Is it possible to run HA with Fully Kiosk on the new Echo Show 15 or only on fire tablets?
…maybe i also want to use the new fire hd 10 tablet, but i cant find any wall mounts for it…
I am looking for the same info.
I am in the same boat, I am about to pull the trigger on touch screen monitor , but the show 15 would be an ideal solution if it works
How do you do right now?
I do automation in Alexa on motion sensor in living room and I open Silk every time.
Just came across this topic…The Fire HD 10 wall mount can be found here: https://mbmounts.com/
I was using it for several years…It’s nothing fancy, but serves it’s purpose. I ended taking out an electrical outlet in the kitchen and mounting it into the box with a direct wire…However, I would be very intrigued if anyone has figured out a way to hack the Echo Show 15 with Fully Kiosk and have it ‘always on’.
Cannot find…only for fire7
There is a drop down box at the bottom of the screen to select the HD fire tablet size and then another one will appear to select the generation:
Ah ok thx
New Info for the HA with Fully Kiosk on the new Echo Show 15?
There must be a bright spark out there somewhere who can hack Fully Kiosk onto this…please… pretty please.
Is there any news?
Hi, take a look here on how to install any APK on the echo Show device
I have tested it, installation worked fine, however I was very disappointed with the limitations caused by fire tv:
Really a pity! The hardware is really great for this amount of money.
Any news on this topic?
i made a youtube vid for this but could;nt get fully kiosk to run https://youtu.be/Ke1eeDrZC8E
