Fully Kiosk New Notification Feature - How to clear it?
I’ve just installed HA 2024.7 and tested the new Fully Kiosk notify integration.
It works great! However I don’t know how to remove the text notification from my tablet display.
Any clues?
I have the same problem. The notification remains at the bottom of the screen constantly, without being able to be removed
The only way I found was to send an empty message, until I found a better way.
hi. whats your yaml config for sending empty messages.
i could not get it running with an empty "message: "
Greetings
Hello. In the developer tools, search “notify.send_message”. Select your device. Press the spacebar once and start the action.
I found if you do that then go to yaml mode then remove the space so it is just empty quotes, its a true blank message, not sure if it really makes a difference but it makes my ocd feel better knowing theres no invisible space :slight_smile:
