Im getting 404 on your gist. Is it public?
It is, maybe that was a bad link, try this one, I can see it without being logged in.
Hi together,
I also forked @Tweak3D Blueprint again to work with âWaste Collection Scheduleâ from @mampfes:
Use this Blueprint:
Greets
Dominik
If anyone Uses the Recollect integration in the USA, i modified this to report the proper next Pickup Type.
Hi there, i hope someone can help me. I have several automations that wonât work and i tried to troubleshoot them. I think it is because of something wrong with the timing.
for example, i have two different blueprints imported to send me a notification when my garbage is picked-up. This are westenberg/garbage-reminder.yaml and idominiki/GarbageCollection.yaml.
Both will check the garbage entities and if there is 1 day before pick up they must sent a notification through telegram. If i do a test it works, but when the blueprints must send a message on a certain time i get Stopped because a condition failed.
I think it has something to do with an invalid strftime date format.
I one of the automations i can set the correct strftime, which is by default %Y-%m-%d, in the configuration yaml of the garbage addon it is also set to %Y-%m-%d.
But when i check the entities, i see several different time/date fields.
I get in the yaml status attributes: Sort_date: 20221101
In the status date: Tomorrow, 2022-10-21
And if i check the attributes of an entity in lovelace i get also Sort date: 20.221.021 (this one is strange, but can be default behavior).
Maybe someone else has have the same problem in the past en seems to solve it?
Hi there, i hope you can help mei canât get your blueprint to work. If it run on the set time in the trace i see: Stopped because a condition failed at
Do you have any idea?
I had the similar issue. In my case I have garbage collection addon configured in a way that sensors for garbage types are not holding textual state with date but only integer value:
- 2 - if next collection is in two days or more
- 1 - if next collection is one day ahead
- 0 - if collection is today.
What worked for me was to change blueprint code to fetch ânext_dateâ attribute while building sensors_tomorrow array that is then checked by trigger condition.
Here is the modified blueprint code:
blueprint:
name: Updated garbage reminder
domain: automation
input:
reminder_time:
description: At what time the day before do you want to be reminded
default: '18:00:00'
selector:
time: {}
day_offset:
description: Amount of days to be added to the triggers date to check for sensor
value matches. E.g. 1 to be notified the day before or 0 for notification
on the garbage collection day.
default: 1
date_format:
description: Valid strftime date format. Default %Y-%m-%d
default: '%Y-%m-%d'
reminder_title:
description: Shown as title in the notification
default: Garbage reminder
reminder_message:
description: Accompanying text in the notification
default: 'The following garbage will be picked up tomorrow: '
notifier:
description: Name of integration you prefer to use for notifications. E.g. notify.notify
default: notify.notify
garbage_sensor_1:
name: Garbage sensor 1
description: Sensor should be a date string formatted according to the date format input
default: ''
selector:
entity:
domain: sensor
garbage_sensor_2:
name: Garbage sensor 2
default: ''
selector:
entity:
domain: sensor
garbage_sensor_3:
name: Garbage sensor 3
default: ''
selector:
entity:
domain: sensor
garbage_sensor_4:
name: Garbage sensor 4
default: ''
selector:
entity:
domain: sensor
variables:
garbage_sensor_1: !input 'garbage_sensor_1'
garbage_sensor_2: !input 'garbage_sensor_2'
garbage_sensor_3: !input 'garbage_sensor_3'
garbage_sensor_4: !input 'garbage_sensor_4'
reminder_title: !input 'reminder_title'
reminder_message: !input 'reminder_message'
day_offset: !input 'day_offset'
date_format: !input 'date_format'
sensors_tomorrow: '{{ [(state_attr(garbage_sensor_1, ''friendly_name''), state_attr(garbage_sensor_1, ''next_date'').strftime(date_format)), (state_attr(garbage_sensor_2, ''friendly_name''), state_attr(garbage_sensor_2, ''next_date'').strftime(date_format)), (state_attr(garbage_sensor_3, ''friendly_name''), state_attr(garbage_sensor_3, ''next_date'').strftime(date_format)), (state_attr(garbage_sensor_4, ''friendly_name''), state_attr(garbage_sensor_4, ''next_date'').strftime(date_format))] | selectattr(''1'', ''eq'', (now() + timedelta(days = day_offset | int)).strftime(date_format)) | join('', '', attribute=0) }}'
platform: time
at: !input 'reminder_time'
condition:
condition: template
value_template: "{{ sensors_tomorrow != '' }}"
service: !input 'notifier'
title: '{{ reminder_title }}'
message: '{{ reminder_message }}{{ ''\n'' }}{{ sensors_tomorrow }}'
I hope this helps anybody who encountered similar issue
Rgds,
J.
I used all of the blueprints here but none of it is working. My setup is a google calendar with the entries for each garbage collection. With the HACS waste collection schedule I transfer these entries in 3 different sensor values - so 3 different types of waste. Based on this I wanted to get a notification each evening before at 6pm to have a reminder. Probably there is a more efficient way with the direct Google Calendar integration. Do you have an advice how to establish the reminder in the most efficient way?
I get this error for my reminders as I am using my google calendrer for my trash days reminder?
variables:
garbage_sensor_1: calendar.garbage_day
garbage_sensor_2: ''
garbage_sensor_3: ''
garbage_sensor_4: ''
reminder_title: Garbage reminder, Take out the Trash
reminder_message: 'The following garbage will be picked up tomorrow: '
day_offset: 1
date_format: '%Y-%m-%d'
sensors_tomorrow: >-
{{ [(state_attr(garbage_sensor_1, 'friendly_name'),
states(garbage_sensor_1)), (state_attr(garbage_sensor_2, 'friendly_name'),
states(garbage_sensor_2)), (state_attr(garbage_sensor_3, 'friendly_name'),
states(garbage_sensor_3)), (state_attr(garbage_sensor_4, 'friendly_name'),
states(garbage_sensor_4))] | selectattr('1', 'eq', (now() + timedelta(days =
day_offset | int)).strftime(date_format)) | join(', ', attribute=0) }}
platform: time
at: '21:00:00'
condition:
condition: template
value_template: '{{ sensors_tomorrow != '''' }}'
service: notify.mobile_app_homeking
message: '{{ reminder_message }}{{ sensors_tomorrow }}'
alias: Garbage reminder
description: ''
description: ""
use_blueprint:
path: westenberg/garbage-reminder.yaml
input:
notifier: notify.mobile_app_homeking
reminder_time: "21:00:00"
Hi all, I canât seem to get these blueprints working. Can someone help me find out what is going wrong? or is it an issue with newer Home Assistant?
If I try to type in the sensors_today variables, i canât get it to display anything.
and in the blueprint of tweak3d trying to test that line i get attribute undefined.
So trying to build the sensors_today proves very challenging for me. Maybe I donât understand the query language good enough.
All this functionality was replaced with the calendar integration years ago, so I doubt that this 3yo BP has been kept up.
I would look at something like this or do search for other similar in the forum:
Garbage Collection - recommendations for replacement of Bruxy integration - #11 by bschatzow.
I think I am getting to understand why it isnât working for me anymore.
The state of my sensors should be a date, but they arenât the same for all sensors, and they arenât what is expected in the blueprint.
The dateformat when further in the future as 7 days is â09-08-2024â this follows the %d-%m-%Y
But less then a week ahead it is like this: âThursday, 01-08-2024â
So i guess this might be part of my problem, resulting in an empty array for the âSensors_tomorrowâ.
Iâll have to see if the âafvalbeheerâ HACS component has a setting for this to make it allways the same data format.
I do like the cards for a dashboard, so thatâs why i am trying it this way and donât go for completely changing it to the calendar in HA. Havenât seen a good way of importing it there, but also havenât searched very intensive either.
Thanks for this! The notification I was getting looked like
The following garbage will be picked up tomorrow: ['garbage', 'recycling']
I had to modify sensors_tomorrow so it would properly join the list by replacing
with
| first | first | join(', ')
I am having the same issue with Afvalbeheer, for some reason the blueprint is never triggered. Does someone have a solution?
