pedolsky
(Pedolsky)
February 18, 2022, 7:04pm
351
No, please compare my example above. You have to reference the custom field by using
styles:
custom_fields: ##<— this is mandatory
bright:
- display: |
return states['light.sockel_kueche'].state == 'off' ? 'none' : 'block'
MrThiemann
(Mr Thiemann)
February 18, 2022, 7:11pm
352
yes, I did… I think I expressed myself wrong.
type: custom:button-card
entity: light.sockel_kueche
icon: hass:outdoor-lamp
show_icon: true
aspect_ratio: 1/1
hold_action:
action: more-info
tap_action:
action: toggle
show_state: true
template: kt_card_1
custom_fields:
bright: |
var b = entity.attributes.brightness ? Math.round(entity.attributes.brightness/2.55) : '';
return parseInt(b ? b/2.55 : '0') + '%';
button_card_templates:
kt_card_1:
styles:
card:
grid:
- grid-template-areas: '"i bright ." "i bm ." "n cl ." "s cl ."'
- grid-template-columns: 1fr min-content
- grid-template-rows: 1fr min-content min-content
custom_fields:
bright:
- display: |
return entity.state == 'off' ? 'none' : 'block'
I have it now and I think it works perfectly!
in your snippet you have: return states[‘light.sockel_kueche ’].state == ‘off’ ? ‘none’ : 'block’
I would like to get rid of the light.sockel_kueche so that I only have to determine the entity once (when creating the card).
editing…
I’ve attached my picture =)
custom:button_card’s are awesome!!!
at the bottom right you see “mirror” here everything is off.
on the left above and below are different properties of the lamps.
pedolsky
(Pedolsky)
February 18, 2022, 9:46pm
353
Yes, all fine. If you use a „main“ entity, there’s no need to repeat it all over the code.
this seems odd…
currently you check twice for the existence and use 2 different methods for doing the same. if yes you divide an extra time /2.55.
Or what am I missing
do as Pedolsky said earlier:
var b = states['light. sockel_kueche'].attributes.brightness;
first set the var, and then manipulate that in the return clause. Using entity that would become
var b = entity.attributes.brightness;
@qoheleth I’m loving your dashboard and was trying to copy your configs but getting stuck with these errors. I understand you have different entities defined etc but
I have the lovelace running in YAML mode. I have the ui-lovelace.yaml, lovelace-templates-button-card.yaml, lovelace-templates-decluttering.yaml and sensors.yaml but still having this error regarding custom element doesn’t exist… Hope you can assist. TIA
qoheleth
(Russell Smith)
February 26, 2022, 5:09pm
356
First and most obvious: Do you have the single-weather card and custom: button-card installed?
I installed them with HACS as Frontend enhancements.
In my /config/configuration.yaml file, I have these entries:
lovelace:
mode: yaml
resources:
- url: /hacsfiles/button-card/button-card.js
type: module
- url: /hacsfiles/simple-weather-card/simple-weather-card-bundle.js
type: module
remmob
February 26, 2022, 11:03pm
357
How can I apply a background image to the card?
I have tried:
- type: custom:button-card
styles:
card:
grid:
- image: url('https://demo.home-assistant.io/stub_config/bedroom.png')
- background-size: cover
But that’s doesn’t work.
pedolsky
(Pedolsky)
February 26, 2022, 11:32pm
358
styles:
card:
- background-image: url('https://demo.home-assistant.io/stub_config/bedroom.png')
remmob
February 27, 2022, 6:49am
359
Found it, must be.
styles:
card:
- background: url('https://demo.home-assistant.io/stub_config/bedroom.png')
Only not the whole image, but that should not be a problem.
MrThiemann
(Mr Thiemann)
February 27, 2022, 7:39am
360
hey,
I need help with a variable, please.
I have custom_field with two entity_pictures. depending on whether the LED has RGB color, either a colored image or a white one should be shown.
custom_fields:
cl:
card:
icon: mdi:palette
entity_picture: /local/multic.png
show_entity_picture: true
show_name: false
styles:
card:
- background-color: '#242e42'
- height: 25px
- width: 25px
icon:
- width: 15px
I have a template with which I can check whether RGB is available (or not)
But I can’t get it integrated into the button card.
{% set variable = state_attr('light.sockel_kueche', 'rgb_color') %}
{% if variable == none %} /local/white.png {% else %} /local/multic.png{% endif %}
everything I´ve found so far is just the query with "is_state == ‘on’ " … but it doesn’t work that way
qoheleth:
hacsfiles
Thanks @qoheleth - That was it. I’ve moved to YAML mode and did define the resources. Now I’m getting the following errors:
qoheleth
(Russell Smith)
February 28, 2022, 2:25am
362
Yes. Those are all defined as decluttering cards (also installed via HACS, which requires these additional lines in /config/configuration.yaml: (after the ‘resources:’ line)
- url: /local/decluttering-card.js
type: module
You’ll notice from the above that the decluttering card files (for me) aren’t in the hacsfiles folder. I had some issues early on with making that work so I manually installed them. I’m assured by the decluttering card creator that that has been fixed but I haven’t changed it because it’s working.
I have a /config/lovelace-templates-decluttering.yaml file which is as follows:
# card to show various (on/off) modes
mode-thing:
card:
entity: '[[thing_entity]]'
state_color: true
triggers_update: all
aspect_ratio: '[[aspect_ratio]]'
hold_action:
action: fire-dom-event
browser_mod:
command: call-service
service: browser_mod.popup
service_data:
deviceID: this
title: Modes
hide_header: false
card:
type: entities
entities:
- type: custom:template-entity-row
icon: "{% if is_state('[[thing_entity]]','on') %} [[thing_icon_on]] {% else %} [[thing_icon_off]] {% endif %}"
active: "{{ is_state('[[thing_entity]]','on') }}"
state: "{% if is_state('[[thing_entity]]','on') %} [[thing_name_on]] {% else %} [[thing_name_off]] {% endif %}"
toggle: '[[thing_toggle]]'
entity: '[[m0_entity]]'
icon: "{% if is_state('[[m0_entity]]','[[m0_on_state]]') %} [[m0_icon_on]] {% else %} [[m0_icon_off]] {% endif %}"
active: "{{ is_state('[[m0_entity]]','[[m0_on_state]]') }}"
state: "{% if is_state('[[m0_entity]]','[[m0_on_state]]') %} [[m0_status_on]] {% else %} [[m0_status_off]] {% endif %}"
toggle: '[[m0_toggle]]'
condition: '[[m0_show]]'
entity: '[[m1_entity]]'
icon: "{% if is_state('[[m1_entity]]','[[m1_on_state]]') %} [[m1_icon_on]] {% else %} [[m1_icon_off]] {% endif %}"
active: "{{ is_state('[[m1_entity]]','[[m1_on_state]]') }}"
state: "{% if is_state('[[m1_entity]]','[[m1_on_state]]') %} [[m1_status_on]] {% else %} [[m1_status_off]] {% endif %}"
toggle: '[[m1_toggle]]'
condition: '[[m1_show]]'
entity: '[[m2_entity]]'
icon: "{% if is_state('[[m2_entity]]','[[m2_on_state]]') %} [[m2_icon_on]] {% else %} [[m2_icon_off]] {% endif %}"
active: "{{ is_state('[[m2_entity]]','[[m2_on_state]]') }}"
state: "{% if is_state('[[m2_entity]]','[[m2_on_state]]') %} [[m2_status_on]] {% else %} [[m2_status_off]] {% endif %}"
toggle: '[[m2_toggle]]'
condition: '[[m2_show]]'
entity: '[[m3_entity]]'
icon: "{% if is_state('[[m3_entity]]','[[m3_on_state]]') %} [[m3_icon_on]] {% else %} [[m3_icon_off]] {% endif %}"
active: "{{ is_state('[[m3_entity]]','[[m3_on_state]]') }}"
state: "{% if is_state('[[m3_entity]]','[[m3_on_state]]') %} [[m3_status_on]] {% else %} [[m3_status_off]] {% endif %}"
toggle: '[[m3_toggle]]'
condition: '[[m3_show]]'
styles:
card:
- background-color: '[[card_background_color]]'
- border-radius: 0%
- padding: 1%
- color: ivory
- font-size: 12px
- text-transform: capitalize
grid:
- grid-template-areas: '"n n m0 m0 m0" "i i m1 m1 m1" "i i m2 m2 m2" "stat stat m3 m3 m3"'
- grid-template-columns: 1fr 1fr 1fr 1fr 1fr
- grid-template-rows: 1fr 1fr 1fr 1fr
name:
- font-weight: bold
- font-size: 13px
- color: white
- align-self: middle
- justify-self: start
- padding-bottom: 0px
img_cell:
- justify-content: start
- align-items: start
- margin: 0%
icon:
- color: |
if (entity.state == 'on') return '[[thing_icon_color_on]]';
else return '[[thing_icon_color_off]]';
- width: 80%
- margin-top: 0%
custom_fields:
stat:
- font-size: 12px
m0:
m1:
m2:
m3:
state:
- value: 'on'
icon: '[[thing_icon_on]]'
- value: 'off'
icon: '[[thing_icon_off]]'
custom_fields:
stat: |
var status = '[[thing_name_off]]';
if (entity.state == "on") status = '[[thing_name_on]]';
return `<span>${status}</span>`
m0: |
if ('[[m0_show]]' == 'true') {
var icon = '[[m0_icon_off]]';
var icon_color = '[[m0_icon_color_off]]';
var status = '[[m0_status_off]]';
if (states['[[m0_entity]]'].state == '[[m0_on_state]]') {
icon = '[[m0_icon_on]]';
status = '[[m0_status_on]]';
icon_color = '[[m0_icon_color_on]]';
return `<ha-icon icon=${icon}
style="width: 14px; height: 14px; color: ${icon_color};">
</ha-icon><span style="color: white";> ${status}</span>`
return ``
m1: |
if ('[[m1_show]]' == 'true') {
var icon = '[[m1_icon_off]]';
var icon_color = '[[m1_icon_color_off]]';
var status = '[[m1_status_off]]';
if (states['[[m1_entity]]'].state == '[[m1_on_state]]') {
icon = '[[m1_icon_on]]';
status = '[[m1_status_on]]';
icon_color = '[[m1_icon_color_on]]';
return ``
m2: |
if ('[[m2_show]]' == 'true') {
var icon = '[[m2_icon_off]]';
var icon_color = '[[m2_icon_color_off]]';
var status = '[[m2_status_off]]';
if (states['[[m2_entity]]'].state == '[[m2_on_state]]') {
icon = '[[m2_icon_on]]';
icon_color = '[[m2_icon_color_on]]';
status = '[[m2_status_on]]';
return ``
m3: |
if ('[[m3_show]]' == 'true') {
var icon = '[[m3_icon_off]]';
var icon_color = '[[m3_icon_color_off]]';
var status = '[[m3_status_off]]';
if (states['[[m3_entity]]'].state == '[[m3_on_state]]') {
icon = '[[m3_icon_on]]';
icon_color = '[[m3_icon_color_on]]';
status = '[[m3_status_on]]';
return ``
# card with main entity and lock entity
locking-thing:
card:
type: 'custom:button-card'
template: standard-button
styles:
grid:
- position: relative
custom_fields:
lock:
- position: absolute
- right: 0%
- top: -10%
- height: 18px
- width: 12px
custom_fields:
lock: |
var icon = "mdi:lock-open-variant:";
var color = "darkRed";
var status = states['[[lock_entity]]'].state;
if (status == 'on') {
icon = "mdi:lock";
color = "darkGreen";
return `<ha-icon icon="${icon}"
style="width 12px; height: 12px; color: ${color};"></ha-icon>`
hold_action:
action: call-service
service: homeassistant.toggle
service_data:
entity_id: '[[lock_entity]]'
state:
- value: 'on'
- value: 'off'
and these are the first two lines of my /config/ui-lovelace.yaml file:
decluttering_templates: !include lovelace-templates-decluttering.yaml
button_card_templates: !include lovelace-templates-button-card.yaml
which, as you can see invoke the decluttering templates and the button card templates from separate files (for ease of editing and basically helping me to remember where to go to find all of that).
Thanks @qoheleth - Fixed that problem but there are so many other errors now might just have to bite the bullet and start fresh.
qoheleth
(Russell Smith)
March 1, 2022, 12:02am
364
Keep in mind that it took me about a year to get to where all this was done, a little bit at a time.
(I’ll be glad to help as I can so it might take you less time.)
Dear Keith
Thanks to your hard work, I have achieved the attached Dashboard.
However I am struggling to change the color of the Alterter Dual Sensors. I want them to be green when locked and red when open.
Can you please guide me on how to do it?
Sajive
Zurich - Switzerland
tk5lam
(TK)
March 9, 2022, 11:21am
366
I used the code (bellow) and I am struggling to create a variable that would change the icon bassed on value in the small fields (let’s say cpu).
entity: 'sensor.raspi_temp'
icon: 'mdi:raspberry-pi'
aspect_ratio: 1/1
styles:
card:
- background-color: '#000044'
- border-radius: 10%
- padding: 10%
- color: ivory
- font-size: 10px
- text-shadow: 0px 0px 5px black
grid:
- grid-template-areas: '"i temp" "n n" "cpu cpu" "ram ram" "sd sd"'
- grid-template-rows: 1fr min-content min-content min-content min-content
name:
- font-weight: bold
- font-size: 13px
- color: white
- padding-bottom: 4px
img_cell:
- margin: none
icon:
- color: >
if (entity.state < 60) return 'lime';
if (entity.state >= 60 && entity.state < 80) return 'orange';
else return 'red';
- width: 70%
- margin-top: -10%
custom_fields:
temp:
- align-self: start
- justify-self: end
cpu:
- padding-bottom: 2px
- --text-color-sensor: '[[[ if (states["sensor.raspi_cpu"].state > 80) return "red"; ]]]'
ram:
- --text-color-sensor: '[[[ if (states["sensor.raspi_ram"].state > 80) return "red"; ]]]'
sd:
- --text-color-sensor: '[[[ if (states["sensor.raspi_sd"].state > 80) return "red"; ]]]'
custom_fields:
temp: >
return `<ha-icon
icon="mdi:thermometer"
style="width: 12px; height: 12px; color: yellow;">
</ha-icon><span>${entity.state}°C</span>`
cpu: >
return `<ha-icon
icon="mdi:server"
style="width: 12px; height: 12px; color: deepskyblue;">
</ha-icon><span>CPU: <span style="color: var(--text-color-sensor);">${states['sensor.raspi_cpu'].state}%</span></span>`
ram: >
return `<ha-icon
icon="mdi:memory"
</ha-icon><span>RAM: <span style="color: var(--text-color-sensor);">${states['sensor.raspi_ram'].state}%</span></span>`
sd: >
return `<ha-icon
icon="mdi:harddisk"
</ha-icon><span>SD: <span style="color: var(--text-color-sensor);">${states['sensor.raspi_sd'].state}%</span></span>``
I have a sensor with battery and would like to change icon bassed on state. Something like this:
return `<ha-icon
icon='[[[ if (states["sensor.raspi_sd"].state > 80) return "mdi:Battery-high"; else return "mdi:Battery-low" ]]]'
Can you help me?
Thanks,
qoheleth
(Russell Smith)
March 9, 2022, 6:49pm
367
Try something like this:
var icon = "mdi:map-marker";
var color = "lightGrey";
var status = states[variables.m1_entity].state;
if (status != 'not_home') {
icon = states['zone.'+status].attributes['icon'];
color = "white";
return `<span>${variables.m1_name}:</span>
style="width: 14px; height: 14px; color: ${color};"></ha-icon>
pimp1310
(Pimp1310)
March 14, 2022, 12:32pm
368
is it possible to have in my picture in the red circle the temperature of the entity?
entity: climate.heizung_keller
tap_action:
browser_mod:
deviceID:
- this
command: popup
hide_header: false
title: Keller
large: false
style:
.mdc-dialog .mdc-dialog__container {
height: 560px;
width: 100%;
.mdc-dialog .mdc-dialog__container .mdc-dialog__surface {
width:25%;
height: auto;
border: 1px solid gray;
border-radius: 15px;
background: center / cover no-repeat url("/local/profilbilder/background.jpg");
:host {
--mdc-theme-surface: rgba(0,0,0,0);
--secondary-background-color: rgba(0,0,0,0);
--ha-card-background: rgba(0,0,0,0);
--mdc-dialog-scrim-color: rgba(0,0,0,0.8);
--mdc-dialog-min-height: 100%;
--mdc-dialog-min-width: 100%;
--mdc-dialog-max-width: 100%;
mwc-icon-button {
color: #FFF;
card:
type: vertical-stack
cards:
- type: horizontal-stack
cards:
- type: custom:thermostat-popup-card
color: rgb(3,169,244)
color_type: icon
icon: mdi:radiator
show_state: true
styles:
card:
- background-color: rgba(190, 190, 190, 0.2)
- border-radius: 12px
- height: 105px
grid:
- grid-template-areas: '"i" "n" "s" "l"'
- grid-template-columns: 3fr
img_cell:
- align-self: left
- text-align: start
- margin-right: 100px
name:
- padding-left: 10px
- font-weight: light
- font-family: Helvetica
- font-size: 12px
state:
- font-size: 11px
- font-weight: bold
state:
- value: 18
operator: <=
color: red
remmob
March 14, 2022, 7:56pm
369
Does anybody know if it is possible to use minmax(x,y) CSS property in the card styles
for with and height of the card itself.
or use width and height: 1fr to fit the parent grid cell
it seems not to work, even setting height in % doesn’t work.
remmob
March 16, 2022, 4:34pm
370
I have a made grid inside the custom button card, it has a space above the top and bottom
of the grid, but can not figure out where it is coming from.
On the sides there is no space.
My code:
styles:
card:
- width: 417px #1920x1080
- height: 234px #1920x1080
grid:
- grid-template-areas: '". . . . . . " "mylabel . . . . temp" "light heat screen scene vent media"'
- grid-template-rows: 0px 1fr 1fr
- grid-row-gap: 0px
custom_fields:
mylabel:
- font-weight: normal
- vertical-align: middle
- background-color: rgba(0,0,0,0.5)
- align-self: start
- text-align: start
temp:
- font-weigth: normal
#- font-size: 16px
- align-self: start
- width: 100%
custom_fields:
mylabel: >
return '<span style="padding-left: 20px; padding-top: 10px;">living</span>'
temp: >
return `<span style="padding-right: 20px;">${states['sensor.temperture_woonkamer'].state} °C</span>`
