Fullscreen calendar in lovelace with multuple events on same day?
I have asked before, and I have searched for a solution for since I started with HA many years ago.
(my last post)
Short question, has a way been developed to display such a fullscreen calendar in lovelace? without the checkbox menu on the left?
Hi, did you find any solution? I’m looking exactly for this.
Thanks.
What about the calendar card in a ‘Panel (1 card)’ view with header and side menu hidden someway (kiosk, browser_mod)
Thanks for the reply. I have tried, but the calendar does not reach the bottom of the screen even if I set the “height” attribute to 100%, it does not resize the cells of the monthly view to take advantage of the space.
I am looking for same solution.
Looking for the same thing. In fact i only run DAK board in an Iframe because of that calendar issue. I once tried with atomic calendar cards stacking them up and showing only one day, styling the whole thing but at some point I ran a core update and the whole thing was gone.
3 years later, still hoping for a solution ^^
DAK Board only support one calendar added (free plan)
Looking for the same thing…
Not exactly right, but found this one that looks promising (not tested):
Seems a good option and is being maintained!
For me it not working, not able to add into HACS custom repositories.
I have installed HACS 2.0 maybe this is an issue? Any idea how to fix?
Get error:
Repository structure for v1.7.1 is not compliant.
It’s unlikely: check this Issue Installing via HACS · Issue #95 · FamousWolf/week-planner-card · GitHub
In this issue referring to the Lovelace, but there no option in dropdown
Oh, sorry “Dashboard” is working
Same issue for me. Cant get the calendar (card version or tab on left menu) to use the whole tablet screen for maximum visibility from afar
