so I had this working in the first MQTT release, but for some reason my BI box is constantly connecting and disconnecting. I have a log full of connected OK, and when I test the MQTT connection I get hundreds of connect failed (0)
Disconnect OK
and so on - anyone else having issues? i’m wondering if there is a way to rename the client_ID of the BI MQTT server?
Same here. I thought it might have been an issue with HA’s builtin MQTT server but I installed Mosquitto on my BI server and saw the exact same issue. So my guess is that the BI MQTT client is causing the flood of disconnect OK messages.
I rolled back a version and works fine. I alerted BI tech support, but works on the previous version.
Ah ok! What version are you on? Looks like BI 4.7.2.4 came out today and I updated. Haven’t tested with it so I wonder if it might be fixed there(?).
This behavior still exists in 4.8.4.6. In addition blueiris CPU climbs significantly when the MQTT borker is unavailable, I assume due to the constant MQTT Ping attempts.
