I have a garage door open/close sensor set up on two different doors using a Smarthings multipurpose sensors and a notification for when they open or close. Everything works well for the most part. I am getting an issue where when the door sometimes shakes when it hits around 200 tilt and I’ll get an open->closed->open notification back to back.
Off another post, it looks like I can add a condition to delay it triggering again for 2 seconds which would work for notifications.
- condition: template
value_template: "{{ ( as_timestamp(now()) - as_timestamp(state_attr('automation.garage_door_notification), 'last_triggered')) | int(0) ) > 2 }}"
But I’d prefer to do get the sensor to not switch on, off, on to begin with. Is there a way to get the sensor to only switch to on after the event data has been > 200 for greater than 2 seconds? This is how I have the sensor set up currently.
- trigger:
- platform: event
event_type: zha_event
event_data:
device_ieee: '28:6d:97:00:01:0c:73:35'
args:
attribute_name: "z_axis"
binary_sensor:
- name: "Garage Door 2 Status"
unique_id: garage_door_2_status
device_class: garage_door
state: >
{% if trigger.event.data.args.value > 200 %}
on
{% else %}
off
{% endif %}
