I then had trusted networks and api_password setup I believe. Then I would add something like the link below in motioneye. Motioneye would then send me a MQTT message notifying me off motion, and making a recording.
Hi
can you explain please how do you do it?
i’m trying without success
I get this message: “not a supported network camera”
when trying to ad network camera
HA’s generic camera integration works perfectly with Fully Kiosk’s getCamshot command.
Just remember, that you HAVE TO use the IP address (not a local DNS name) and that you HAVE TO url encode any special characters in your password.
So if your password is abc$xyz! your getCamshot URL would be: http://192.168.xxx.yyy:2323/?cmd=getCamshot&password=abc%24xyz%21
Also remember that new generic cameras are not added through configuration.yaml anymore but through the frontend. Go to Settings → Devices & Services and add a new integration with the “+” symbol.
Here is an example:
I got a Fire HD 10 set up and can see live video feed with a picture card. I got the camera working through the generic platform, as described in #1.
But now, I am trying to record from this camera. I played around a lot with ffmpeg to capture from the stream. But I just can’t seem to get it to work.
Interesting: on an older Ubuntu 18.04 install (ffmpeg version 4.3-2~18.04.york0), this works as expected. But on a 22.04 install (ffmpeg version 4.4.2-0ubuntu0.22.04.1), it does not. The command that works on the old machine is this:
I am deliberately using a higher framerate (-r 30) than what the cam can produce. This leads to a movie playing faster, which takes less time to review the safety footage.
Yes, I am capturing after persons have been detected.
I am using this both as motion sensor and as a security camera (activated by the sensors). Technically, the command up there is only pulling individual frames at a time. It’s not high-quality, though. I wanna say something like 320x256. (I think I read somewhere that fully is basically just pulling a preview rather than a full frame.) Still surprising how much you can see on those.
You can also show “live” video in lovelave. There might be a second delay, and the framerate is not super impressive (say, ≈7-10 fps), but still, I am getting something out of these videos. I am using the generic camera integration. I only fed the URL for the still images (individual frames), not the one for the streams, but that works anyway.
That said, I’d be much happier if fully actually provided the full-quality stream of the camera. Now, that would be some really good video!
