Fully Kiosk disconnects device from charging
I’m currently trying to diagnose why fullly kiosk is disconnecting my device from charging.
I have isolated the issue to fully kiosk by running isolated tests, without fully kiosk device charges fine, once I enable fully kiosk the device stops charging after around 20 minutes.
Does anyone know of a setting or what could be causing this behaviour when fully kiosk is enabled?
Hi Dale, did you found a solution for that? im facing excatly the same issue…
BR
