why do you keep posting in this thread, while there is a huge thread with so many more people to help and get inspiration from? Not saying you shouldn’t, it just that the other thread has all the examples you would need to get you all going.
I know I am doing some basic wrong. I have put this into my raw configuration but am getting this error:
Button-card template 'container' is missing!
This is the config. I am fairly new to dashboards with HA so I am quite certain it is probably something in the wrong place sort of thing. Any help would be appreciated. Of course I truncated the config to just enough to show the error.
Thanks!
title: Home
template:
button_card_templates:
container:
color_type: label-card
color: dimgray
styles:
card:
- padding: 0
name:
- border-radius: 0.4em 0.4em 0 0
- padding: 0.1em
- width: 100%
- font-weight: bold
grid:
- grid-template-areas: '"i" "n" "buttons"'
- grid-template-columns: 1fr
- grid-template-rows: 1fr min-content min-content
custom_fields:
buttons:
- background-color: 'rgba(0,0,0,0.3)'
- margin: 0
- padding: 0.3em
- path: default_view
title: Home
cards:
- type: 'custom:button-card'
template: container
color: '#EDE7B0'
name: Eating & Patio
custom_fields:
buttons:
card:
type: horizontal-stack
cards:
- entity: switch.ge_14291_in_wall_smart_switch_switch_2
template: standard
icon: 'mdi:wall-sconce-flat'
Do you have the first section that begins with “button card templates:”? It’s something like this and is at the very beginning of your Lovelace raw config.
standard:
color_type: card
hold_action:
action: more-info
styles:
card:
- padding: 0.2em
- '--mdc-ripple-color': yellow
- '--mdc-ripple-press-opacity': 0.5
icon:
- opacity: 0.75
name:
- font-size: 0.5em
- white-space: normal
state:
- font-size: 0.5em
label:
- font-size: 0.5em
wide:
template: standard
styles:
grid:
- position: relative
- grid-template-areas: '"i n"'
- grid-template-columns: 1fr 1fr
container:
color: dimgray
styles:
card:
- padding: 0
name:
- padding: 0.0em
- width: 100%
- font-weight: bold
- font-size: 0.6em
grid:
custom_fields:
buttons:
- margin: 0
- padding: 0.15em
standard-button:
template: standard
variables:
value_on: 'on'
value_off: 'off'
background_color_on: gold
background_color_off: slategrey
text_color_on: blue
text_color_off: white
styles:
label:
- color: '[[[ return variables.text_color_off ]]]'
state:
- id: value_on
value: '[[[ return variables.value_on ]]]'
styles:
card:
- background-color: '[[[ return variables.background_color_on ]]]'
name:
- color: '[[[ return variables.text_color_on ]]]'
icon:
- opacity: 1
- id: value_off
value: '[[[ return variables.value_off ]]]'
styles:
card:
- background-color: '[[[ return variables.background_color_off ]]]'
name:
icon:
- opacity: 0.5
option-button:
template: standard
show_icon: false
aspect_ratio: 1/1
styles:
card:
- border-radius: 20%
dimmer-option:
template: option-button
tap_action:
action: call-service
service: light.turn_on
service_data:
entity_id: entity
brightness: '[[[ return variables.set_value ]]]'
state:
- operator: default
styles:
card:
- background-color: '[[[ return variables.option_button_off_color ]]]'
- color: '[[[ return variables.option_text_off_color ]]]'
- operator: template
value: >-
[[[ return (entity.attributes.brightness||0) >= variables.range_start
&& (entity.attributes.brightness||0) <= variables.range_stop ]]]
styles:
card:
- background-color: '[[[ return variables.option_button_on_color ]]]'
- color: '[[[ return variables.option_text_on_color ]]]'
presets:
template: standard
color_type: icon
tap_action:
action: none
styles:
card:
icon:
- color: white
grid:
- grid-template-areas: '"i opt1 opt2 opt3 opt4" "n opt1 opt2 opt3 opt4"'
- grid-template-columns: 1fr 1fr 1fr 1fr 1fr
custom_fields:
opt1:
- margin: 0.1em
- overflow: visible
opt2:
- margin: 0.1em
- overflow: visible
opt3:
- margin: 0.1em
- overflow: visible
opt4:
- margin: 0.1em
- overflow: visible
variables:
option_template: dimmer-option
option_button_on_color: var(--paper-item-icon-active-color)
option_text_on_color: white
option_button_off_color: var(--paper-card-background-color)
option_text_off_color: white
option1_name: Low
option1_set_value: 51
option1_range_start: 1
option1_range_stop: 77
option2_name: Med
option2_set_value: 102
option2_range_start: 78
option2_range_stop: 170
option3_name: High
option3_set_value: 255
option3_range_start: 171
option3_range_stop: 255
option4_name: 'Off'
option4_set_value: 0
option4_range_start: 0
option4_range_stop: 0
custom_fields:
opt1:
card:
entity: '[[[ return variables.entity ]]]'
template: '[[[ return variables.option_template ]]]'
name: '[[[ return variables.option1_name ]]]'
variables:
set_value: '[[[ return variables.option1_set_value ]]]'
range_start: '[[[ return variables.option1_range_start ]]]'
range_stop: '[[[ return variables.option1_range_stop ]]]'
option_button_on_color: '[[[ return variables.option_button_on_color ]]]'
option_button_off_color: '[[[ return variables.option_button_off_color ]]]'
option_text_on_color: '[[[ return variables.option_text_on_color ]]]'
option_text_off_color: '[[[ return variables.option_text_off_color ]]]'
opt2:
card:
name: '[[[ return variables.option2_name ]]]'
variables:
set_value: '[[[ return variables.option2_set_value ]]]'
range_start: '[[[ return variables.option2_range_start ]]]'
range_stop: '[[[ return variables.option2_range_stop ]]]'
opt3:
card:
name: '[[[ return variables.option3_name ]]]'
variables:
set_value: '[[[ return variables.option3_set_value ]]]'
range_start: '[[[ return variables.option3_range_start ]]]'
range_stop: '[[[ return variables.option3_range_stop ]]]'
opt4:
card:
name: '[[[ return variables.option4_name ]]]'
variables:
set_value: '[[[ return variables.option4_set_value ]]]'
range_start: '[[[ return variables.option4_range_start ]]]'
range_stop: '[[[ return variables.option4_range_stop ]]]'
alerter:
template: standard
show_last_changed: true
color_type: icon
extra_styles: |
[[[ return `
@keyframes pulse {
20% {
background-color: ${variables.color};
variables:
state:
- value: 'on'
styles:
card:
- animation: pulse 1s infinite
alerter-dual:
template: standard
color_type: icon
extra_styles: |
[[[ return `
@keyframes pulse1 {
20% {
background-color: ${variables.color_initial};
@keyframes pulse2 {
20% {
background-color: ${variables.color_extended};
@keyframes color {
0% {
color: unset;
opacity: 0.5
99% {
color: unset;
opacity: 0.5
100% {
variables:
color_initial: var(--paper-item-icon-active-color)
color_extended: 'rgba(240,52,52, 0.9)'
color_seconds: 60
state:
- value: 'on'
styles:
card:
- animation: >-
[[[ return `pulse1 1s ${variables.color_seconds}, pulse2 1s
${variables.color_seconds}s infinite` ]]]
icon:
- color: '[[[ return variables.color_extended ]]]'
- opacity: 1
- animation: '[[[ return `color ${variables.color_seconds}s 1` ]]]'
name:
- font-weight: bold
check this Lovelace config:
title: Ha Rpi4 Data
button_card_templates: !include lovelace/buttons/button_card_templates.yaml # <------- this is where you save your templates
decluttering_templates: !include_dir_named lovelace/decluttering_templates
custom_header: !include lovelace/custom_header/custom_header_data.yaml
- !include lovelace/views/view_Home_assistant.yaml #0
- !include lovelace/views/view_Light_data.yaml #1
- !etcetcetc
in that file you should copy what you now show below template: (which isnt a valid key in the first place)
safe below code in a button_card_templates.yaml file in the directory of your naming (and reference that in the main lovelace-ui.yaml like I suggested above)
container:
color: dimgray
styles:
card:
- padding: 0
name:
- padding: 0.1em
- width: 100%
- font-weight: bold
grid:
custom_fields:
buttons:
- margin: 0
- padding: 0.3em
That decluttering is a good move.
@qoheleth Yes, it is there, it is the third line in the config that I posted.
ah, that was my problem. I removed templates and everything started working. Not sure why I put that in there in the first place. Many thanks!!
@Mariusthvdb One more thing if I may. I tried to move the templates to a separate template file like you did via this:
I put that in the Raw configuration editor and when I try to save it I get the following error:
Unable to parse YAML: YAMLException: unknown tag !<!include> at line 3, column 76: ... ttons/button_card_templates.yaml ^
I have used the !include in the main configuration file with no issues. Do I need to do something special here for HA to recognize the macro?
tbh, I dont know, I dont use the Raw config editor, but use yaml mode.
speaking of which, my main setting in configuration.yaml is:
lovelace:
mode: yaml
resources: !include /config/lovelace/resources.yaml
dashboards:
etcetc
but I don’t think that has anything to do with the error you see. Of course, the folder name and the path need to be exactly the same, are you sure you have done that alright?
Ok, I am going NUTS! I almost have this how I want it. - the fact the Street does not do ST and the STATE does not do a two letter. My malfunction is I CAN NOT get the line after the <br> to justify start like the line before!
so code is this…
ln1: |
return `<img
src='https://developers.google.com/maps/images/maps-icon.svg'
style="width:12px;height:12px">
</ha-icon> ${states['sensor.g3_1_iphone'].attributes.Street}, ${states['sensor.g3_1_iphone'].attributes.City}<br>${states['sensor.g3_1_iphone'].attributes.State}, ${states['sensor.g3_1_iphone'].attributes['Postal Code']}`
And this code is whats sposta tell it to all align to start.
ln1:
- font-size: 11px
- align-self: start
- justify-self: start
- padding-botom: 4px
instead, the outcome is like this…
icon Street Name, City Name
FullStateName, Zip
This is the whole code incase someone wants to use it. Really nice looking card - the kink above…
entity: person.g3_1
show_icon: false
show_name: true
aspect_ratio: 1/1
styles:
card:
- background-color: transparent
- border-radius: 10%
- padding: 14%
- font-size: 10px
- text-shadow: 0px 0px 5px black
- text-transform: capitalize
grid:
- grid-template-areas: '"n n""i i""zone zone""battery battery""ln1 ln1"'
- grid-template-rows: 1fr min-content min-content min-content min-content
name:
- font-weight: bold
- font-size: 12px
- align-self: start
- justify-self: middle
custom_fields:
zone:
- font-size: 12px
- self-start: center
- align-self: center
- padding-bottom: 4px
battery:
- entity: sensor.g3_1_iphone_12_pro_max_battery_state_2
- font-size: 12px
- '--text-color-sensor': >-
[[[ if (states["sensor.g3_1_iphone_12_pro_max_battery_state_2"].state
<= 20) return "red"; ]]]
ln1:
- font-size: 11px
- align-self: start
custom_fields:
i: |
<img width= 38% src='/local/images/me_g3-1.png'>
zone: |
if (states['person.g3_1'].state ='Home')
return `<ha-icon
icon="mdi:google-maps"
style="width:12px;height:12px;color:SteelBlue">
</ha-icon><span> <span style="color: var(--text-color-sensor);">${states['person.g3_1'].state}</span></span>`
else
return `<ha-icon
style="width:12px;height:12px;color:DarkOrange">
battery: |
if (states['device_tracker.g3_1_iphone_12_pro_max_2'].attributes.battery_status.state =='Charging')
return `<ha-icon
icon="mdi:battery-charging"
style="width:12px;height:12px;color:lime">
</ha-icon><span> <span style="color: var(--text-color-sensor);">${states['sensor.g3_1_iphone_12_pro_max_battery_state_2'].state}%</span></span>`
else
return `<ha-icon
icon="mdi:battery"
ln1: |
return `<img
@portigui, the raw configuration editor does not support !include. You have to do your dashboard in yaml mode for that feature. I don’t know why they don’t support that feature in GUI mode. I wish they did.
@G3GhostTech, have you tried using - text-align: left?
You can also use the browser’s developer pane (usually F12 to turn it on) to examine the styling being applied and experiment with different styling.
Side note, did you intend to have </ha-icon> in your ln1 definition? It may not be causing any problem, but it’s not doing anything. Also, the extra <span>...</span> is redundant and can be removed.
Help with variable.
I have some custom fields that i would like to move to an template.
custom_fields:
sensor_1: "[[[ return `${states['sensor.hallway_mirror_power'].state} W` ]]]"
Is there a way to change the above “return statement” to replace the part “hallway_mirror” with a variable? so i can use the same template for multiple buttons with minimal code in the card.
like a variable i set in the card:
variables:
var_sensor_name: "hallway_mirror"
custom_fields:
sensor_1: "[[[ return `${states[ variables.var_sensor_name + '_power' ].state} W` ]]]"
Thanks Keith. That coding is also exactly what I need to turn my Thermostat into a template. (I only have one thermostat currently, but I’d hate to have to duplicate all that code if I ever change to a split-level / double-stat system.)
On a completely different aspect, is there anyway to retrieve the icon associated with a zone for display on a card? Of course, if it’s the entity listed on the card, that’s easy and automatic, but on my “family presence” card, the primary entity is our combined status. I’d like to not only show the text of where we are, but also the associated icon.
Any ideas?
I haven’t done anything with zones. If you find out, let me know
Thank you very much.
I had to add "‘sensor.’ + " to it but your example guided me in the right direction.
sensor_1: "[[[ return `${states[ 'sensor.' + variables.var_sensor_name + '_power' ].state} W` ]]]"
My “status” buttons made with template and variables, makes it easy to add multiple buttons.
Yaml for the cards:
cards:
- type: horizontal-stack
cards:
- type: custom:button-card
template: shelly_plug_s
entity: light.hallway_mirror
variables:
var_name: "Hallway Mirror"
var_label: "Shelly Plug S - 01"
var_double_tap_entity: "sensor.hallway_mirror_power"
entity: light.bedroom_window
variables:
var_name: "Bedroom Window"
var_label: "Shelly Plug S - 02"
var_double_tap_entity: "sensor.bedroom_window_power"
var_sensor_name: "bedroom_window"
Yaml for the template:
shelly_plug_s:
show_label: true
show_entity_picture: true
entity_picture: "/local/lovelace/home/shelly_plug_s.png"
name: '[[[ return variables.var_name ]]]'
label: '[[[ return variables.var_label ]]]'
tap_action:
action: none
double_tap_action:
action: more-info
entity: '[[[ return variables.var_double_tap_entity ]]]'
hold_action:
action: toggle
custom_fields:
sensor_label_1: '[[[ return "POWER:" ]]]'
sensor_label_2: '[[[ return "CURRENT:" ]]]'
sensor_2: "[[[ return `${states[ 'sensor.' + variables.var_sensor_name + '_energy' ].state} kWh` ]]]"
sensor_label_3: '[[[ return "TEMP:" ]]]'
sensor_3: "[[[ return `${states[ 'sensor.' + variables.var_sensor_name + '_device_temperature' ].state} °C` ]]]"
sensor_label_4: '[[[ return "FW UPDATE:" ]]]'
sensor_4: "[[[ return `${states[ 'binary_sensor.' + variables.var_sensor_name + '_firmware_update' ].state}` ]]]"
styles:
card:
- padding: 5px 15px
- background: 'linear-gradient(rgba(255,255,255,0.1) 25%, rgba(0,0,20,0.3)50%)'
- border-radius: 15px
- border: 'solid 3px var(--button-card-light-color)'
- color: ivory
name:
- text-transform: uppercase
- color: white
- font-weight: bold
- font-size: 80%
- padding: 15px 0px 0px 0px
label:
- color: white
- font-weight: bold
- padding: 5px 0px 0px 0px
img_cell:
- align-items: middle
grid:
- grid-template-areas: '"n n" "i i" "l l" "sensor_label_1 sensor_1" "sensor_label_2 sensor_2" "sensor_label_3 sensor_3" "sensor_label_4 sensor_4"'
- grid-template-rows: min-content 1fr min-content min-content min-content min-content min-content
custom_fields:
sensor_label_1:
- font-size: 13px
sensor_1:
- justify-self: end
- font-size: 13px
sensor_label_2:
- font-size: 13px
sensor_2:
- justify-self: end
- font-size: 13px
sensor_label_3:
- font-size: 13px
sensor_3:
- justify-self: end
- font-size: 13px
sensor_label_4:
- font-size: 13px
sensor_4:
- justify-self: end
- font-size: 13px
@Mariusthvdb Many thanks for all the info. I stopped using storage mode and am only using yaml mode. I was able to get everything working with your advise. I even got everything decluttered.
Much obliged for the time you gave me.
