Fully Kiosk Wont Show on Tablet
Hello All,
I loaded FK on my Fire HD 10 tablet, and got it hooked up to home assistant (I can see the entities in HA) however, i cant get to the kiosk screen in the tablet. I get the attached error. Has anyone seen this before?
Thank you,
Jesse
Does this url works in browser on pc? Did you try with IP address instead of using “homeassistant.local”?
That did it!!! Thank you, sir!
I never use local names, because i found them too many times to be unreliable or randomly unavailable. Only numbers - they never lie. For the same reason i only use IP’s for my ESPHome devices, not DNS names.
I am having the same issue except I am using http://10.0.0.104:8123/tablet-view/0
getting the error, EMPTY_RESPONSE
I can see the integration fine in HA.
