content
--layout-center-justified_-_justify-content
--layout-center-justified_-_-ms-flex-pack
--layout-center-justified_-_-webkit-justify-content
--layout-end_-_align-items
--layout-end_-_-ms-flex-align
--layout-end_-_-webkit-align-items
--layout-end-aligned_-_align-content
--layout-end-aligned_-_-ms-align-content
--layout-end-aligned_-_-ms-flex-line-pack
--layout-end-aligned_-_-webkit-align-content
--layout-end-justified_-_justify-content
--layout-end-justified_-_-ms-flex-pack
--layout-end-justified_-_-webkit-justify-content
--layout-fit
--layout-fit_-_bottom
--layout-fit_-_left
--layout-fit_-_position
--layout-fit_-_right
--layout-fit_-_top
--layout-fixed-bottom_-_bottom
--layout-fixed-bottom_-_left
--layout-fixed-bottom_-_position
--layout-fixed-bottom_-_right
--layout-fixed-left_-_bottom
--layout-fixed-left_-_left
--layout-fixed-left_-_position
--layout-fixed-left_-_top
--layout-fixed-right_-_bottom
--layout-fixed-right_-_position
--layout-fixed-right_-_right
--layout-fixed-right_-_top
--layout-fixed-top_-_left
--layout-fixed-top_-_position
--layout-fixed-top_-_right
--layout-fixed-top_-_top
--layout-flex_-_flex
--layout-flex_-_flex-basis
--layout-flex_-_-ms-flex
--layout-flex_-_-webkit-flex
--layout-flex_-_-webkit-flex-basis
--layout-flex-10_-_flex
--layout-flex-10_-_-ms-flex
--layout-flex-10_-_-webkit-flex
--layout-flex-11_-_flex
--layout-flex-11_-_-ms-flex
--layout-flex-11_-_-webkit-flex
--layout-flex-12_-_flex
--layout-flex-12_-_-ms-flex
--layout-flex-12_-_-webkit-flex
--layout-flex-2_-_flex
--layout-flex-2_-_-ms-flex
--layout-flex-2_-_-webkit-flex
--layout-flex-3_-_flex
--layout-flex-3_-_-ms-flex
--layout-flex-3_-_-webkit-flex
--layout-flex-4_-_flex
--layout-flex-4_-_-ms-flex
--layout-flex-4_-_-webkit-flex
--layout-flex-5_-_flex
--layout-flex-5_-_-ms-flex
--layout-flex-5_-_-webkit-flex
--layout-flex-6_-_flex
--layout-flex-6_-_-ms-flex
--layout-flex-6_-_-webkit-flex
--layout-flex-7_-_flex
--layout-flex-7_-_-ms-flex
--layout-flex-7_-_-webkit-flex
--layout-flex-8_-_flex
--layout-flex-8_-_-ms-flex
--layout-flex-8_-_-webkit-flex
--layout-flex-9_-_flex
--layout-flex-9_-_-ms-flex
--layout-flex-9_-_-webkit-flex
--layout-flex-auto_-_flex
--layout-flex-auto_-_-ms-flex
--layout-flex-auto_-_-webkit-flex
--layout-flex-none_-_flex
--layout-flex-none_-_-ms-flex
--layout-flex-none_-_-webkit-flex
--layout-fullbleed_-_height
--layout-fullbleed_-_margin
--layout-horizontal_-_display
--layout-horizontal_-_flex-direction
--layout-horizontal_-_-ms-flex-direction
--layout-horizontal_-_-webkit-flex-direction
--layout-horizontal-reverse_-_display
--layout-horizontal-reverse_-_flex-direction
--layout-horizontal-reverse_-_-ms-flex-direction
--layout-horizontal-reverse_-_-webkit-flex-direction
--layout-inline_-_display
--layout-invisible_-_visibility
--layout-justified_-_justify-content
--layout-justified_-_-ms-flex-pack
--layout-justified_-_-webkit-justify-content
--layout-relative_-_position
--layout-scroll_-_overflow
--layout-scroll_-_-webkit-overflow-scrolling
--layout-self-baseline_-_align-self
--layout-self-baseline_-_-ms-align-self
--layout-self-baseline_-_-webkit-align-self
--layout-self-center_-_align-self
--layout-self-center_-_-ms-align-self
--layout-self-center_-_-webkit-align-self
--layout-self-end_-_align-self
--layout-self-end_-_-ms-align-self
--layout-self-end_-_-webkit-align-self
--layout-self-start_-_align-self
--layout-self-start_-_-ms-align-self
--layout-self-start_-_-webkit-align-self
--layout-self-stretch_-_align-self
--layout-self-stretch_-_-ms-align-self
--layout-self-stretch_-_-webkit-align-self
--layout-start_-_align-items
--layout-start_-_-ms-flex-align
--layout-start_-_-webkit-align-items
--layout-start-aligned_-_align-content
--layout-start-aligned_-_-ms-align-content
--layout-start-aligned_-_-ms-flex-line-pack
--layout-start-aligned_-_-webkit-align-content
--layout-start-justified_-_justify-content
--layout-start-justified_-_-ms-flex-pack
--layout-start-justified_-_-webkit-justify-content
--layout-vertical_-_display
--layout-vertical_-_flex-direction
--layout-vertical_-_-ms-flex-direction
--layout-vertical_-_-webkit-flex-direction
--layout-vertical-reverse_-_display
--layout-vertical-reverse_-_flex-direction
--layout-vertical-reverse_-_-ms-flex-direction
--layout-vertical-reverse_-_-webkit-flex-direction
--layout-wrap_-_flex-wrap
--layout-wrap_-_-ms-flex-wrap
--layout-wrap_-_-webkit-flex-wrap
--layout-wrap-reverse_-_flex-wrap
--layout-wrap-reverse_-_-ms-flex-wrap
--layout-wrap-reverse_-_-webkit-flex-wrap
--light-disabled-opacity
--light-divider-opacity
--light-primary-opacity
--light-secondary-opacity
--light-theme-background-color
--light-theme-disabled-color
--light-theme-secondary-background-color
--light-theme-secondary-color
--light-theme-text-color
--markdown-code-background-color
--material-background-color
--material-body-text-color
--material-button-font-size
--material-caption-font-size
--material-disabled-color
--material-disabled-text-color
--material-divider-color
--material-error-color
--material-error-text-color
--material-h6-font-size
--material-primary-color
--material-primary-contrast-color
--material-primary-text-color
--material-secondary-background-color
--material-secondary-text-color
--material-shadow-elevation-12dp
--material-shadow-elevation-16dp
--material-shadow-elevation-24dp
--material-shadow-elevation-2dp
--material-shadow-elevation-3dp
--material-shadow-elevation-4dp
--material-shadow-elevation-6dp
--material-shadow-elevation-8dp
--material-small-font-size
--mdc-button-disabled-ink-color
--mdc-button-outline-color
--mdc-checkbox-disabled-color
--mdc-checkbox-unchecked-color
--mdc-dialog-scroll-divider-color
--mdc-radio-disabled-color
--mdc-radio-unchecked-color
--mdc-select-disabled-dropdown-icon-color
--mdc-select-disabled-fill-color
--mdc-select-disabled-ink-color
--mdc-select-dropdown-icon-color
--mdc-select-fill-color
--mdc-select-hover-line-color
--mdc-select-idle-line-color
--mdc-select-ink-color
--mdc-select-label-ink-color
--mdc-select-outlined-disabled-border-color
--mdc-select-outlined-hover-border-color
--mdc-select-outlined-idle-border-color
--mdc-tab-text-label-color-default
--mdc-text-field-disabled-fill-color
--mdc-text-field-disabled-ink-color
--mdc-text-field-disabled-line-color
--mdc-text-field-fill-color
--mdc-text-field-hover-line-color
--mdc-text-field-idle-line-color
--mdc-text-field-ink-color
--mdc-text-field-label-ink-color
--mdc-text-field-outlined-disabled-border-color
--mdc-text-field-outlined-hover-border-color
--mdc-text-field-outlined-idle-border-color
--mdc-theme-background
--mdc-theme-error
--mdc-theme-on-primary
--mdc-theme-on-secondary
--mdc-theme-on-surface
--mdc-theme-primary
--mdc-theme-secondary
--mdc-theme-surface
--mdc-theme-text-disabled-on-light
--mdc-theme-text-hint-on-background
--mdc-theme-text-icon-on-background
--mdc-theme-text-primary-on-background
--mdc-theme-text-secondary-on-background
--mini-media-player-overlay-color-stop
--paper-dropdown-menu
--paper-dropdown-menu-button
--paper-dropdown-menu-disabled
--paper-dropdown-menu-icon
--paper-dropdown-menu-input
--paper-dropdown-menu-ripple
--paper-font-body1_-_font-family
--paper-font-body1_-_font-size
--paper-font-body1_-_font-weight
--paper-font-body1_-_line-height
--paper-font-body1_-_-webkit-font-smoothing
--paper-font-body2_-_font-family
--paper-font-body2_-_font-size
--paper-font-body2_-_font-weight
--paper-font-body2_-_line-height
--paper-font-body2_-_-webkit-font-smoothing
--paper-font-button_-_font-family
--paper-font-button_-_font-size
--paper-font-button_-_font-weight
--paper-font-button_-_letter-spacing
--paper-font-button_-_line-height
--paper-font-button_-_overflow
--paper-font-button_-_text-overflow
--paper-font-button_-_text-transform
--paper-font-button_-_-webkit-font-smoothing
--paper-font-button_-_white-space
--paper-font-caption_-_font-family
--paper-font-caption_-_font-size
--paper-font-caption_-_font-weight
--paper-font-caption_-_letter-spacing
--paper-font-caption_-_line-height
--paper-font-caption_-_overflow
--paper-font-caption_-_text-overflow
--paper-font-caption_-_-webkit-font-smoothing
--paper-font-caption_-_white-space
--paper-font-code1_-_font-family
--paper-font-code1_-_font-size
--paper-font-code1_-_font-weight
--paper-font-code1_-_line-height
--paper-font-code1_-_-webkit-font-smoothing
--paper-font-code2_-_font-family
--paper-font-code2_-_font-size
--paper-font-code2_-_font-weight
--paper-font-code2_-_line-height
--paper-font-code2_-_-webkit-font-smoothing
--paper-font-common-base_-_font-family
--paper-font-common-base_-_-webkit-font-smoothing
--paper-font-common-code_-_font-family
--paper-font-common-code_-_-webkit-font-smoothing
--paper-font-common-expensive-kerning_-_text-rendering
--paper-font-common-nowrap_-_overflow
--paper-font-common-nowrap_-_text-overflow
--paper-font-common-nowrap_-_white-space
--paper-font-display1_-_font-family
--paper-font-display1_-_font-size
--paper-font-display1_-_font-weight
--paper-font-display1_-_letter-spacing
--paper-font-display1_-_line-height
--paper-font-display1_-_-webkit-font-smoothing
--paper-font-display2_-_font-family
--paper-font-display2_-_font-size
--paper-font-display2_-_font-weight
--paper-font-display2_-_letter-spacing
--paper-font-display2_-_line-height
--paper-font-display2_-_-webkit-font-smoothing
--paper-font-display3_-_font-family
--paper-font-display3_-_font-size
--paper-font-display3_-_font-weight
--paper-font-display3_-_letter-spacing
--paper-font-display3_-_line-height
--paper-font-display3_-_overflow
--paper-font-display3_-_text-overflow
--paper-font-display3_-_-webkit-font-smoothing
--paper-font-display3_-_white-space
--paper-font-display4_-_font-family
--paper-font-display4_-_font-size
--paper-font-display4_-_font-weight
--paper-font-display4_-_letter-spacing
--paper-font-display4_-_line-height
--paper-font-display4_-_overflow
--paper-font-display4_-_text-overflow
--paper-font-display4_-_-webkit-font-smoothing
--paper-font-display4_-_white-space
--paper-font-headline_-_font-family
--paper-font-headline_-_font-size
--paper-font-headline_-_font-weight
--paper-font-headline_-_letter-spacing
--paper-font-headline_-_line-height
--paper-font-headline_-_overflow
--paper-font-headline_-_text-overflow
--paper-font-headline_-_-webkit-font-smoothing
--paper-font-headline_-_white-space
--paper-font-menu_-_font-family
--paper-font-menu_-_font-size
--paper-font-menu_-_font-weight
--paper-font-menu_-_line-height
--paper-font-menu_-_overflow
--paper-font-menu_-_text-overflow
--paper-font-menu_-_-webkit-font-smoothing
--paper-font-menu_-_white-space
--paper-font-subhead
--paper-font-subhead_-_font-family
--paper-font-subhead_-_font-size
--paper-font-subhead_-_font-weight
--paper-font-subhead_-_line-height
--paper-font-subhead_-_overflow
--paper-font-subhead_-_text-overflow
--paper-font-subhead_-_-webkit-font-smoothing
--paper-font-subhead_-_white-space
--paper-font-title_-_font-family
--paper-font-title_-_font-size
--paper-font-title_-_font-weight
--paper-font-title_-_line-height
--paper-font-title_-_overflow
--paper-font-title_-_text-overflow
--paper-font-title_-_-webkit-font-smoothing
--paper-font-title_-_white-space
--paper-input-container-input
--paper-input-container-input_-_font-size
--paper-input-container-input-align
--paper-input-container-input-color
--paper-input-container-shared-input-style_-_background
--paper-input-container-shared-input-style_-_border
--paper-input-container-shared-input-style_-_box-shadow
--paper-input-container-shared-input-style_-_color
--paper-input-container-shared-input-style_-_font-family
--paper-input-container-shared-input-style_-_font-size
--paper-input-container-shared-input-style_-_font-weight
--paper-input-container-shared-input-style_-_line-height
--paper-input-container-shared-input-style_-_margin
--paper-input-container-shared-input-style_-_max-width
--paper-input-container-shared-input-style_-_outline
--paper-input-container-shared-input-style_-_padding
--paper-input-container-shared-input-style_-_position
--paper-input-container-shared-input-style_-_text-align
--paper-input-container-shared-input-style_-_vertical-align
--paper-input-container-shared-input-style_-_-webkit-appearance
--paper-input-container-shared-input-style_-_-webkit-font-smoothing
--paper-input-container-shared-input-style_-_width
--paper-item-disabled
--paper-item-disabled-color
--paper-item-focused
--paper-item-focused-before
--paper-item-icon-active-color
--paper-item-icon-color
--paper-item-min-height
--paper-item-selected
--paper-item-selected-weight
--paper-slider-active-color
--paper-slider-container-color
--paper-slider-knob-color
--paper-slider-knob-start-color
--paper-slider-pin-color
--paper-slider-pin-start-color
--paper-slider-secondary-color
--primary-color
--rgb-accent-color
--rgb-card-background-color
--rgb-primary-color
--rgb-primary-text-color
--rgb-secondary-text-color
--rgb-text-primary-color
--scrollbar-thumb-color
--secondary-background-color
--shadow-elevation-12dp_-_box-shadow
--shadow-elevation-16dp_-_box-shadow
--shadow-elevation-24dp_-_box-shadow
--shadow-elevation-2dp_-_box-shadow
--shadow-elevation-3dp_-_box-shadow
--shadow-elevation-4dp_-_box-shadow
--shadow-elevation-6dp_-_box-shadow
--shadow-elevation-8dp_-_box-shadow
--shadow-none_-_box-shadow
--shadow-transition_-_transition
--sidebar-background-color
--sidebar-selected-icon-color
--sidebar-selected-text-color
--sidebar-text-color
--slider-color
--slider-track-color
--state-climate-auto-color
--state-climate-cool-color
--state-climate-dry-color
--state-climate-eco-color
--state-climate-fan_only-color
--state-climate-heat-color
--state-climate-idle-color
--state-climate-manual-color
--state-climate-off-color
--state-home-color
--state-icon-active-color
--state-icon-color
--state-icon-error-color
--state-icon-unavailable-color
--state-idle-color
--state-not_home-color
--state-off-color
--state-on-color
--state-unavailable-color
--state-unknown-color
--success-color
--switch-checked-button-color
--switch-checked-track-color
--switch-unchecked-button-color
--switch-unchecked-track-color
--table-row-alternative-background-color
--table-row-background-color
--text-light-primary-color
--warning-color
Might be much better if they just let you deliver a custom css file where you can override base-styles that gets injected for official theming (not that you can already do that by adding a custom resource) … instead of this weird yaml mapping to css-vars that’s lacking options left and right.
Maybe point is with a “Default View”, is that you are able to “reverse” to Default, if you fu your CSS
A Theme is just a long list off CSS, you don’t have to use “weird” mapping, if you don’t see the point in that, so your " Custom CSS file " is exactly a " Theme ", which you place in a Folder and get access to it, in your views and cards ( and you can have several Themes / CSS-files , … you can also choose to place your "Theme/CSS(style definitions) in top of the (Official Theming) … So i think you just don’t know what you want and what you “Have” , because you have exactly what you want … not 1, but 2 options (actually 3, in cards) where you can “deliver your own CUSTOM css” and overwrite base-style … And again, if you have “problems” with your “personal” css escapades, you can’t blame other than your-self, but luckily you have an “untouched” Default Theme
2025 update now that alot of it has basically been re-written / replaced?
I pulled what I could from the front end code after the changes to get my own ui in order. I haven’t tested them all but all the one’s I’ve needed for my own use have worked. The values listed here should be the default values but no promises.
hass_default:
  ha-font-family-body: Roboto, Noto, sans-serif
  ha-font-family-code: monospace
  ha-font-family-longform: ui-sans-serif, system-ui, sans-serif
  font-size: 14px
  ha-font-size-scale: 1
  ha-font-size-xs: calc(10px * var(--ha-font-size-scale))  # 0.714286rem
  ha-font-size-s: calc(12px * var(--ha-font-size-scale))  # 0.857143rem
  ha-font-size-m: calc(14px * var(--ha-font-size-scale))  # 1rem
  ha-font-size-l: calc(16px * var(--ha-font-size-scale))  # 1.142857rem
  ha-font-size-xl: calc(20px * var(--ha-font-size-scale))  # 1.428571rem
  ha-font-size-2xl: calc(24px * var(--ha-font-size-scale))  # 1.714286rem
  ha-font-size-3xl: calc(28px * var(--ha-font-size-scale))  # 2rem
  ha-font-size-4xl: calc(32px * var(--ha-font-size-scale))  # 2.285714rem
  ha-font-size-5xl: calc(40px * var(--ha-font-size-scale))  # 2.857143rem
  ha-font-weight-light: 300
  ha-font-weight-normal: 400
  ha-font-weight-medium: 500
  ha-font-weight-bold: 700
  ha-font-family-heading: var(--ha-font-family-body)
  ha-font-weight-body: var(--ha-font-weight-normal)
  ha-font-weight-heading: var(--ha-font-weight-bold)
  ha-font-weight-action: var(--ha-font-weight-medium)
  ha-line-height-condensed: 1.2
  ha-line-height-normal: 1.6
  ha-line-height-expanded: 2
  ha-font-smoothing: antialiased
  ha-moz-osx-font-smoothing: grayscale
  #Vaadin typography
  material-h6-font-size: var(--ha-font-size-m)
  material-small-font-size: var(--ha-font-size-xs)
  material-caption-font-size: var(--ha-font-size-2xs)
  material-button-font-size: var(--ha-font-size-xs)
  #for header
  header-height: 56px
  #opacity for dark text on a light background
  dark-divider-opacity: 0.12
  dark-disabled-opacity: 0.38  # or hint text or icon
  dark-secondary-opacity: 0.54
  dark-primary-opacity: 0.87
  #opacity for light text on a dark background
  light-divider-opacity: 0.12
  light-disabled-opacity: 0.3  # or hint text or icon
  light-secondary-opacity: 0.7
  light-primary-opacity: 1
  direction: ltr
  float-start: left
  float-end: right
  margin-title-ltr: 0 0 0 24px
  margin-title-rtl: 0 24px 0 0
  primary-text-color: "#212121"
  secondary-text-color: "#727272"
  text-primary-color: "#ffffff"
  text-light-primary-color: "#212121"
  disabled-text-color: "#bdbdbd"
  # main interface colors
  primary-color: "#03a9f4"
  dark-primary-color: "#0288d1"
  light-primary-color: "#b3e5fc"
  accent-color: "#ff9800"
  divider-color: rgba(0, 0, 0, 0.12)
  outline-color: rgba(0, 0, 0, 0.12)
  outline-hover-color: rgba(0, 0, 0, 0.24)
  # rgb
  rgb-primary-color: 3, 169, 244
  rgb-accent-color: 255, 152, 0
  rgb-primary-text-color: 33, 33, 33
  rgb-secondary-text-color: 114, 114, 114
  rgb-text-primary-color: 255, 255, 255
  rgb-card-background-color: 255, 255, 255
  scrollbar-thumb-color: rgb(194, 194, 194)
  error-color: "#db4437"
  warning-color: "#ffa600"
  success-color: "#43a047"
  info-color: "#039be5"
  # backgrounds
  card-background-color: "#ffffff"
  primary-background-color: "#fafafa"
  secondary-background-color: "#e5e5e5" # behind the cards on state
  clear-background-color: "#ffffff"
  # for label-badge
  label-badge-grey: "#9e9e9e"
  # states icon
  state-icon-color: "#44739e"
  # an error state is anything that would be considered an error
  # state-icon-error-color: "#db4437" # derived from error-color
  # energy
  energy-grid-consumption-color: "#488fc2"
  energy-grid-return-color: "#8353d1"
  energy-solar-color: "#ff9800"
  energy-non-fossil-color: "#0f9d58"
  energy-battery-out-color: "#4db6ac"
  energy-battery-in-color: "#f06292"
  energy-gas-color: "#8e021b"
  energy-water-color: "#00bcd4"
  # color
  disabled-color: "#bdbdbd"
  red-color: "#f44336"
  pink-color: "#e91e63"
  purple-color: "#926bc7"
  deep-purple-color: "#6e41ab"
  indigo-color: "#3f51b5"
  blue-color: "#2196f3"
  light-blue-color: "#03a9f4"
  cyan-color: "#00bcd4"
  teal-color: "#009688"
  green-color: "#4caf50"
  light-green-color: "#8bc34a"
  lime-color: "#cddc39"
  yellow-color: "#ffeb3b"
  amber-color: "#ffc107"
  orange-color: "#ff9800"
  deep-orange-color: "#ff6f22"
  brown-color: "#795548"
  light-grey-color: "#bdbdbd"
  grey-color: "#9e9e9e"
  dark-grey-color: "#606060"
  blue-grey-color: "#607d8b"
  black-color: "#000000"
  white-color: "#ffffff"
  # history colors
  history-unavailable-color: transparent
  # input components
  input-idle-line-color: rgba(0, 0, 0, 0.42)
  input-hover-line-color: rgba(0, 0, 0, 0.87)
  input-disabled-line-color: rgba(0, 0, 0, 0.06)
  input-outlined-idle-border-color: rgba(0, 0, 0, 0.38)
  input-outlined-hover-border-color: rgba(0, 0, 0, 0.87)
  input-outlined-disabled-border-color: rgba(0, 0, 0, 0.06)
  input-fill-color: rgb(245, 245, 245)
  input-disabled-fill-color: rgb(250, 250, 250)
  input-ink-color: rgba(0, 0, 0, 0.87)
  input-label-ink-color: rgba(0, 0, 0, 0.6)
  input-disabled-ink-color: rgba(0, 0, 0, 0.37)
  input-dropdown-icon-color: rgba(0, 0, 0, 0.54)
  # for label-badge
  label-badge-red: var(--error-color)
  label-badge-blue: var(--info-color)
  label-badge-green: var(--success-color)
  label-badge-yellow: var(--warning-color)
  # state color
  state-active-color: var(--amber-color)
  state-inactive-color: var(--grey-color)
  state-unavailable-color: var(--state-icon-unavailable-color, var(--disabled-text-color))
  # state domain colors
  state-alarm_control_panel-armed_away-color: var(--green-color)
  state-alarm_control_panel-armed_custom_bypass-color: var(--green-color)
  state-alarm_control_panel-armed_home-color: var(--green-color)
  state-alarm_control_panel-armed_night-color: var(--green-color)
  state-alarm_control_panel-armed_vacation-color: var(--green-color)
  state-alarm_control_panel-arming-color: var(--orange-color)
  state-alarm_control_panel-disarming-color: var(--orange-color)
  state-alarm_control_panel-pending-color: var(--orange-color)
  state-alarm_control_panel-triggered-color: var(--red-color)
  state-alert-off-color: var(--orange-color)
  state-alert-on-color: var(--red-color)
  state-binary_sensor-active-color: var(--amber-color)
  state-binary_sensor-battery-on-color: var(--red-color)
  state-binary_sensor-carbon_monoxide-on-color: var(--red-color)
  state-binary_sensor-gas-on-color: var(--red-color)
  state-binary_sensor-heat-on-color: var(--red-color)
  state-binary_sensor-lock-on-color: var(--red-color)
  state-binary_sensor-moisture-on-color: var(--red-color)
  state-binary_sensor-problem-on-color: var(--red-color)
  state-binary_sensor-safety-on-color: var(--red-color)
  state-binary_sensor-smoke-on-color: var(--red-color)
  state-binary_sensor-sound-on-color: var(--red-color)
  state-binary_sensor-tamper-on-color: var(--red-color)
  state-climate-auto-color: var(--green-color)
  state-climate-cool-color: var(--blue-color)
  state-climate-dry-color: var(--orange-color)
  state-climate-fan_only-color: var(--cyan-color)
  state-climate-heat-color: var(--deep-orange-color)
  state-climate-heat-cool-color: var(--amber-color)
  state-cover-active-color: var(--purple-color)
  state-device_tracker-active-color: var(--blue-color)
  state-device_tracker-home-color: var(--green-color)
  state-fan-active-color: var(--cyan-color)
  state-humidifier-on-color: var(--blue-color)
  state-lawn_mower-error-color: var(--red-color)
  state-lawn_mower-mowing-color: var(--teal-color)
  state-light-active-color: var(--amber-color)
  state-lock-jammed-color: var(--red-color)
  state-lock-locked-color: var(--green-color)
  state-lock-locking-color: var(--orange-color)
  state-lock-unlocked-color: var(--red-color)
  state-lock-unlocking-color: var(--orange-color)
  state-lock-open-color: var(--red-color)
  state-lock-opening-color: var(--orange-color)
  state-media_player-active-color: var(--light-blue-color)
  state-person-active-color: var(--blue-color)
  state-person-home-color: var(--green-color)
  state-plant-active-color: var(--red-color)
  state-siren-active-color: var(--red-color)
  state-sun-above_horizon-color: var(--amber-color)
  state-sun-below_horizon-color: var(--indigo-color)
  state-switch-active-color: var(--amber-color)
  state-update-active-color: var(--orange-color)
  state-vacuum-active-color: var(--teal-color)
  state-valve-active-color: var(--blue-color)
  state-sensor-battery-high-color: var(--green-color)
  state-sensor-battery-low-color: var(--red-color)
  state-sensor-battery-medium-color: var(--orange-color)
  state-water_heater-eco-color: var(--green-color)
  state-water_heater-electric-color: var(--orange-color)
  state-water_heater-gas-color: var(--orange-color)
  state-water_heater-heat_pump-color: var(--orange-color)
  state-water_heater-high_demand-color: var(--deep-orange-color)
  state-water_heater-performance-color: var(--deep-orange-color)
  # history colors
  history-unknown-color: var(--dark-grey-color)
  state-icon-error-color: var(--error-state-color, var(--error-color))
  sidebar-text-color: var(--primary-text-color)
  sidebar-background-color: var(--card-background-color)
  sidebar-selected-text-color: var(--primary-color)
  sidebar-selected-icon-color: var(--primary-color)
  sidebar-icon-color: rgba(var(--rgb-primary-text-color), 0.6)
  switch-checked-color: var(--primary-color)
  switch-checked-button-color: var(--switch-checked-color, var(--primary-background-color))
  switch-checked-track-color: var(--switch-checked-color, "#000000")
  switch-unchecked-button-color: var(--switch-unchecked-color, var(--primary-background-color))
  switch-unchecked-track-color: var(--switch-unchecked-color, "#000000")
  slider-color: var(--primary-color)
  slider-secondary-color: var(--light-primary-color)
  slider-track-color: var(--scrollbar-thumb-color)
  label-badge-background-color: var(--card-background-color)
  label-badge-text-color: rgba(var(--rgb-primary-text-color), 0.8)
  table-header-background-color: var(--input-fill-color)
  table-row-background-color: var(--primary-background-color)
  table-row-alternative-background-color: var(--secondary-background-color)
  data-table-background-color: var(--card-background-color)
  markdown-code-background-color: var(--primary-background-color)
  mdc-theme-primary: var(--primary-color)
  mdc-theme-secondary: var(--accent-color)
  mdc-theme-background: var(--primary-background-color)
  mdc-theme-surface: var(--card-background-color)
  mdc-theme-on-primary: var(--text-primary-color)
  mdc-theme-on-secondary: var(--text-primary-color)
  mdc-theme-on-surface: var(--primary-text-color)
  mdc-theme-text-disabled-on-light: var(--disabled-text-color)
  mdc-theme-text-primary-on-background: var(--primary-text-color)
  mdc-theme-text-secondary-on-background: var(--secondary-text-color)
  mdc-theme-text-hint-on-background: var(--secondary-text-color)
  mdc-theme-text-icon-on-background: var(--secondary-text-color)
  mdc-theme-error: var(--error-color)
  app-header-text-color: var(--text-primary-color)
  app-header-background-color: var(--primary-color)
  app-theme-color: var(--app-header-background-color)
  mdc-checkbox-unchecked-color: rgba(var(--rgb-primary-text-color), 0.54)
  mdc-checkbox-disabled-color: var(--disabled-text-color)
  mdc-radio-unchecked-color: rgba(var(--rgb-primary-text-color), 0.54)
  mdc-radio-disabled-color: var(--disabled-text-color)
  mdc-tab-text-label-color-default: var(--primary-text-color)
  mdc-button-disabled-ink-color: var(--disabled-text-color)
  mdc-button-outline-color: var(--outline-color)
  mdc-dialog-scroll-divider-color: var(--divider-color)
  mdc-dialog-heading-ink-color: var(--primary-text-color)
  mdc-dialog-content-ink-color: var(--primary-text-color)
  mdc-text-field-idle-line-color: var(--input-idle-line-color)
  mdc-text-field-hover-line-color: var(--input-hover-line-color)
  mdc-text-field-disabled-line-color: var(--input-disabled-line-color)
  mdc-text-field-outlined-idle-border-color: var(--input-outlined-idle-border-color)
  mdc-text-field-outlined-hover-border-color: var(--input-outlined-hover-border-color)
  mdc-text-field-outlined-disabled-border-color: var(--input-outlined-disabled-border-color)
  mdc-text-field-fill-color: var(--input-fill-color)
  mdc-text-field-disabled-fill-color: var(--input-disabled-fill-color)
  mdc-text-field-ink-color: var(--input-ink-color)
  mdc-text-field-label-ink-color: var(--input-label-ink-color)
  mdc-text-field-disabled-ink-color: var(--input-disabled-ink-color)
  mdc-select-idle-line-color: var(--input-idle-line-color)
  mdc-select-hover-line-color: var(--input-hover-line-color)
  mdc-select-outlined-idle-border-color: var(--input-outlined-idle-border-color)
  mdc-select-outlined-hover-border-color: var(--input-outlined-hover-border-color)
  mdc-select-outlined-disabled-border-color: var(--input-outlined-disabled-border-color)
  mdc-select-fill-color: var(--input-fill-color)
  mdc-select-disabled-fill-color: var(--input-disabled-fill-color)
  mdc-select-ink-color: var(--input-ink-color)
  mdc-select-label-ink-color: var(--input-label-ink-color)
  mdc-select-disabled-ink-color: var(--input-disabled-ink-color)
  mdc-select-dropdown-icon-color: var(--input-dropdown-icon-color)
  mdc-select-disabled-dropdown-icon-color: var(--input-disabled-ink-color)
  ha-assist-chip-filled-container-color: rgba(var(--rgb-primary-text-color), 0.15)
  ha-assist-chip-active-container-color: rgba(var(--rgb-primary-color), 0.15)
  chip-background-color: rgba(var(--rgb-primary-text-color), 0.15)
  # Vaadin
  material-body-text-color: var(--primary-text-color)
  material-background-color: var(--card-background-color)
  material-secondary-background-color: var(--secondary-background-color)
  material-secondary-text-color: var(--secondary-text-color)
  modes:
    dark:
      primary-background-color: "#111111"
      card-background-color: "#1c1c1c"
      secondary-background-color: "#282828"
      clear-background-color: "#111111"
      primary-text-color: "#e1e1e1"
      secondary-text-color: "#9b9b9b"
      disabled-text-color: "#6f6f6f"
      app-header-text-color: "#e1e1e1"
      app-header-background-color: "#101e24"
      switch-unchecked-button-color: "#999999"
      switch-unchecked-track-color: "#9b9b9b"
      divider-color: rgba(225, 225, 225, 0.12)
      outline-color: rgba(225, 225, 225, 0.12)
      outline-hover-color: rgba(225, 225, 225, 0.24)
      mdc-ripple-color: "#aaaaaa"
      mdc-linear-progress-buffer-color: rgba(255, 255, 255, 0.1)
      input-idle-line-color: rgba(255, 255, 255, 0.42)
      input-hover-line-color: rgba(255, 255, 255, 0.87)
      input-disabled-line-color: rgba(255, 255, 255, 0.06)
      input-outlined-idle-border-color: rgba(255, 255, 255, 0.38)
      input-outlined-hover-border-color: rgba(255, 255, 255, 0.87)
      input-outlined-disabled-border-color: rgba(255, 255, 255, 0.06)
      input-fill-color: rgba(255, 255, 255, 0.05)
      input-disabled-fill-color: rgba(255, 255, 255, 0.02)
      input-ink-color: rgba(255, 255, 255, 0.87)
      input-label-ink-color: rgba(255, 255, 255, 0.6)
      input-disabled-ink-color: rgba(255, 255, 255, 0.37)
      input-dropdown-icon-color: rgba(255, 255, 255, 0.54)
      codemirror-keyword: "#c792ea"
      codemirror-operator: "#89ddff"
      codemirror-variable: "#f07178"
      codemirror-variable-2: "#eeffff"
      codemirror-variable-3: "#decb6b"
      codemirror-builtin: "#ffcb6b"
      codemirror-atom: "#f78c6c"
      codemirror-number: "#ff5370"
      codemirror-def: "#82aaff"
      codemirror-string: "#c3e88d"
      codemirror-string-2: "#f07178"
      codemirror-comment: "#545454"
      codemirror-tag: "#ff5370"
      codemirror-meta: "#ffcb6b"
      codemirror-attribute: "#c792ea"
      codemirror-property: "#c792ea"
      codemirror-qualifier: "#decb6b"
      codemirror-type: "#decb6b"
      energy-grid-return-color: "#a280db"
      map-filter: invert(0.9) hue-rotate(170deg) brightness(1.5) contrast(1.2) saturate(0.3)
      disabled-color: "#464646"
There’s also these for history and energy graphs.
These are not default values.
  energy-grid-consumption-color-0: var(--green-color)
  energy-grid-consumption-color-1: var(--yellow-color)
  energy-grid-consumption-color-2: var(--red-color)
  energy-grid-consumption-color-3: var(--orange-color)
  energy-grid-consumption-color-4: var(--cyan-color)
  energy-grid-consumption-color-5: var(--purple-color)
  graph-color-1: var(--primary-color)
  graph-color-2: var(--green-color)
  graph-color-3: var(--red-color)
  graph-color-4: var(--orange-color)
  graph-color-5: var(--cyan-color)
  graph-color-6: var(--purple-color)
  graph-color-7: var(--teal-color)
  graph-color-8: var(--amber-color)
  graph-color-9: var(--light-green-color)
  graph-color-10: var(--pink-color)
ha-tab-padding-start: 14px
ha-tab-padding-end: 14px
Newly added in 2025.7
