I´m having a strange issue with the Fully kiosk integration where it seems the integration turns on the screen every other minute. Fully client on its own worked great until i installed the integration.
Then I wanted to be able to control the screen and turn it on and off manually for certain Automations.
When I have the “screen_off_timer” set to for example 45s its changing state of the screen every other minute as i mentioned, but if I set it to 0, the screen is always on but if i manually change the state it turns back on after a minute.
If I kill the Remote Administration to the client it behaves as normal, so its definitely the integration controlling/overriding the screen to on. Checking the enity history after being away for a day its been changing state hundreds of times over the day.
Any idea of how to use the function of “screen_off_timer” built in to Fully and not have the integration changing the state unexpectedly but only on manual trigger?
