Fully disable Wemo discovery
I have a combination of legit Belkin Wemo switches and Sonoff devices running Espurna. The Espurna devices have the Alexa integration component enabled, so they pop in Home Assistant as Wemo devices.
They don’t work in hass as Wemo devices, so I have them set up as MQTT switches. I have the actual Wemo switched set up with static IP addresses and listed in a wemo.yaml file. I have discovery turned off.
The problem is that Wemo discovery stays on even when discovery in general is turned off. The result is a log file cluttered with stuff about reaching out to my Espurna devices as Wemo’s and not getting the predicted responses.
It would be great if the Wemo component could work natively with the Espurna devices or (more simply) if there was an option to use the Wemo component, but with the discovery element completely disabled.
Thanks. Home Assistant is great.
