Future options for the energy dashboard
While germany is on it’s way to transform the energy market, Hydrogen, fuel cell and electrolyser - technologies become more and more important.
Now, I found a solution, which will use the energy created by your solar installation and creates hydrogen from whater - wich will then be stored.
In the Winter, when your solar installation becomes less important, this installation will use the saved hydrogen and with a fuell cell, it will create electricity (and heat again).
Sure - this technology is at the moment rarely used - because it is still very expensive, but It would be great if the energy dashboard can be prepared for such technology.
I think, an important step into the transformation into a new era of energy distributon is to support people and get as much into the energy dashboard as possible.
For Example, I am also missing the option to add Wind turbines into the energy dashboard… this should be possible by adding them “as a solar collector” but then, it might be a bit misleading.
Changes:
Rename “Sun collectors” into “Power generators”,
Allow the integration of different types of generators, such as Wind Turbines, Solar installations, and other, future technologies (Hydrogen, etc)
Add Oil usage for heating like it is possible for gas…
Add Battery powerd vehicles (at least charging) - maybe with information how much energy has been used from solar, battery or grid for the charging
Other possibilities and ideas for the energy dashboard are very welcome :slight_smile:
I also need the option to add wind turbine generation to the Energy dashboard. We need to change the current ‘Solar Panels’ area to become ‘Electricity Production’ with different types of production i.e. Solar, Wind, Hydro, etc
There’s another reason. The conversion efficiency from solar → electricity → hydrogen → electricity is terrible.
I know that it is terrible - and doesn’t really make sense at all…
But it is, how it is and it is a set goal from our politicians …
So I think, it will play a role in the future … so why not prepare and be ready for it :slight_smile: :wink:
If you are off-grid or aiming for 100% autarky, the conversion efficiency is less important if you live at a high enough latitude that seasonal energy storage is important. Say you want to store 30 days of consumption. I consume about 30 kWh per day, so that is 900 kWh of usable energy which would require about 1.2 MWh of lithium battery (assuming a 30% reserve to protect the battery) or 2MWh of H2 Storage (assuming a fuel cell conversion efficiency of 50%).
Enapter claims 62.5% efficiency for their electrolyzer, but, after compression, let’s assume the hydrogen production efficiency is more like 50%.
So what does that mean? At 25% round trip efficiency, four times the number of solar panels are required to produce energy in the summer to then store for use in the winter as compared to using battery storage.
So now the comparison is the cost of 1.3 MWh of battery storage + the cost of, say 10kWp of PV vs. 2 MWh of H2 storage + the cost of 40kWp of PV panels.
When I did this comparison a few years ago, the battery storage solution was significantly more than cost of hydrogen storage. It would be interesting to compare now.
+1 on this. I am operating a fuel-cell (Viessmann PT2, powered by gas) that generates around 15kWh of electricity during the winter. I don’t have a solar, but I’m using that option in Energy dashboard to get generated electricity captured and displayed in my graph. It seems to work quite well, the only issue is that shows up as “Solar”, and there is no way to customize it.
