Fully kiosk browser now integrated / get rid of hacs version?
Does anyone know if the default integration for fully kiosk is the same code base as what was brought in with hacs? Do we remove the hacs one now?
I found this thread which has a little info: 2022.9: Home Assistant Birthday Release! - #82 by cgarwood
The core component was born from the codebase of the custom component in HACS, but had a number of changes to bring it up to modern HA standards. The biggest thing it’s missing from the HACS component is the load_url start_application and set_config_parameter services - I ran out of time to get those PR’d before the 2022.9 release.
just curious if play_video() with the various params will be added? i use it using an api call with the params loop=false, end_on_touch=true ect.
ive been using the hacs version for a while and love it :slight_smile:
