What is the best way to go about getting FV-11VHL2 Panasonic switch on HA.
Is it Aeon micro switch a good solution to drive all Heat/Fan/Light/Night-Light 4 Function On/Off Switch?
I am not familiar with Aeon micro switches, and I am trying to figure out if I need to setup some sort of access box for three or four of these micro switches so that I can connect them to these four functions.
I am using this switch to control FV-11VH2 WhisperWarm Fan/Heater Combination, Ventilation Fan in bathroom …
Much appriciated
Did you ever find something to do with this?
I’m looking at buying the similar Panasonic WhisperSense Ceiling Mount Bathroom Exhaust Fan with LED Light, Motion & Humidity Sensors, 50-80-110 CFM, FV-0511VQCL1 https://www.supplyhouse.com/Panasonic-FV-0511VQCL1-Panasonic-WhisperSense-Ceiling-Mount-Bathroom-Exhaust-Fan-with-LED-Light-Motion-Humidity-Sensors-50-80-110-CFM-FV-0511VQCL1
Edit – I see in the WhisperGreen series they also sell Panasonic FV-CSVK1 humidity module which can be connected directly to fans like Panasonic FV-0511VK2, and senses 30% - 80% humidity. I guess that’s better than a smart home integration, unless the tracking is desired. Or using for example implementing seasonal adjustment (e.g. set 30% during winter and 55% during summer). The fact this is a simple module that can be connected/disconnected to the fan makes me wonder whether an external system could be easily connected, too, with Matter connectivity for that tracking and control.
