Fun with custom:button-card
I created a binary sensor (Aqara T1 Door Sensor) button card which calls a script to turn on my A/C on tap action. This function works fine, and I’m also able to change the state name to On/Off instead of the default Open/Closed.
However, I have difficulty changing the icon color based on the state. Below is my code, is there anything I’m doing wrong?
type: custom:button-card
entity: binary_sensor.living_room_air_con_sensor_contact
show_name: false
show_state: true
tap_action:
  action: call-service
  service: script.living_room_air_con_toggle
color_type: icon
color: |
    if (entity.state === 'off')
      return 'Green'
    else
      return 'Grey'
state_display: |
      return 'Off'
    else
      return 'On'
I’ve also tried using;
  state:
    - value: 'On'
      color: Green
    - value: 'Off'
      color: Grey
The icon color changes to yellow despite the above coding, which seems to be the default color for this senor/entity.
Thanks.
guys ive got a real werid one and not sure if this is the right place to post.
my setup is as follows.
  • Core2023.11.1
  • Frontend20231030.1
    Button card v4.1.1
So I have 2 lights (sideboard & underlight)
The code for these lights is
                  - type: custom:button-card
                    entity: light.kitchen_sideboard
                    name: <marquee behavior=scroll scrollamount="3">Side Board Lamp</marquee>
                    template:
                      - light
                      - icon_lamp
                      #- loader
                    entity: light.kitchen_under_light
                    template:
                      - base
                      - icon_lamp
If i turn light.kitchen_sideboard on/off works fine no issues.
BUT if i turn off light.kitchen_under_light i get this error
When i turn the light back on goes back to normal.
So its as if it can report something in its off state? BUT the strange thing is the other light light.kitchen_sideboard works fine when on/off with no errors.? which is throwing me to work out what it is.?!?!
I have tried switching templates from -base to -light
Any help would be great
I’ve not managed to make any progress with this - can anyone shed any light on how to achieve? Would it require CSS styling instead, in order to split out the format?
I have an issue with variables not showing.
Followed the instructions, but unfortunately no success.
Any obvious errors?
entity: input_select.bs9000
show_name: true
show_icon: true
variables:
  - var_disc: input_select.bs9000
  - var_pos: input_number.bs9000_sled
name: [[[ return variable.var_disc; ]]]
I’m able to display the name of the logged in user with this code.
    return "Hi "+ user.name + "!"
Does anyone know if it’s also possible to display the profile picture for the logged in user?
This is how I’m thinking it would look.
The image above is done by statically setting entity: person.drew and show_entity_picture: true. I’m looking for the picture to by dynamic, just like the name based on whoever is logged in.
This should work:
entity: '[[[ return "person." + user.name.toLowerCase(); ]]]'
name: '[[[ return "Hi " + user.name + "!" ]]]'
YES!!! Thank you!
Is oit posssible to use two images in an setup like
“i s i”
“i n i”
“l s l”
How can I use marquee on sensor value?
  entity: media_player.lounge_2
  label: >
    [[[ return '<marquee> entity.attributes.media_title <\marquee>' ]]]
This scrolls: entity.attributes.media_title and not the value of entity.
is it possible to use something like replace here on ${states[“sensor.enceinte_etat”].state
like replace “-” by line break
enceinte: '[[[return `<ha-icon icon="mdi:speaker" style="width: 14px;
 color: var(--color-icon-blue); margin-right: 2px;"></ha-icon><span>
 ${states["sensor.enceinte_etat"].state}</span>`]]]'
Thanks for all help
Your closing marquee tag should be </marquee> - see if that resolves it
thanks! well spotted!
Unfortunatelly, it still scrolls sensor name )-:
Use extra_styles for css
extra_styles:  >
    .marquee {
      animation: marquee 20s cubic-bezier(0.45, 0.05, 0.55, 0.95) infinite;
    @keyframes marquee {
      from {
        transform: translateX(0%);
      to {
        transform: translateX(-80%);
      state_display: >
          if (entity)
              return  `<div class="marquee"> ${states['sensor.someting'].state} </div>`;
CleanShot 2023-11-19 at 18.20.36
CleanShot 2023-11-19 at 18.21.30
exactly this. As an example from my dashboard, I am using this to generate the marquee on one of my button cards for my echo device, as the state display:
state_display: >
    let artist = entity.attributes.media_artist;
    let title = entity.attributes.media_title;
    if (entity.state === 'standby') {
      return 'Standby';
    } else if (artist && title) {
      return `<marquee>${artist} - ${title}</marquee>`;
    } else if (artist) {
      return `<marquee>${artist}</marquee>`;
    } else if (title) {
      return `<marquee>${title}</marquee>`;
Still my fav card this, been playing around recently and addeding different elements to it.
Thank you. I think that is the solution.
On another note…
Is it possible to dynamically move card or element inside card? Replacing hard coded position coordinate with variable driven by different entity?
Hey All,
I’m trying to add the mini-graph as it shows in this post; Fun with custom:button-card - #852 by edwardtich
However, when I’ve added this into my button-card, it’s just adding [object Object] in place of the graph. I can’t work out what I’m doing wrong, and ChatGPT isn’t helping me either (ha!).
Any ideas?
SCR-20231120-kkhu
entity: light.office_light_switch
icon: mdi:desk
tap_action:
  action: navigate
  navigation_path: /lovelace/office
  haptic: medium
styles:
  grid:
    - grid-template-areas: '"i temp" "n hum" "graph graph"'
    - grid-template-columns: 1fr 1fr
    - grid-template-rows: 1fr min-content min-content
  card:
    - background: var(--contrast2)
    - padding: 16px
    - '--mdc-ripple-press-opacity': 0
  img_cell:
    - justify-self: start
    - width: 24px
  icon:
    - width: 24px
    - height: 24px
    - color: var(--contrast8)
  name:
    - font-size: 14px
    - margin: 4px 0 4px 0
    - color: var(--contrast)
    - font-family: Montserrat
    - font-weight: 600
  custom_fields:
    temp:
      - align-self: start
      - justify-self: end
      - font-size: 13px
      - font-weight: 500
      - margin: 4px 0 0px 0
    hum:
      - align-self: start
      - justify-self: end
      - font-size: 13px
      - font-weight: 500
      - margin: 4px 0 12px 0
    graph:
      - padding-top: 0%
      - width: 100%
      - height: 100%
      - margin-bottom: '-3%'
custom_fields:
  temp: |
    return `<ha-icon
      icon="mdi:thermometer"
      style="width: 18px; height: 18px; color: var(--orange);">
      </ha-icon><span>${parseFloat(states['sensor.office_temperature_sensor_temperature'].state).toFixed(0)}°C</span>`
  hum: |
    return `<ha-icon
      icon="mdi:water-percent"
      style="width: 18px; height: 18px; color: var(--blue);">
      </ha-icon> <span>${parseFloat(states['sensor.office_temperature_sensor_humidity'].state).toFixed(0)}%</span>`
  graph:
      type: custom:mini-graph-card
      entities:
      - entity: sensor.office_temperature_sensor_temperature
        color: '#ff8c00'
      - entity: sensor.office_temperature_sensor_humidity
        color: '#3399ff'
        y_axis: secondary
      height: 50
      hours_to_show: 24
      line_width: 3
      font_size: 50
      animate: true
      show:
        icon: false
        state: false
        legend: false
        fill: fade
      card_mod:
        style: |
          ha-card {
            position: absolute !important;
            height: 100%;
            width: 100%;
            top: 0px;
            --ha-card-border-width: 0;
          ha-card:after {
            content: "";
            position: absolute;
            width: 100%;
            height: 100%;
            background: linear-gradient(to right, var(--card-background-color) 20%, transparent);
state:
  - value: 'on'
    styles:
      card:
        - background: |
                var color = entity.attributes?.rgb_color;
                if (entity.state != "on"){
                  return 'var(--contrast20)';
                else if (color){
                  return 'rgba(' + color + ')'
                else{
                  return 'var(--yellow)'
      icon:
        - color: var(--red)
        - animation: bounce 2s infinite
      name:
        - color: var(--black)
  - value: 'off'
    styles:
      name:
        - color: var(--contrast20)
extra_styles: |
  @keyframes bounce {
    0% { transform: scale3d(1, 1, 1); }
          7% { transform: scale3d(1.25, 0.75, 1); }
          10% { transform: scale3d(0.75, 1.25, 1); }
          12% { transform: scale3d(1.15, 0.85, 1); }
          16% { transform: scale3d(0.95, 1.05, 1); }
          19% { transform: scale3d(1.05, 0.95, 1); }
          25% { transform: scale3d(1, 1, 1); }
EDIT: I managed to get this working, and also do some cool stuff with it. So now, when the entity is on, the color of the name changes, and the icon bounces.
If anyone is interested in using my code to add to their setup, it is below.
type: custom:stack-in-card
cards:
    entity: light.living_room_light_switch
    icon: '[[[ return entity.attributes.icon ]]]'
    show_icon: false
    tap_action:
      action: navigate
      navigation_path: /lovelace/living-room
      haptic: medium
    styles:
      card:
        - padding: 16px
      icon_cells:
        - margin-top: 12px
        - margin-left: 15px
        - animation: |
              var state = states['light.living_room_light_switch'].state;
              return state === 'on' ? 'bounce 2s infinite' : 'none';
      img_cell:
        - width: 24px
      custom_fields:
        temp:
          - align-self: start
          - justify-self: end
          - font-size: 13px
          - font-weight: 500
        hum:
          - align-self: start
          - justify-self: end
          - font-size: 13px
          - font-weight: 500
          - margin: 1px 0 12px 0
        graph:
          - padding-top: 0%
          - width: 100%
          - height: 100%
        icon_cells:
          - width: 24px
          - height: 24px
          - animation: |
      name:
        - font-size: 14px
        - margin: 1px 0 1px 0
        - color: |
              return state === 'on' ? 'white' : 'grey';
        - font-weight: 600
      grid:
        - grid-template-areas: '"icon_cells slider temp" "n slider hum"'
        - grid-template-columns: 1fr min-content 1fr
    custom_fields:
      icon_cells: |
         if(state == "on")
          return `<ha-icon
          icon="mdi:sofa"
          style="width: 25px; height: 25px; color: yellow;">
          </ha-icon>
         else
          return `<ha-icon
          icon="mdi:sofa-outline"
          style="width: 25px; height: 25px; color: grey;">
          </ha-icon>
      temp: |
          return `<ha-icon
          </ha-icon><span>${parseFloat(states['sensor.living_room_temp_sensor_temperature'].state).toFixed(0)}°C</span>`
      hum: |
          return `<ha-icon
          </ha-icon> <span>${parseFloat(states['sensor.living_room_temp_sensor_humidity'].state).toFixed(0)}%</span>`
    card_mod:
      style: |
        ha-card {
          z-index: 1;
          height: 70px;
    extra_styles: |
      @keyframes bounce {
  - type: custom:mini-graph-card
    entities:
      - entity: sensor.living_room_temp_sensor_temperature
        color: '#ff8c00'
      - entity: sensor.living_room_temp_sensor_humidity
        color: '#3399ff'
        y_axis: secondary
    height: 40
    hours_to_show: 24
    line_width: 3
    font_size: 50
    show:
      icon: false
      state: false
      legend: false
    card_mod:
      style: |
        ha-card {
          position: absolute;
          height: 100%;
          width: 100%;
          top: 0px;
        ha-card:after {
          content: "";
          position: absolute;
          width: 100%;
          height: 100%;
Light On:
Light Off:
encja
How to use a fan that rotated proportionally to the entity’s rotation.
state:
  - value: 'on'
    color: blue
    spin: true
entity: entity: sensor.panasonic_heat_pump_main_fan2_motor_speed
show_state: tfalse
icon: mdi:fan
Have look here…
