Gap between heading card in section
Hi, I’m trying to group, in the same section, several types of cards related to the same hardware. But I’m facing a problem with the gap/vertical space between heading card in the same column. Have a look on the picture attached. Section A & B are identical In Section A, the column containing 2 tile cards and 2 heading cards have a “normal” vertical gap/space in between. On the other hand, for the section B, the column containing one more heading card. And here the gap/vertical space becomes the double. How can I keep the gap/vertical space constant to “normal” to have possibility to add more tile or heading cards and still be aligned with the bottom of the thermostat card ?
Thanks for your help.
Laurent
