My first post to the forum. I’m a SmartThings user working to migrate to Home Assistant. I’ve made some 120db 12v Sonoff Sirens, Sonoff lighting projects and a Sonoff Garage Door Opener. I’m trying to solve another challenge. I currently have a PIR motion sensor that triggers a bell in the house, a std driveway motion detector. It drives me nuts hearing it all day and night as it detects the critters that wander through the yard. I have a gated driveway entry so I don’t really need a wide area to be monitored, only a narrow channel. I would like to set up a light beam which will have a much more specific trigger. I was thinking I could use the infra red garage door sensor eyes to trigger GPIO pins on an ESP86xx board. This way I could define a beam that needs to be broken at say 3 or 4 ft above groung and would eliminate the alerts for the animals in the yard. I was hoping to get some pointers and direction from the vast experience the forum members. Any advice would be great!
I wanted a sensor to notify me when my car was past the door. I bought a NPN laser emitter / sensor and used an ESP32 dev board with esphome. I haven’t installed it yet, but the setup tests fine.
I researched using the garage door sensors and it seemed that it would be more complicated.
@ceh I/we would be interested in how you pinned the NPN laser/sensor to the ESP32. Would you mind sharing your pinout/setup? I found this photoelectric beam sensor on Amazon and thought it could be a candidate for this type of project. I contacted the mfg and they confirmed that it should work based on NC/NO configuration.
In my initial post I wrote that I was using an ESP32. I was wrong, it’s an ESP8266. I have the sensor on pin 16. There’s also a relay on pin 5 to control the door opener and a light on pin 12 that comes on when the doorway is clear. I’ve copied the esphome yaml below.
Curious, is this a garage safety sensor that has 2 wires? I’ve been attempting to get mine to work with an ESP8266 board with no success.
If the above is correct, did you just connect one wire of the sensor to a GPIO pin 16?
