I’m in the process of trying to simplify my configuration by breaking my cards out into individual files that can then be included into different views. This is working fine until I got to a view with multiple gap cards with different heights. My thought was to use a variable entity (var.gap_card_height) to set the height in the card but unfortunately it doesn’t seem to be working. If I create a view with the following:
- type: custom:gap-card
height: 13
- type: entities
entities:
- var.gap_card_height
height: var.gap_card_height
A gap card with the hard coded value is inserted, followed by an entity card with gap card height 25
, but then there is no gap card between this and the next card. No errors or warnings, just a fully rendered page without the second gap card. Should this not work?
