I wasn’t paying attention and it seems that one of the last 3 releases has somehow changed the way my garage door cover reports through the UI. I use a Shelly One+ with the following code in my configuration.yaml file:
template:
- sensor:
- name: "Garage Door Sensor"
state: >
{% if is_state('binary_sensor.shelly_garage_sensor', 'on') and is_state('switch.shelly_garage_relay', 'on') %}
opening
{% elif is_state('binary_sensor.shelly_garage_sensor', 'off') and is_state('switch.shelly_garage_relay', 'on') %}
closing
{% elif is_state('binary_sensor.shelly_garage_sensor', 'off') %}
open
{% else %}
closed
{% endif %}
cover:
covers:
garage_door_cover:
device_class: garage
unique_id: garage_door_shelly_01
friendly_name: "Garage Door"
value_template: "{{ states('sensor.garage_door_sensor') }}"
open_cover:
- condition: state
entity_id: sensor.garage_door_sensor
state: "closed"
- service: switch.toggle
entity_id: switch.shelly_garage_relay
close_cover:
- condition: state
state: "open"
stop_cover:
icon_template: >-
{% if is_state('cover.garage_door_cover', 'opening') or is_state('cover.garage_door_cover', 'closing') %}
mdi:garage-alert
{% elif is_state('cover.garage_door_cover', 'open') %}
mdi:garage-open
{% else %}
mdi:garage
{% endif %}
Using developer tools, I confirmed that the states are, in fact, updating – at least ‘open’ and ‘closed’ (can’t confirm ‘opening’ and ‘closing’).
On my dashboard, I have the following custom button card:
type: custom:button-card
entity: cover.garage_door_cover
show_entity_picture: true
styles:
icon:
- width: 50%
- color: rgb(50,200,255)
card:
- height: 120px
tap_action:
action: call-service
service: automation.trigger
service_data:
entity_id: automation.toggle_garage
skip_condition: false
The icon used to update to “opening” or “closing” briefly based on the relay state, and then settle to “open” or “closed”, appropriately. Now, it just shows the “closed” state at all time (even though the door may be open).
The garage door works just fine - the problem seems to be with the dashboard logic. Again, I’m sure I missed something in a release note but I’m having difficulty figuring out the issue.
