burg93
(Adam)
November 4, 2022, 1:28pm
202
Hey, Iâm not overly sure what you mean but the scripts can just called from anywhere, just plonk the textbox and number somewhere you can set them and call the script. This is what I use, which creates a veryyyy basic popup via the âbrowsermodâ customer-component with âbutton-cardâ too. Enrol and not Enroll as Iâm in the UK
Could definitely be improved but itâs extremely rare that I need to add/remove a fingerprint now.
type: custom:mushroom-entity-card
entity: script.fingerprint_learning_mode_2
fill_container: true
secondary_info: none
layout: vertical
tap_action:
action: call-service
service: browser_mod.popup
deviceID:
- THIS
title: Enrol a new fingerprint
left_button: Ok
right_button: Cancel
content:
type: vertical-stack
cards:
- type: horizontal-stack
cards:
- type: custom:button-card
icon: mdi:minus
tap_action:
service: input_number.decrement
service_data:
entity_id: input_number.fingerprint_learning_id
styles:
card:
- height: 60px
- width: 60px
- type: markdown
content: |
{{ states('input_number.fingerprint_learning_id') | string }}
icon: mdi:plus
tap_action:
service: input_number.increment
service_data:
styles:
card:
- height: 60px
- width: 60px
- type: entities
entities:
- entity: input_text.id_name
icon: mdi:form-textbox
right_button_action:
service: browser_mod.close-popup
left_button_action:
service: script.fingerprint_learning_mode_2
Jan007
(Jan Landwehrkamp)
November 4, 2022, 6:11pm
203
Thank you very much for the example. Can you tell me what you wrote in the script âscript.fingerprint_learning_mode_2â ?
dariob84
(Dariob84)
November 7, 2022, 9:03am
204
Thank you very much. Please can you share the whole project? card, scriptâŚand more.
burg93
(Adam)
November 7, 2022, 9:10am
206
Itâs just the learning script from my original post. Nothing much in there.
Added an Idle status after each action otherwise you canât trigger an automation between two identical states after eachother as the state wonât get renewed when the same state is send.
So now after each action the satet changes to Idle after 10 seconds.
Below you can find (the complete) code. In case you want this too.
esphome:
esp8266:
board: nodemcuv2
# Enable logging
logger:
uart:
tx_pin: D0
rx_pin: D1
baud_rate: 57600
fingerprint_grow:
sensing_pin: D2
on_finger_scan_matched:
- fingerprint_grow.aura_led_control:
state: BREATHING
speed: 200
color: BLUE
count: 1
- text_sensor.template.publish:
state: "Authorized finger"
- delay: 10s
state: "Idle"
on_finger_scan_unmatched:
state: FLASHING
speed: 25
color: RED
count: 2
state: "Unauthorized finger"
- delay: 10s
state: "Idle"
on_enrollment_scan:
state: FLASHING
speed: 25
color: BLUE
count: 2
state: ALWAYS_ON
speed: 0
color: PURPLE
count: 0
state: "Finger scanned"
- delay: 10s
state: "Idle"
on_enrollment_done:
state: BREATHING
speed: 100
color: BLUE
count: 2
state: "Enrolled fingerprint"
- delay: 20s
state: "Idle"
on_enrollment_failed:
state: FLASHING
speed: 25
color: RED
count: 4
state: "Failed to enroll fingerprint"
- delay: 20s
state: "Idle"
text_sensor:
- platform: fingerprint_grow
fingerprint_count:
last_finger_id:
name: "Fingerprint Last Finger ID"
last_confidence:
name: "Fingerprint Last Confidence"
status:
capacity:
name: "Fingerprint Capacity"
security_level:
name: "Fingerprint Security Level"
# Enable Home Assistant API
api:
encryption:
key: "ThisWasALongKey"
services:
- service: enroll
variables:
finger_id: int
num_scans: int
then:
- fingerprint_grow.enroll:
finger_id: !lambda 'return finger_id;'
num_scans: !lambda 'return num_scans;'
- service: cancel_enroll
then:
- fingerprint_grow.cancel_enroll:
- service: delete
variables:
finger_id: int
then:
- fingerprint_grow.delete:
- service: delete_all
then:
- fingerprint_grow.delete_all:
ota:
password: "ThisWasAVeryLongPassword"
wifi:
ssid: !secret wifi_ssid
ap:
ssid: "Fingerprint Fallback Hotspot"
password: "ThisWAsAPassword"
captive_portal:
stivenpl79
(Stivenpl79)
November 7, 2022, 9:31pm
208
Hi, I bought it, soldered it, programmed it and it works. But I have a problem that when I disconnect my ESP from the power supply, it is visible after reconnecting the ESP, but GROW R503 is not. Nothing is reported. Only uploading .yaml back to ESP helps. What have I missed?
Iâm sorry itâs unclear to me whatâs going on there.
What happens when you reconnect power supply? The esp is fully operational but the r503 seems to not respond to any finger input?
Perhaps you can play around with you gpio pins? Especially with the sensing pinâŚ
I had some strange issues at first when using other gpio pinsâŚwhen I exactly followed the TSâs pins it worked like a charm on my setupâŚ
dariob84
(Dariob84)
November 9, 2022, 6:58am
210
Can you share rename script and rename card? Thank you
burg93
(Adam)
November 9, 2022, 9:24am
211
Itâs the same as the learning card and script above but without the call to the fingerprint reader in the script. All its doing is renaming the name associated with an ID, the reader doesnât know about the name so doesnât need to be called.
rak
(Ralf KlĂźber)
December 15, 2022, 1:53pm
212
Love it. Thanks for your great work. I tried to add a service which scnas a finger in the next free slot. Tried this ⌠not working. Any hints?
- service: enroll_next
variables:
num_scans: int
then:
state: BREATHING
speed: 25
count: 10
color: GREEN
finger_id: !lambda 'return int(fingerprint_count);'
state: BREATHING
speed: 25
count: 10
color: GREEN
fingerprint_count:
parrel
(Parrel)
December 15, 2022, 2:31pm
213
Thatâs really clever, using fingerprint_count!
Whatâs the value of this sensor when you call the service?
Danik
(Daniel)
December 18, 2022, 3:29pm
214
Hi Trying to create Also
have 2 bords D1 mini and ESP32 and grow R503
The Yaml for D1 and ESP 32 is the same?
On the D1 mini and the ESP32 i have only 1 3v and not (2).
Attached my D1 and ESP32
parrel
(Parrel)
December 24, 2022, 2:07pm
216
Iâve moved to an ESP32 to unlock bluetooth possibilities, and updated the post with ESP32 pins.
@Danik If youâre still looking for the pins, they are now in the post.
@rak If youâre still looking for the enroll_next solution, Iâve added it to the original post with the working code, and credits to you
veetek22
(Veetek22)
December 25, 2022, 5:49pm
217
Morning,
Is there a chance to make this sensor glow lets say green while waiting for the scan ? Itâs installed in a really dark area and it would be helpful.
Thank you,
parrel
(Parrel)
December 25, 2022, 6:01pm
218
Yes thatâs possible. You should call this when you boot the ESP, and after every other LED change.
state: ALWAYS_ON
speed: 0
color: GREEN
count: 0
veetek22
(Veetek22)
December 26, 2022, 11:24pm
219
Thank you , that works after the first scan , where do i put it in the code so it starts at boot like that ?
veetek22
(Veetek22)
December 26, 2022, 11:30pm
220
Iâve put together a simple wall plate for this sensor - hope someone will find it useful,
DocDoo
(Jakob)
January 10, 2023, 9:24pm
222
Hi all
Iâm hoping you wonât mind giving me a sanity check on a strange experience I have with my Grow 503 reader (https://www.aliexpress.com/item/33053655412.html ). I have connect to GPIO16 and 17 for RX and TX and GPIO25 for SENSING_PIN on a ESP32 WROOM device (https://www.aliexpress.com/item/32866143601.html ). And the communication is working well, but every 500ms the sensor is sending âScan and matchâ + âGetting image 1â + âNo fingerâ. This happens regardless of if I actually touch the housing of the sensor or lay a finger on the sensor. If I lay a finger on the sensor then this is successfully detected, but the constant flow of false detections continue as you can see in the screenshot below.
Is this normal/expected behavior?
and if not have anyone seen this before and been able to rectify it?
