Yes, it is possible to install any older version.
Take a look here
Hello, I am turning to you because I have been looking for several days and I cannot find the solution.
in HA I have the IDs which are displayed but I cannot see the names which correspond to the ID, they are however registered in my yaml file
What am I doing wrong
THANKS
esphome:
friendly_name: capteur emprunte digital
esp32:
board: esp32dev
framework:
type: arduino
# Enable logging
logger:
# Enable Home Assistant API
api:
password: !secret api_password
encryption:
key: "xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx"
services:
- service: enroll
variables:
finger_id: int
num_scans: int
then:
- fingerprint_grow.enroll:
finger_id: !lambda 'return finger_id;'
num_scans: !lambda 'return num_scans;'
- fingerprint_grow.aura_led_control:
state: ALWAYS_ON
speed: 0
color: PURPLE
count: 0
- service: enroll_next # Idea by Ralf KlĂŒber (thanks!)
variables:
num_scans: int
then:
finger_id: !lambda 'return id(fingerprint_count).state;'
- service: cancel_enroll
then:
- fingerprint_grow.cancel_enroll:
- service: delete
variables:
finger_id: int
then:
- fingerprint_grow.delete:
- service: delete_all
then:
- fingerprint_grow.delete_all:
ota:
password: "xxxxxxxxxxxxxxxxxx"
wifi:
ssid: !secret wifi_ssid
power_save_mode: NONE
reboot_timeout: 5 min
ap:
ssid: "Capteur-Emprunte-Digital"
captive_portal:
uart:
rx_pin: GPIO19
tx_pin: GPIO21
baud_rate: 57600
fingerprint_grow:
# sécurisez votre systÚme !ATTENTION à ne jamais perdre le mot de passe
password: xxxxxxxxxxxxxxxxxxx # Mot de passe existant, peut ĂȘtre omis s'il s'agit de la valeur par dĂ©faut 0x00
#new_password: xxxxxxxxxxxxxxxx # Nouveau mot de passe ensuite mettre Ă jour le mot de passe existant avec le nouveau.
sensing_pin: GPIO4 #GPIO32
on_finger_scan_matched:
- homeassistant.event:
event: esphome.test_node_finger_scan_matched
confidence: !lambda 'return confidence;'
#- switch.turn_on: trigger_relay
state: BREATHING
speed: 200
color: BLUE
count: 1
- text_sensor.template.publish:
state: "doigt autorisé"
- delay: 2s
state: "Scan your finger"
# Pousser un événement tag_scanned basé sur finger_id uniquement si la confiance est supérieure à 50
# Créer une balise avec nom d'utilisateur pour chaque numéro d'identifiaction
- if:
condition:
lambda: 'return confidence > 50;'
then:
- homeassistant.tag_scanned: !lambda |-
switch (finger_id) {
case 0:
return "Seba";
case 1:
return "person_1";
case 2:
return "person_2";
case 3:
return "person_3";
default:
return "person_inconnu";
on_finger_scan_unmatched:
event: esphome.test_node_finger_scan_unmatched
state: FLASHING
speed: 25
color: RED
count: 2
state: "doigt refusé"
- delay: 2s
on_enrollment_scan:
event: esphome.test_node_enrollment_scan
scan_num: !lambda 'return scan_num;'
state: FLASHING
speed: 25
color: BLUE
count: 2
state: ALWAYS_ON
speed: 0
color: PURPLE
count: 0
state: "Finger scanné"
- delay: 2s
on_enrollment_done:
event: esphome.test_node_enrollment_done
state: BREATHING
speed: 100
color: BLUE
count: 2
state: "emprunte enrgistée"
- delay: 2s
on_enrollment_failed:
event: esphome.test_node_enrollment_failed
state: FLASHING
speed: 25
color: RED
count: 4
state: !lambda 'return "Failed to enroll into slot " + to_string(finger_id);'
- delay: 3s
state: !lambda 'return "Retrying enrollment into slot " + to_string(finger_id) + " in 3 seconds...";'
- delay: 3s
- fingerprint_grow.enroll: !lambda 'return finger_id;'
text_sensor:
- platform: wifi_info
ip_address:
name: ${entity_name} ESP IP Address
entity_category: "diagnostic"
disabled_by_default: True
icon: mdi:ip-network
mac_address:
name: ${entity_name} ESP MAC
# Intégration des entités capteur pour Lovelace
- platform: fingerprint_grow
fingerprint_count:
last_finger_id:
name: "Fingerprint Last Finger ID"
last_confidence:
name: "Fingerprint Last Confidence"
status:
capacity:
name: "Fingerprint Capacity"
security_level:
name: "Fingerprint Security Level"
- platform: uptime
name: ${entity_name} ESP Uptime
update_interval: 60s
- platform: wifi_signal
button:
- platform: restart
icon: mdi:power-cycle
name: ${entity_name} ESP Reboot
entity_category: diagnostic
Hi diagus, did you solve the problem of installing the new sensor in a button? If so, could you tell me which components you used?
Ive been eyeing one of these for a while but, was unsure about how well it worked. Now that its been a while, can you do an update on it? Any malfunctions? Any weathering? No problems at all?
No problems for me. Itâs installed under a cover, but outside. No rust or anything like that. Still works fine since the day I installed it.
Does anyone else have problems with R307 sensor? Says âfinger misplacedâ 99 times out of 100. Totally unusable.
Bought it from aliexpress so it may be cheap copy.
Never used it, but generally speaking optical sensors are inferior to capacitive ones, so I wouldnât put too much faith in the R307.
I need help, every time I scan my finger I get this:
[03:30:47][W][component:237]: Component fingerprint_grow took a long time for an operation (61 ms).
[03:30:47][W][component:238]: Components should block for at most 30 ms.
esphome:
friendly_name: Door Controller
esp32:
board: esp32-c3-devkitm-1
framework:
type: arduino
# Enable logging
logger:
baud_rate: 9600
api:
encryption:
key: "secretkeyhere"
services:
- service: enroll
variables:
finger_id: int
num_scans: int
then:
variables:
num_scans: int
then:
then:
- service: delete
variables:
finger_id: int
then:
then:
ota:
password: "secretpasswordhere"
platform: esphome
wifi:
ap:
ssid: "Door-Controller Fallback Hotspot"
password: "6VJ7TXB4f3Z6"
captive_portal:
uart:
rx_pin: GPIO21 #Blue
tx_pin: GPIO20 #Green
baud_rate: 57600
binary_sensor:
- platform: gpio
pin: GPIO4 #Light Green
- platform: gpio
pin: GPIO3 #Dark Brown
- platform: gpio
pin:
number: GPIO2 #Dark Blue
inverted: False
device_class: lock
- platform: gpio
pin:
number: GPIO1 #Pale Purple
inverted: False
filters:
- delayed_on: 50ms
device_class: door
name: "Fingerprint Enrolling"
lock:
lambda: |-
if (id(locksensor).state) {
return LOCK_STATE_UNLOCKED;
} else {
return LOCK_STATE_LOCKED;
lock_action:
then:
- if:
condition:
and:
- binary_sensor.is_off: doorsensor
then:
- switch.turn_on: lockclose
else:
state: "Door is Open"
unlock_action:
- switch.turn_on: lockopen
open_action:
on_lock:
state: "Door Locked"
on_unlock:
state: "Door Unlocked"
switch:
- platform: gpio
pin:
number: GPIO8 #Yellow
inverted: true
internal: True
on_turn_on:
- delay: 500ms
- switch.turn_off: lockclose
- platform: gpio
pin:
number: GPIO9 #Grey
inverted: true
internal: True
on_turn_on:
- delay: 500ms
- switch.turn_off: lockopen
- platform: restart
light:
- platform: esp32_rmt_led_strip
rgb_order: GRB
pin: GPIO7 #White
num_leds: 10
rmt_channel: 0
chipset: ws2812
internal: True
- platform: partition
internal: false
restore_mode: RESTORE_DEFAULT_OFF
segments:
- id: statuslights
to: 0
effects:
- strobe:
colors:
- state: true
brightness: 50%
red: 0%
green: 100%
blue: 0%
duration: 1s
- state: false
duration: 500ms
- strobe:
colors:
- state: true
brightness: 50%
red: 0%
green: 0%
blue: 100%
duration: 1s
- state: false
duration: 500ms
- strobe:
colors:
- state: true
brightness: 50%
red: 100%
green: 0%
blue: 0%
duration: 1s
- state: false
duration: 500ms
internal: false
segments:
- id: statuslights
to: 9
effects:
- strobe:
colors:
- state: true
brightness: 50%
red: 100%
green: 100%
blue: 100%
duration: 2s
transition_length: 1s
- state: false
duration: 1s
transition_length: 500ms
- addressable_color_wipe:
colors:
- red: 0%
green: 0%
blue: 0%
num_leds: 8
gradient: False
- red: 25%
green: 25%
blue: 75%
num_leds: 5
gradient: True
add_led_interval: 50ms
reverse: True
colors:
- red: 0%
green: 0%
blue: 0%
num_leds: 8
gradient: False
- red: 25%
green: 25%
blue: 75%
num_leds: 5
gradient: True
reverse: False
text_sensor:
fingerprint_grow:
uart_id: biometrics
sensing_pin: GPIO10 #Purple
password: !secret fingerprint_password
on_finger_scan_start:
state: ALWAYS_ON
color: GREEN
speed: 0
count: 0
on_finger_scan_invalid:
event: esphome.test_node_finger_scan_invalid
state: "Invalid Finger"
state: BREATHING
speed: 200
color: BLUE
count: 1
state: FLASHING
speed: 25
color: RED
count: 2
state: "Unauthorized Finger"
state: FLASHING
speed: 25
color: RED
count: 2
on_finger_scan_misplaced:
event: esphome.frontdoor_finger_scan_misplaced
state: "Misplaced finger"
state: FLASHING
speed: 25
color: PURPLE
count: 2
on_enrollment_scan:
state: !lambda 'return "Enrolling into slot " + to_string(finger_id) + ", scanned " + to_string(scan_num) + " time(s)";'
state: FLASHING
speed: 25
color: BLUE
count: 2
state: ALWAYS_ON
speed: 0
color: PURPLE
count: 0
on_enrollment_done:
state: !lambda 'return "Enrolled into slot " + to_string(finger_id);'
state: BREATHING
speed: 100
color: BLUE
count: 2
# Retry enrollment into the same slot
- delay: 3s
- delay: 3s
state: FLASHING
speed: 25
color: RED
count: 4
fingerprint_count:
fingerprint_count:
last_finger_id:
last_confidence:
name: "Last Confidence"
status:
capacity:
security_level:
Itâs just a warning, does the sensor work fine?
The sensor seems to work fine, when I test the reader I get a Misplaced finger message, and I canât enroll any fingerprints.
I disabled the sensing pin in esphome, now the reader works fine. Does the pin send an hi/low signal or does it send data?
this is a great post. thanks for all the great info and inspiration to make (trying to make) this fingerprint sensor. I keep getting this error when I compile.
[19:23:14][E][component:082]: Component fingerprint_grow is marked FAILED
still pretty new to esphome, would love some input to what I may have wrong. sorry for so much info, my yaml file is below.
========================= [SUCCESS] Took 3.56 seconds =========================
INFO Successfully compiled program.
INFO Connecting to 192.168.10.197
INFO Uploading /data/build/fingerprint/.pioenvs/fingerprint/firmware.bin (983680 bytes)
Uploading: [============================================================] 100% Done...
INFO Upload took 11.93 seconds, waiting for result...
INFO OTA successful
INFO Successfully uploaded program.
INFO Starting log output from 192.168.10.197 using esphome API
INFO Successfully connected to fingerprint @ 192.168.10.197 in 11.260s
INFO Successful handshake with fingerprint @ 192.168.10.197 in 0.081s
[19:23:13][I][app:100]: ESPHome version 2024.7.3 compiled on Aug 20 2024, 16:13:56
[19:23:13][C][wifi:599]: WiFi:
[19:23:13][C][wifi:427]: Local MAC: FC:E8:C0:7E:60:D8
[19:23:13][C][wifi:432]: SSID: [redacted]
[19:23:13][C][wifi:435]: IP Address: 192.168.10.197
[19:23:13][C][wifi:439]: BSSID: [redacted]
[19:23:13][C][wifi:440]: Hostname: 'fingerprint'
[19:23:13][C][wifi:442]: Signal strength: -57 dB ââââ
[19:23:13][C][wifi:446]: Channel: 11
[19:23:13][C][wifi:447]: Subnet: 255.255.255.0
[19:23:13][C][wifi:448]: Gateway: 192.168.10.1
[19:23:13][C][wifi:449]: DNS1: 208.67.222.222
[19:23:13][C][wifi:450]: DNS2: 208.67.220.220
[19:23:13][C][logger:185]: Logger:
[19:23:13][C][logger:186]: Level: DEBUG
[19:23:13][C][logger:188]: Log Baud Rate: 115200
[19:23:13][C][logger:189]: Hardware UART: UART0
[19:23:13][C][uart.arduino_esp32:151]: UART Bus 1:
[19:23:13][C][uart.arduino_esp32:152]: TX Pin: GPIO17
[19:23:13][C][uart.arduino_esp32:153]: RX Pin: GPIO16
[19:23:13][C][uart.arduino_esp32:155]: RX Buffer Size: 256
[19:23:13][C][uart.arduino_esp32:157]: Baud Rate: 57600 baud
[19:23:13][C][uart.arduino_esp32:158]: Data Bits: 8
[19:23:13][C][uart.arduino_esp32:159]: Parity: NONE
[19:23:13][C][uart.arduino_esp32:160]: Stop bits: 1
[19:23:13][C][template.text_sensor:020]: Template Sensor 'Mud Fingerprint State'
[19:23:13][C][uptime.sensor:033]: Uptime Sensor 'fingerprint_sensor Uptime'
[19:23:13][C][uptime.sensor:033]: Device Class: 'duration'
[19:23:13][C][uptime.sensor:033]: State Class: 'total_increasing'
[19:23:13][C][uptime.sensor:033]: Unit of Measurement: 's'
[19:23:13][C][uptime.sensor:033]: Accuracy Decimals: 0
[19:23:13][C][uptime.sensor:033]: Icon: 'mdi:timer-outline'
[19:23:13][C][uptime.sensor:034]: Type: Seconds
[19:23:13][C][template.switch:068]: Template Switch 'Fingerprint matched'
[19:23:13][C][template.switch:091]: Restore Mode: always OFF
[19:23:13][C][template.switch:057]: Optimistic: YES
[19:23:13][C][homeassistant.time:010]: Home Assistant Time:
[19:23:13][C][homeassistant.time:011]: Timezone: 'MST7MDT,M3.2.0,M11.1.0'
[19:23:13][C][version.text_sensor:021]: Version Text Sensor 'fingerprint_sensor ESPHome Version'
[19:23:13][C][version.text_sensor:021]: Icon: 'mdi:new-box'
[19:23:13][C][restart:068]: Restart Switch 'fingerprint_sensor Restart'
[19:23:13][C][restart:070]: Icon: 'mdi:restart'
[19:23:13][C][restart:091]: Restore Mode: always OFF
[19:23:13][C][fingerprint_grow:537]: GROW_FINGERPRINT_READER:
[19:23:13][C][fingerprint_grow:538]: System Identifier Code: 0x0000
[19:23:13][C][fingerprint_grow:540]: Touch Sensing Pin: GPIO5
[19:23:13][C][fingerprint_grow:542]: Sensor Power Pin: None
[19:23:13][C][fingerprint_grow:546]: Idle Period to Sleep: Never
[19:23:14][C][fingerprint_grow:548]: Update Interval: 0.5s
[19:23:14][C][fingerprint_grow:550]: Fingerprint Count 'Mud Fingerprint Count'
[19:23:14][C][fingerprint_grow:550]: State Class: ''
[19:23:14][C][fingerprint_grow:550]: Unit of Measurement: ''
[19:23:14][C][fingerprint_grow:550]: Accuracy Decimals: 0
[19:23:14][C][fingerprint_grow:550]: Icon: 'mdi:fingerprint'
[19:23:14][C][fingerprint_grow:551]: Current Value: 65535
[19:23:14][C][fingerprint_grow:554]: Status 'Mud Fingerprint Status'
[19:23:14][C][fingerprint_grow:554]: State Class: ''
[19:23:14][C][fingerprint_grow:554]: Unit of Measurement: ''
[19:23:14][C][fingerprint_grow:554]: Accuracy Decimals: 0
[19:23:14][C][fingerprint_grow:555]: Current Value: 255
[19:23:14][C][fingerprint_grow:558]: Capacity 'Mud Fingerprint Capacity'
[19:23:14][C][fingerprint_grow:558]: State Class: ''
[19:23:14][C][fingerprint_grow:558]: Unit of Measurement: ''
[19:23:14][C][fingerprint_grow:558]: Accuracy Decimals: 0
[19:23:14][C][fingerprint_grow:558]: Icon: 'mdi:database'
[19:23:14][C][fingerprint_grow:559]: Current Value: 65535
[19:23:14][C][fingerprint_grow:562]: Security Level 'Mud Fingerprint Security Level'
[19:23:14][C][fingerprint_grow:562]: State Class: ''
[19:23:14][C][fingerprint_grow:562]: Unit of Measurement: ''
[19:23:14][C][fingerprint_grow:562]: Accuracy Decimals: 0
[19:23:14][C][fingerprint_grow:562]: Icon: 'mdi:security'
[19:23:14][C][fingerprint_grow:563]: Current Value: 255
[19:23:14][C][fingerprint_grow:566]: Last Finger ID 'Mud Fingerprint Last Finger ID'
[19:23:14][C][fingerprint_grow:566]: State Class: ''
[19:23:14][C][fingerprint_grow:566]: Unit of Measurement: ''
[19:23:14][C][fingerprint_grow:566]: Accuracy Decimals: 0
[19:23:14][C][fingerprint_grow:566]: Icon: 'mdi:account'
[19:23:14][C][fingerprint_grow:567]: Current Value: 4294967295
[19:23:14][C][fingerprint_grow:570]: Last Confidence 'Mud Fingerprint Last Confidence'
[19:23:14][C][fingerprint_grow:570]: State Class: ''
[19:23:14][C][fingerprint_grow:570]: Unit of Measurement: ''
[19:23:14][C][fingerprint_grow:570]: Accuracy Decimals: 0
[19:23:14][C][fingerprint_grow:570]: Icon: 'mdi:account-check'
[19:23:14][C][fingerprint_grow:571]: Current Value: 4294967295
[19:23:14][C][captive_portal:088]: Captive Portal:
[19:23:14][C][mdns:116]: mDNS:
[19:23:14][C][mdns:117]: Hostname: fingerprint
[19:23:14][C][esphome.ota:073]: Over-The-Air updates:
[19:23:14][C][esphome.ota:074]: Address: fingerprint.local:3232
[19:23:14][C][esphome.ota:075]: Version: 2
[19:23:14][C][esphome.ota:078]: Password configured
[19:23:14][C][safe_mode:018]: Safe Mode:
[19:23:14][C][safe_mode:020]: Boot considered successful after 60 seconds
[19:23:14][C][safe_mode:021]: Invoke after 10 boot attempts
[19:23:14][C][safe_mode:023]: Remain in safe mode for 300 seconds
[19:23:14][C][api:139]: API Server:
[19:23:14][C][api:140]: Address: fingerprint.local:6053
[19:23:14][C][api:142]: Using noise encryption: YES
[19:23:14][C][wifi_info:011]: WifiInfo SSID 'fingerprint_sensor SSID'
[19:23:14][C][wifi_info:012]: WifiInfo BSSID 'fingerprint_sensor BSSID'
[19:23:14][C][wifi_info:009]: WifiInfo IPAddress 'fingerprint_sensor IP'
[19:23:14][C][wifi_signal.sensor:009]: WiFi Signal 'fingerprint_sensor WiFi Signal'
[19:23:14][C][wifi_signal.sensor:009]: Device Class: 'signal_strength'
[19:23:14][C][wifi_signal.sensor:009]: State Class: 'measurement'
[19:23:14][C][wifi_signal.sensor:009]: Unit of Measurement: 'dBm'
[19:23:14][C][wifi_signal.sensor:009]: Accuracy Decimals: 0
esphome:
friendly_name: FingerPrint
esp32:
board: esp32dev
framework:
type: arduino
# Enable logging
logger:
api:
encryption:
key: "abc"
#finger print specific
services:
- service: enroll
variables:
finger_id: int
num_scans: int
then:
variables:
num_scans: int
then:
then:
- service: delete
variables:
finger_id: int
then:
then:
ota:
- platform: esphome
password: "abc"
wifi:
ap:
ssid: "Fingerprint Fallback Hotspot"
password: "abc"
# Sync time with Home Assistant.
time:
- platform: homeassistant
captive_portal:
# Text sensors with general information.
text_sensor:
# Expose ESPHome version as sensor.
- platform: version
name: fingerprint_sensor ESPHome Version
# Expose WiFi information as sensors.
ip_address:
ssid:
bssid:
# Finger Print Specific
name: "Mud Fingerprint State"
# Exposed switches.
# Switch to restart the salt_level_sensor.
switch:
- platform: restart
optimistic: True
on_turn_on:
- delay: 2000ms
- switch.turn_off: fingerprint_matched
# Uptime sensor.
- platform: uptime
# WiFi Signal sensor.
name: fingerprint_sensor WiFi Signal
fingerprint_count:
name: "Mud Fingerprint Count"
last_finger_id:
name: "Mud Fingerprint Last Finger ID"
last_confidence:
name: "Mud Fingerprint Last Confidence"
status:
name: "Mud Fingerprint Status"
capacity:
name: "Mud Fingerprint Capacity"
security_level:
name: "Mud Fingerprint Security Level"
#specific for finger print sensor
uart:
tx_pin: GPIO17
rx_pin: GPIO16
baud_rate: 57600
fingerprint_grow:
sensing_pin: GPIO05
state: BREATHING
speed: 200
color: BLUE
count: 1
state: "Authorized finger"
- switch.turn_on: fingerprint_matched
- delay: 500ms
state: FLASHING
speed: 25
color: RED
count: 2
state: "Unauthorized finger"
- delay: 3s
on_enrollment_scan:
state: FLASHING
speed: 25
color: BLUE
count: 2
state: ALWAYS_ON
speed: 0
color: PURPLE
count: 0
state: "Finger scanned"
on_enrollment_done:
state: BREATHING
speed: 100
color: BLUE
count: 2
state: "Enrolled fingerprint"
state: FLASHING
speed: 25
color: RED
count: 4
state: "Failed to enroll fingerprint"
I do not see anything strange from the logs. Try to enable debug logs in ESPHome. And make sure there is no password on the fingerprint scanner. Also verify if you connected TX of the sensor to RX of the ESP and visa versa.
Thanks for the input. I started to examine the pins on the ESP32 I was using and realized I was using the wrong pins for tx, rx and sensing, I was using a wrong pinout document. It is all working now.
Thanks for sharing all the information on this great project. I have just received my R503 en will start testing with a ESP 32S.
I wondered if any of you used the sleep mode as described here:
[Grow Fingerprint Reader â ESPHome]
Is it wise to use this option?
First to say - awesome project with the R503 @parrel
Reading the thread top to button raised some questions.
Would it be possible to pair the R503 with an PoE powered ESP32 WROOM32 like the M5Stack U138 - mainly referring to the sense pin GPIO and the pin connected to the transistor like described in the ESP Home documentation.
This shows the bottom part of the U138 - there is an additional board connected on top with the pins to gain poe power and a breakout for for GPIO 16 and 17 for TX and RX as well as GND and 5V.
Refering to their documentation and pcb wiring the GPIO 5, which is mainly used by you all for the sensing pin, is on the U138 already used, resulting in not available for the R503 â see spec or diagram below
Would it be possible to connect the sensing pin and transistor pin to IO4 or IO32 to IO35?
The idea was to solder some extra AWG30 wires directly on the chip connectors and align them out of the housing with an extra connector or create a new housing with an embedded connector at all.
Since soldering job directly to the ESP32 die would probably be a little tricky Iâm curios if this all would theoretically work out or if I have missed something in consideration.
Any input from you would be helpful.
To be honest, I have no idea if that will work. But you could buy a esp32 devboard to see it it works, before soldering to the chip itself
For the TX and RX pins:
The ESP32 has three UARTs. ESP32 lite variant chips (ESP32-S3, ESP32-C3, ESP32-S2, etc) may have fewer UARTs (usually two). Any pair of GPIO pins can be used, as long as they support the proper output/input modes.
from UART Bus â ESPHome.
For the sensing pin, any pin thatâs a suitable input pin should work (and itâs optional to begin with).
As mentioned above, I would recommend trying it out before soldering.
Possibly dumb question, but does anyone know if itâs possible to centrally manage fingerprints/access with multiple ESP32 and sensors? Iâd love to mount these at each door, without having to walk each person around to each sensor. Can the hashed fingerprint info be synchronized somehow?
I donât think thatâs possible unfortunately. The fingerprints are stored on the sensor itself. One of the reasons that it might also not be possible, is that each sensor is different, and one sensorâs hash might not validate on another sensor. But thatâs just a thought.
Edit: on the datasheet there is functionality listed for uploading and downloading fingerprints.
