Function Fetch (cross-fetch/polyfill)
I found some javascript that uses the function called fetch.
When I try to use in a node it gives me an error.
I tried adding this to my settings.js
functionGlobalContext: {
fetch:require(“cross-fetch/polyfill”),
// os:require(‘os’),
// jfive:require(“johnny-five”),
// j5board:require(“johnny-five”).Board({repl:false})
But that just gave a config error
Then I thought I need to install it.
“npm install fetch-polyfill --save”
That works fine - but the issue is that when the container is restarted in HA, the container is reset. So an “in-container” install won’t work.
What can I do ?
Add fetch-polyfill to the npm section on the nodered configuration page inside the addon.
Okay - I did that
npm_packages:
  - fetch-polyfill
Still I am getting the error
TypeError: fetch is not a function
If I change the settings.js Node Red still won’t start.
You can try the full command npm install fetch-polyfill under the init section but leave off --save
Same error. Maybe I am doing my JS wrong.
fetch = global.get("fetch")
fetch('https.........
