I have zigbee2mqtt with Mosquitto as broker on a Sonoff 3.0. I am able to discover my IKEA blinds after pairing them, and battery levels are reported in both zigbee2mqtt and HA. However, the blinds won’t respond to open, close, or cover position. Example error:
2024-04-22 19:41:27Failed to configure 'TV Left Blind', attempt 2 (Error: {"address":44543,"clusterId":32801,"sequence":16} after 10000ms at Object.start (/app/node_modules/zigbee-herdsman/src/utils/waitress.ts:63:23) at Driver.zdoRequest (/app/node_modules/zigbee-herdsman/src/adapter/ezsp/driver/driver.ts:692:43) at /app/node_modules/zigbee-herdsman/src/adapter/ezsp/adapter/ezspAdapter.ts:574:13 at Queue.execute (/app/node_modules/zigbee-herdsman/src/utils/queue.ts:35:20) at Endpoint.bind (/app/node_modules/zigbee-herdsman/src/controller/model/endpoint.ts:469:13) at Object.bind (/app/node_modules/zigbee-herdsman-converters/src/lib/reporting.ts:43:9) at Object.configure (/app/node_modules/zigbee-herdsman-converters/src/devices/ikea.ts:910:13) at Configure.configure (/app/lib/extension/configure.ts:122:13) at Configure.onMQTTMessage (/app/lib/extension/configure.ts:55:21) at EventEmitter.wrappedCallback (/app/lib/eventBus.ts:174:17))
I previously was using the Sonoff with ZHA, but wanted to make the switch to zigbee2mqtt. I’ve deleted ZHA from HA. Mentioning that in case it is relevant.
Any help greatly appreciated!
