Garage Door Template Trouble
Hi all,
I used a shelly 1 to automate my garage but i’m having a really tough time getting this to show up as a cover in HA. I got this code to work when I inserted it into my config.yaml, but I can’t get it to work on the split out tempalte.yaml file. Any ideas? this is the code in my template. yaml file
cover:
  - name: "TEST Garage Door 2"
    state: "{{ states('binary_sensor.swgaragehoop_input') }}"
    device_class: opening
    open_cover:
      service: switch.toggle
      entity_id: switch.swgaragehoop
    close_cover:
    stop_cover:
    icon: >-
      {% if states('binary_sensor.swgaragehoop_input') == "on" %}
        mdi:garage-open
      {% else %}
       mdi:garage
      {% endif %}
this is the error i get:
Invalid config for [template]: [cover] is an invalid option for [template]. Check: template->cover. (See /config/configuration.yaml, line 13).
If you added it to your template.yaml file it would become
template:
cover:
if you create a cover.yaml and place the code in the file, then do a cover: !include cover.yaml in you configuration.yaml does this fix.
See here: Template Cover - Home Assistant
Cover hasn’t been moved to the non-legacy style configuration.
cover:
  covers:
    test_garage_door_2:
Thanks Petro.
so my config.yaml says:
My cover.yaml has:
cover:
  covers:
    test_garage_door_2:
      open_cover:
      close_cover:
      stop_cover:
      icon: >-
          mdi:garage-open
        {% else %}
          mdi:garage
        {% endif %}
when i try and validate the config.yaml file i get:
Validate your configuration if you recently made some changes to your configuration and want to make sure that it is all valid.
Configuration invalid
Invalid config for [cover]: required key not provided @ data[‘platform’]. Got None. (See /config/configuration.yaml, line 16).
any ideas? I’m assuming i have bad syntax or format somewhere, because it works fine when it’s imbedded in the config.yaml file.
yes, because your file contains the field cover: in it. Your include already specifies that. What you’re feeding home assistant is:
cover:
  cover:
    covers:
when you use include…
already has field.
so your contents shoudl start…
Secondly, review the template cover docs. You’re mixing old style and new style fields in your configuration (state should be value_template)
Petro, thanks so much for your help, it worked! I used the new syntax for my last template (the one with “state”) but this one as you said needed the older syntax (i.e. “value_template”).
Is that because for the first template, that i did for a sensor, i used Template.yaml, instead of sensor.yaml? Where as this time I used the template in the cover.yaml file?
It’s because there’s 2 formats. The old way and the new way. The new way supports triggers and other new fields like state_characteristic (for sensors). The old way is just how it used to be done. The new way was developed specifically to handle triggers as an optional method to update sensor states.
I appreciate the color.
Just to close the loop and to show the resolved code. Thanks again Petro. This is all good to go now in my cover.yaml file.
  covers:
    garage_door_hoop:
      friendly_name: 'Garge Door - Hoop'
      value_template: "{{ states('binary_sensor.swgaragehoop_input') }}"
      open_cover:
      close_cover:
      stop_cover:
      icon_template: >-
        {% if states('binary_sensor.swgaragehoop_input') == 'on' %}
          mdi:garage-open
        {% else %}
          mdi:garage
        {% endif %}
    garage_door_house:
      friendly_name: 'Garge Door - House'
      value_template: "{{ states('binary_sensor.swgaragehouse_input') }}"
      open_cover:
          entity_id: switch.SwGarageHouse
      close_cover:
      stop_cover:
      icon_template: >-
        {% if states('binary_sensor.swgaragehouse_input') == 'on' %}
          mdi:garage-open
        {% else %}
          mdi:garage
        {% endif %}
FYI you don’t need the icon_tempalte. Just do
device_class: garage
Best solution, more info Cover - Home Assistant
Also looking for semi open garage for cat :slight_smile: I got two sensor semi open (icon ie mdi:garage-alert-variant) and full open.
Code is full working for someone like me :slight_smile:
captive_portal:
switch:
  - platform: gpio
    pin: D5
    restore_mode: ALWAYS_OFF
    internal: True
binary_sensor:
  - platform: gpio
    pin:
      number: D6
      mode: INPUT_PULLUP
    name: "Garaz vrata I"
    device_class: garage_door
    filters:
      - delayed_on_off: 50ms
    internal: True
  - platform: gpio
    pin:
      number: D7
      mode: INPUT_PULLUP
    name: "Garaz vrata II"
    filters:
    internal: True
cover:
    name: "Ovladani garazove vrat"
    lambda: |-
      if (id(garage_door_1).state) {
        return COVER_OPEN;
      } else if (id(garage_door_2).state) {
        return COVER_OPEN;
      } else {
        return COVER_CLOSED;
    open_action:
      - switch.turn_on: garage_door_relay
      - delay: 0.1s
      - switch.turn_off: garage_door_relay
    close_action:
      - delay: 0.1s
    stop_action:
      - delay: 0.1s
