I am using the garage door templates to control my two garage doors on an Insteon I/O link.
I have condition statements for both open and closed to check the sensors (sensors are OFF in the closed position and ON in any other position.)
I am trying to get the UI to block control of opening the door when it is open, and closing the door when it is close.
I would also like it to only allow the stop command within 10 seconds of either the open or closed commands.
The “script.large_garage_door_trigger” triggers the I/O link relay for 1 second and then turns it off.
Is this not working? Not sure if you’re just stating this or whether there’s a problem.
Add a template condition to the stop action and check the last_updated property of the cover entity itself. If that doesn’t work, make an input_datetime helper to save the last opened or closed trigger and then check that in the template condition.
It is not working, I was under the impression that the UI would automatically block based off of the position sensor, I am not sure If I have the sensor implemented correctly.
My template covers correctly disables the right buttons depending on the state of the cover.
Does the value of binary_sensor.io_linc_sensor_lgdo change and persist when you open or close the garage door?
Are there any errors in your log?
I don’t think it will provide additional info that’s of value to debug this, but could you show the config for script.large_garage_door_trigger nonetheless?
binary_sensor.io_linc_sensor_lgdo Outputs Open or Closed in the corresponding states.
script.large_garage_door_trigger Is a simple script to trigger the relay for 1 second. I have a 14 second delay at the end to prevent it from being triggered multiple times by a bouncing finger.
