Fully Kiosk Browser now supports MQTT
Fully Kiosk doesn’t implement HA’s autodiscovery so you have to configure it in HA yourself.
I use the following to make a simple battery sensor and put the full device info in the sensor’s attributes. Just replace <mqtt_topic> with the topic you configured in Fully Kiosk Browser.
  - platform: mqtt
    state_topic: "<mqtt_topic>/device_info"
    unit_of_measurement: "%"
    value_template: "{{ value_json.batteryLevel | int }}"
    json_attributes_topic: "<mqtt_topic>/device_info"
    device_class: battery
Another option is to use the HACS integration instead of MQTT, it is quite powerful.
:open_mouth: Thank you!
Trying to work out if it is possible to create a binary sensor which is true when fully detects motion. I looked here but the MQTT integration has changed so the YAML here no longer works: Fully Kiosk Browser ScreenOn ScreenOff binary sensor
As I am using motion detection on the tablet to set the screen brightness I thought maybe I could indirectly use that to work out when motion is detected. So I tried this which pulls all the JSON into the sensor attributes but the state stays as UNKNOWN. Can anyone help with showing how I can have a sensor which goes true for a short period if motion is detected?
    - name: tablet_motion_detected
      state_topic: "fully/event/onMotion/3571d082-16ee5c32"
      payload_available: visual
      force_update: true
      json_attributes_topic: "fully/deviceInfo/3571d082-16ee5c32"
      value_template: "{% if value_json.screenBrightness > 100 %}
                         true
                       {% else %}
                         false
                       {% endif %}"
If you adopt this to the new format it should work
Thank you thank you this saved me today. Working on a kiosk for my BnB and was trying to get the battery switch thing working so I can tell the tablet when to charge.
Anyone know how to do this today, unfortunately the method proposed in your link @kajmaj seems deprecated in December 2022 with a link to THIS as the new way, however I am almost out of hair trying to figure out how to get events to work, the device info works fine but events are not.
I’ve tried with the $event and without (below) but nothing seems to show up on the fully_wall_tab_events entity that gets created.
In my configuration.yaml
#MQTT#
mqtt:
      - state_topic: fullykios/walltab/devinfo
        json_attributes_topic: fullykios/walltab/devinfo
      - state_topic: fullykios/walltab/event
        json_attributes_topic: fullykios/walltab/event
Fully Settings
Since I couldn’t find the answer anywhere and it’s taken me hours to work this out. Here’s how I got the motion state from MQTT:
mqtt:
  binary_sensor:
  # Fully Kiosk Motion sensors
    # Galaxy Tab A Motion
    - name: Galaxy Tab A Motion
      unique_id: 8983C354-AE5A-483F-A17A-E6DA742B60DF
      state_topic: fully/event/onMotion/[device_id]
      device_class: motion
      value_template: "{% if value_json.event == 'onMotion' %}ON{% else %}OFF{% endif %}"
      off_delay: 10 # Off after 10 seconds
Where are you adding this code? Also, have you added any other code anywhere relating to getting HA to see Fully
In configuration.yaml. Although technically in mqtt.yaml, but I have split my configuration.
