Hi Charles,
I am trying to get this set up with the configuration below but I get unexpected error when I enter my IP and remote password (port 2323). I have copied the log below my config.I have tried 3 separate installations from HACs and got the same result. I can connect remotely through any remote device with the same IP and password via a url so connection is there. Any advice gratefully received.
Thanks,
Johnny
Configuration:
VM HASS
Home Assistant OS core-2022.7.0b2
Home Assistant OS 8.2
Fully Kiosk Browser 1.48
Fully Kiosk Browser integration for Home Assistant 1.1.0
Logs:
This error originated from a custom integration.
Logger: custom_components.fullykiosk.config_flow
Source: custom_components/fullykiosk/config_flow.py:49
Integration: Fully Kiosk Browser (documentation, issues)
First occurred: 19:13:48 (1 occurrences)
Last logged: 19:13:48
Unexpected exception
File "/config/custom_components/fullykiosk/config_flow.py", line 50, in validate_input
deviceInfo = await fully.getDeviceInfo()
File "/usr/local/lib/python3.10/site-packages/fullykiosk/__init__.py", line 30, in getDeviceInfo
result = await self.sendCommand("deviceInfo")
File "/usr/local/lib/python3.10/site-packages/fullykiosk/__init__.py", line 22, in sendCommand
data = await self._rh.get(
File "/usr/local/lib/python3.10/site-packages/fullykiosk/__init__.py", line 139, in get
async with self.session.get(
File "/usr/local/lib/python3.10/site-packages/aiohttp/client.py", line 1138, in __aenter__
self._resp = await self._coro
File "/usr/local/lib/python3.10/site-packages/aiohttp/client.py", line 535, in _request
conn = await self._connector.connect(
File "/usr/local/lib/python3.10/site-packages/aiohttp/connector.py", line 542, in connect
proto = await self._create_connection(req, traces, timeout)
File "/usr/local/lib/python3.10/site-packages/aiohttp/connector.py", line 907, in _create_connection
_, proto = await self._create_direct_connection(req, traces, timeout)
File "/usr/local/lib/python3.10/site-packages/aiohttp/connector.py", line 1175, in _create_direct_connection
transp, proto = await self._wrap_create_connection(
File "/usr/local/lib/python3.10/site-packages/aiohttp/connector.py", line 986, in _wrap_create_connection
return await self._loop.create_connection(*args, **kwargs) # type: ignore[return-value] # noqa
File "/usr/local/lib/python3.10/asyncio/base_events.py", line 1049, in create_connection
sock = await self._connect_sock(
File "/usr/local/lib/python3.10/asyncio/base_events.py", line 960, in _connect_sock
await self.sock_connect(sock, address)
File "/usr/local/lib/python3.10/asyncio/selector_events.py", line 500, in sock_connect
return await fut
asyncio.exceptions.CancelledError
File "/config/custom_components/fullykiosk/config_flow.py", line 80, in async_step_user
info = await validate_input(self.hass, user_input)
File "/config/custom_components/fullykiosk/config_flow.py", line 49, in validate_input
with timeout(15):
File "/usr/local/lib/python3.10/site-packages/async_timeout/__init__.py", line 116, in __exit__
self._do_exit(exc_type)
File "/usr/local/lib/python3.10/site-packages/async_timeout/__init__.py", line 212, in _do_exit
raise asyncio.TimeoutError
asyncio.exceptions.TimeoutError
