I was following dr zzzs tutorial on using a sonoff sv to toggle a garage door opener and add a reed switch and sonic presence sensor. It was going great until I had the idea to toggle the light separately for the door that didn’t get opened. I just have to short the same to wires on the opener with a capacitor inline. (Bonus points if any one can explain that. I thought it would be a resistor.) Problem is the project uses up gpio 4,5,14 that have pins on the board. Is there any more gpio pins that are maybe less accessible on this board? I was thinking the holes above the gpio block, or can I get to one by removing one leds maybe? I’d be willing to remove scrap one of those off to hack my way to another gpio pin. Then I could maybe use a something like this to do the other 12v circuit for the light.
https://www.amazon.com/ICStation-Optocoupler-Trigger-Development-Arduinoo/dp/B07P73PHQY
If there’s no other gpio pins available I’m open to other board suggestions that have 3 gpio pins for the sensors and 2 dry contact relays for the opener and light circuits.
