Hi
I just migrated to Home Assistant 0.106.0 and the garage door icon will not show open when it IS open. It always shows closed. I’m using sonoff SV with read switch. All the sonoff functions and relay reset automation is working fine. Even the “arrows” switch direction. You can see the color even changes to yellow because I added the state_color: true to toggle on/off, but meaning open = yellow, blue = closed as an added feature. BUT THE GARAGE DOES NOT SHOW OPEN…dang? Any Help Please. See picture. The garage is open as I type this. When I close it by tapping the highlighted down arrow, the garage turns blue and the arrows switch highlighted colors.
Hi, yes I did that, it acts the same. Does not open, but changes color when the garage door hits the read switch to show open and the arrows switch direction like they should. Do you think it’s in the mqtt commands or in the HA system? I added that manually to the config.yaml file too.
cover:
if it reacts to state change by changing icon’s colour, MQTT seem to work - looks like UI issue.
Did it work before the update?
Is it he only binary sensor that behaves weird?
You could create a template binary sensor controlled by input_boolean and see if it behaves differently (changes its icon) to debug it.
I wish I knew how to make the template. I saw some on another post, I just get confused on where to put it and line it up in the yaml. And I had a really old version before and it worked fine. It’s weird right? I would assume others would be having the issue too. Thanks to you for getting back to me.
Opps, see, I don’t know how to add to yaml very well yet. I will keep trying. Must be formatting or something
Invalid config for [input_boolean]: expected dictionary for dictionary value @ data[‘input_boolean’]. Got [‘test_icon’]. (See /config/configuration.yaml, line 77).
Invalid config for [binary_sensor]: required key not provided @ data[‘platform’]. Got None. (See /config/configuration.yaml, line 80).
yeah…
to add it to UI if you use Lovelace:
click three dots (top-right) and select configure, then + (right-bottom) and select “Entities”)
Select your entity from the list.
Now … I go to have some sleep as I need it.
Well, seems like your customisation plays up.
Post here anything that is related to your non-working sensor.
