I’ve adjusted it slightly so that it immediately notifies when the garage door is open, waits the defined period of time, and announces immediately when the garage door is closed.
blueprint:
name: Garage Door open TTS announcer
domain: automation
input:
monitored_entity:
description: Entity that causes announcement
selector:
entity:
domain: cover
device_class: garage
speaker_target:
description: Entity to announce event on
selector:
entity:
domain: media_player
announcement_message:
description: What to say when door is opened
final_message:
description: What to say when door is closed
cooldown:
description: The minimum time needed in between announcements
default: 10
selector:
number:
min: 0.0
max: 600.0
unit_of_measurement: seconds
mode: slider
step: 1.0
source_url: https://community.home-assistant.io/t/door-open-tts-announcer/266252
mode: single
platform: state
entity_id: !input 'monitored_entity'
to: 'open'
- alias: Repeat the sequence UNTIL the door is closed
repeat:
sequence:
- service: tts.google_translate_say
target: !input 'speaker_target'
message: !input 'announcement_message'
- wait_for_trigger:
- platform: state
to: 'closed'
for: 10
timeout: !input 'cooldown'
until:
- condition: state
state: 'closed'
message: !input 'final_message'
I closed the door 5 minutes ago and have it reporting every 14 seconds and it keeps going off even know the door has been closed. I am using a contact sensor on my door that goes into my garage.
I assume the device shows as a ‘cover’ with ‘open’ and ‘closed’ states… I know this one works for me and my 2 garage doors, but if you’re using it with another type of sensor (such as binary or door) then it’ll probably not react as expected.
Hi doughecka, great Blueprint. I think you need to do an update for the ‘tts.google_say’ integration to the now used ‘tts.google_translate_say’. My automation is getting an error with the ‘tts.google_say’.
I was just trouble shooting this blueprint for my father in law and realized why he was having issues with it… I believe that at some point the service tts.google_say was changed to tts.google_translate_say.
If anyone else is having issues with this blueprint on newer versions of HA you most likely just need to copy the BP file into a new location and change the google_say to google_translate_say
I’ve adjusted the blueprint to use google_translate_say instead of google_say, however that did require that I change my configuration.yaml to use google_translate_say.
And side note, in my opinion, google_translate_say doesn’t sound as good as google_say… Not sure why the difference. Same voice, but it’s not as ‘smooth’.
Sorry, didn’t see your reply. I’m running the latest version as of a few days ago, 2021.12.0
What’s confusing is that the documentation references both ways:
The extended example near the beginning of the page shows google_say, but other examples show google_translate_say.
Maybe this is because I’ve got my google API account setup to support both methods? Or I’ve had it for so long that I have a feature/service that’s not available any longer?
