Garbage-Collection broken in 0.115
After installing 0.115 the garbage-collection integration is no longer working. The error from the log is below. Is this something I can fix myself for do I have to wait for the integration to be updated?
Setup failed for garbage_collection: Requirements for garbage_collection not found: ['typing'].
If this is a third party (not core) integration you should raise an issue with the developer.
It is a custom component. What version are you running @AwesomeGuyNamedMatt
@bruxy70 - the owner of this custom component - could help you out on this.
You may also try installing typing manually then restart HA.
lol. I found the github repo and crated an issue there. Looks like you might be the owner.
For the second tine, that version are you running?
That’s the card not the integration
