I have 2 devices in my configuration.yaml that control my garage doors with the Garadget Platform. It stopped working today and I’m seeing a lot of timeouts to api.particle.io however I can connect to that host with the correct port with no issues from the same machine. Any ideas? It says the domain was actually setup but took 12 seconds, however the devices are no longer showing up in my dev-state area. Is this timeout configurable?
2018-10-25 18:09:12 ERROR (MainThread) [homeassistant.components.cover] Error while setting up platform garadget
File "/usr/local/lib/python3.6/site-packages/urllib3/connectionpool.py", line 384, in _make_request
six.raise_from(e, None)
File "<string>", line 2, in raise_from
File "/usr/local/lib/python3.6/site-packages/urllib3/connectionpool.py", line 380, in _make_request
httplib_response = conn.getresponse()
File "/usr/local/lib/python3.6/http/client.py", line 1331, in getresponse
response.begin()
File "/usr/local/lib/python3.6/http/client.py", line 297, in begin
version, status, reason = self._read_status()
File "/usr/local/lib/python3.6/http/client.py", line 258, in _read_status
line = str(self.fp.readline(_MAXLINE + 1), "iso-8859-1")
File "/usr/local/lib/python3.6/socket.py", line 586, in readinto
return self._sock.recv_into(b)
File "/usr/local/lib/python3.6/ssl.py", line 1009, in recv_into
return self.read(nbytes, buffer)
File "/usr/local/lib/python3.6/ssl.py", line 871, in read
return self._sslobj.read(len, buffer)
File "/usr/local/lib/python3.6/ssl.py", line 631, in read
v = self._sslobj.read(len, buffer)
socket.timeout: The read operation timed out
File "/usr/local/lib/python3.6/site-packages/requests/adapters.py", line 445, in send
timeout=timeout
File "/usr/local/lib/python3.6/site-packages/urllib3/connectionpool.py", line 638, in urlopen
_stacktrace=sys.exc_info()[2])
File "/usr/local/lib/python3.6/site-packages/urllib3/util/retry.py", line 367, in increment
raise six.reraise(type(error), error, _stacktrace)
File "/usr/local/lib/python3.6/site-packages/urllib3/packages/six.py", line 686, in reraise
raise value
File "/usr/local/lib/python3.6/site-packages/urllib3/connectionpool.py", line 600, in urlopen
chunked=chunked)
File "/usr/local/lib/python3.6/site-packages/urllib3/connectionpool.py", line 386, in _make_request
self._raise_timeout(err=e, url=url, timeout_value=read_timeout)
File "/usr/local/lib/python3.6/site-packages/urllib3/connectionpool.py", line 306, in _raise_timeout
raise ReadTimeoutError(self, url, "Read timed out. (read timeout=%s)" % timeout_value)
urllib3.exceptions.ReadTimeoutError: HTTPSConnectionPool(host='api.particle.io', port=443): Read timed out. (read timeout=10)
File "/usr/local/lib/python3.6/site-packages/homeassistant/helpers/entity_platform.py", line 128, in _async_setup_platform
SLOW_SETUP_MAX_WAIT, loop=hass.loop)
File "/usr/local/lib/python3.6/asyncio/tasks.py", line 358, in wait_for
return fut.result()
File "/usr/local/lib/python3.6/concurrent/futures/thread.py", line 56, in run
File "/usr/local/lib/python3.6/site-packages/homeassistant/components/cover/garadget.py", line 68, in setup_platform
covers.append(GaradgetCover(hass, args))
File "/usr/local/lib/python3.6/site-packages/homeassistant/components/cover/garadget.py", line 102, in __init__
self.update()
File "/usr/local/lib/python3.6/site-packages/homeassistant/components/cover/garadget.py", line 227, in update
status = self._get_variable('doorStatus')
File "/usr/local/lib/python3.6/site-packages/homeassistant/components/cover/garadget.py", line 252, in _get_variable
ret = requests.get(url, timeout=10)
File "/usr/local/lib/python3.6/site-packages/requests/api.py", line 72, in get
return request('get', url, params=params, **kwargs)
File "/usr/local/lib/python3.6/site-packages/requests/api.py", line 58, in request
return session.request(method=method, url=url, **kwargs)
File "/usr/local/lib/python3.6/site-packages/requests/sessions.py", line 512, in request
resp = self.send(prep, **send_kwargs)
File "/usr/local/lib/python3.6/site-packages/requests/sessions.py", line 622, in send
r = adapter.send(request, **kwargs)
File "/usr/local/lib/python3.6/site-packages/requests/adapters.py", line 526, in send
raise ReadTimeout(e, request=request)
requests.exceptions.ReadTimeout: HTTPSConnectionPool(host='api.particle.io', port=443): Read timed out. (read timeout=10)
2018-10-25 18:09:13 INFO (MainThread) [homeassistant.setup] Setup of domain cover took 12.0 seconds.
