Dinoaus
(John Dean)
June 5, 2019, 10:29am
1
I have the following YAML file for my garage door. The problem I am having is that the state of the cover in home assistant is being reported as “OPENING” and “CLOSING” instead of “OPEN” and “CLOSE”. Can anyone see a problem with this?
I had it working with MQTT, then decided to use the ESPHOME API instead, now having the issue.
switch:
- platform: gpio
pin: D1
name: "Garage Door Switch"
binary_sensor:
- platform: gpio
pin:
number: D5
mode: INPUT_PULLUP
name: "Garage Reed Switch"
filters:
- delayed_on: 1000ms
- delayed_off: 1000ms
cover:
device_class: garage
lambda: |-
if (id(garage_status).state) {
return COVER_OPEN;
} else {
return COVER_CLOSED;
open_action:
- switch.turn_on:
- delay: 1s
- switch.turn_off:
close_action:
- switch.turn_on:
- delay: 1s
- switch.turn_off:
stop_action:
- switch.turn_on:
- delay: 1s
- switch.turn_off:
Dinoaus
(John Dean)
June 7, 2019, 3:55am
2
Fixed. Had to set the current operation to IDLE.
therm0
(Justin)
June 8, 2019, 2:02am
3
How did you do that? Can you post the updated version of your YAML for folks (like me) who can’t for some reason wrap their head around the documentation?
Dinoaus
(John Dean)
June 8, 2019, 4:55am
4
This is my current YAML.
esphomeyaml:
platform: ESP8266
board: d1_mini
wifi:
ssid:
password:
api:
password:
# Enable logging
logger:
level: NONE
ota:
password:
switch:
- platform: gpio
pin: D1
binary_sensor:
- platform: gpio
pin:
number: D5
mode: INPUT_PULLUP
filters:
cover:
lambda: !lambda |-
id(garage_door).current_operation = esphome::cover::COVER_OPERATION_IDLE;
return COVER_OPEN;
} else {
open_action:
- lambda: !lambda |-
if (!id(garage_status).state) {
id(garage_switch).turn_on();
delay(500);
id(garage_switch).turn_off();
close_action:
delay(500);
stop_action:
- switch.turn_off:
- switch.turn_on:
- delay: 1s
- switch.turn_off:
Crewski
(David Naylor)
June 10, 2019, 6:26pm
5
Thanks for this. I’m about to implement a garage door opener (previously wrote my own code) and I like your lambdas in the open/close actions. Checking to see if it is open first or not is great!
