Good work on this card. Just a question what is this sensor that you are referring to sensor.g3_1_iphone
is it possible to have a button change colour depending on the state of a sensor while when pressed run a script?
I have a button for my 3D printer that runs a script to determin if the printer is safe to turn off or if it needs turned on. what I’d like to do though is have the button be the standard blue if its “Off”, be green if its “Safe” and be red if its “Not Safe”
here is what I have tried
type: custom:button-card
entity: sensor.ender_safe_shutdown
icon: mdi:printer-3d-nozzle
state:
- value: 'Off'
color: black
- value: Not Safe
color: red
- value: Safe
color: green
tap_action:
action: toggle
entity: script.ender_5_safe_switch
but when I press it, I get “Failed to call service sensor/turn_off. Service not found”
the button changes colour correctly it’s the tap action that isn’t doing as I want.
any help?
I believe, this should be:
tap_action:
action: call-service
service: script.ender_5_safe_switch
hmm, strange. Are you sure the script is working? Have you tried to run it from Developer tools/services?
Anyway, details of tap_action can be found here: Actions - Home Assistant
Thank you Suxlala! I had to change it to this
tap_action:
service: script.toggle
service_data:
entity_id: script.ender_5_safe_switch
now that part works a charm and I can also use that to clean up some other buttons.
now to work out the tweeks and change the background colour but I’m sure ive seen somewhere how to do that
thank you again
Hi all!
Trying to set up a custom:button-card to change the opacity to 1 depending on what state my vacuum is in, I want it to go to 1 on all states except docked (then the “go home” card is hidden). Anyone have any thoughts on how to solves this and I dont want add one section for each state
thought I could use something like this but it doesn´t work:
state:
- value: [[[ return state['vacuum.name'].states != docked; ]]]
Hope someone can help me get this correct.
Kind regards
It’s
state:
- operator: template
value: |
[[[ return … ]]]
or
state:
value: "[[[ return … ]]]"
Thanks for the response but all I get is this:
ButtonCardJSTemplateError: ReferenceError: state is not defined in ‘return state[‘vacuum.name’].states != ‘docked’;’
And it doesnt matter which solution i try. The both render the same error and I´ve tried with double-quotes, single, none. Same error.
when using the template in the name field it works “[[[ return state[‘vacuum.name’].states ]]]” the name changes to docked, any ideas?
Thanks!
For reference, this is the entire card:
entity: vacuum.name
icon: mdi:robot-vacuum-variant
name: "[[[ return states['vacuum.name'].state ]]]"
styles:
card:
- height: 90px
- width: 120px
- border-radius: 10%
- padding: 5%
- color: white
- font-size: 20px
- background-color: '#000000'
- border-width: 5px
- border-color: darkgrey
- border-style: solid
- opacity: 0
name:
- color: white
icon:
- color: lightgrey
state:
value: "[[[ return states['vacuum.name'].state !='docked']]]"
icon: mdi:home-import-outline
tap_action:
service: vacuum.return_to_base
service_data:
entity_id: vacuum.name
hold_action:
action: none
styles:
card:
- opacity: 1
I don’t use a vacuum cleaner, so I can only test with other entities and cannot confirm the mentioned failure notice.
Think I solved it by using this:
opacity: “[[[ if (entity.state = docked) return 0; else 1 ]]]”
Haven’t tested it yet but looks promising
Is it possible to use a template for colors? I can’t seem to make this work:
- type: custom:button-card
entity: input_boolean.set64_0
color_type: card
color: '{{ states("input_select.set64_colors") }}'
aspect_ratio: 1/1
show_name: false
show_icon: false
It’s
color: '[[[ return states["input_select.set64_colors"].state ]]]'
But I can’t test now, if color
is templatable.
it’s not: https://github.com/custom-cards/button-card#main-options
you can change color in the state:
or styles:
section of the button card.
It probably says something about not using jinja templates too Always good to read the docs…
i have some custom_fields in my card.
is it somehow possible to only show them when the entity is “on”.
custom_fields:
bright: |
{% if is_state("light.sockel_kueche", "on") -%}
var b = states['light.sockel_kueche'].attributes.brightness;
return parseInt(b ? b/2.55 : '0') + '%';
{%- else -%}
{%- endif %}
Kick out all Jinja code and control the visibility of the custom field with CSS:
custom_fields:
bright: |
var b = states['light. sockel_kueche'].attributes.brightness;
styles:
custom_fields:
bright:
- display: |
return states['light.sockel_kueche'].state == 'off' ? 'none' : 'block'
just noticing you use parseInt()
where I have Math.round(entity.attributes.brightness/2.55)
would there be any advantage of one over the other?
amazing!!! Thank you very much
I don’t like to change great codes =)
but that’s how it should work, right?
I have a few buttons that all look the same… and I think with this adjustment I “only” need to select the entity afterwards and then I wouldn’t have to adjust everything in the code anymore, right?
custom_fields:
bright: |
styles:
bright:
- display: |
return entity.state == 'off' ? 'none' : 'block'
do you think so ?
custom_fields:
bright: |
var b = entity.attributes.brightness ? Math.round(entity.attributes.brightness/2.55) : '';
