Garden runners
my gift for all those who in this sad period, to keep a little fit, are forced to run around their garden. The system will allow you to listen to information from your phone on the number of laps completed, the time taken, and also some extra comments on your performance ; -) …
Required … for the software part: Home Assistant and the Lannouncer application. For hardware, a smartphone and a Pir sensor, preferably mobile ones that work with Sonoff rf bridge.
Here are the codes …
configuration.yaml:
timer:
  stopwatch:
    duration:
      seconds: 540
input_number:
  averageminutes:
    initial: 0
    max: 9
    min: 0
    step: 1
  averageseconds:
    initial: 0
    max: 59
    min: 0
    step: 1
  delay:
    initial: 5
    max: 59
    min: 5
    step: 1
input_text:
  averagelap:
    initial: '0'
  timelap:
    initial: '00:00'
counter:
  revcounter:
    initial: 0
    step: 1
    maximum: 500
    restore: true
    icon: mdi:walk
input_boolean:
  revcounter:
    initial: off
  motivator:
    initial: off
  averagelap:
    initial: off
notify:
  - platform: lannouncer #(you need to download the app to your smartphone)
    host: 192.168.0.xxx  #(you have to set the static ip for your smartphone)
    port: 1035
# This works with a Sonoff Pir sensor and a SONOFF 433 RF Bridge)
binary_sensor:
  - platform: mqtt
    state_topic: "tele/sonoff-bridge/RESULT"
    value_template: '{{value_json.RfReceived.Data}}'
    payload_on: 'xxxxxx'    # (SONOFF RF BRIDGE codes)
    payload_off: 'xxxxxx'
    off_delay: 10
    device_class: motion
    qos: 0
AUTOMATION
- id: 'revcounteron'
  alias: revcounteron
  - entity_id: input_boolean.revcounter
    platform: state
    to: 'on'
  - data:
      entity_id: timer.stopwatch
    service: timer.cancel
  - service: counter.reset
    entity_id: counter.revcounter
  - data:
    service: timer.start
  - data:
      entity_id:
      - automation.stopwatch
    service: automation.turn_on
  initial_state: 'on'
- id: 'revcounteroff'
  alias: revcounteroff
    platform: state
    to: 'off'
  - data:
      entity_id:
    service: automation.turn_off
  - data:
  - service: input_text.set_value
      entity_id: input_text.averagelap
      value: '0'
      entity_id: input_text.timelap
      value: '00:00'
  initial_state: 'on'
- id: 'stopwatch'
  alias: stopwatch
  - entity_id: binary_sensor.sensor_pir
    platform: state
    to: 'on'
  - data:
    service: timer.pause
  - service: counter.increment
    data_template:
      value: >
        {% if is_state('counter.revcounter', '2') and is_state('input_boolean.averagelap', 'on') %}
        {% set min = state_attr('timer.stopwatch', 'remaining')|replace('0:0', '') %}
        {% set sec = 59 - min[2:]|int %}
        {% set min2 = min|truncate(1,false,'',0) %}
        {% set min3 = 8 |float - min2| round(0) %}
        {% set min4 = min3| round(0) %}
        {% set minsec = min4 * 60 %}
        {% set sectot = minsec + sec %}
        {{ sectot }}
        {% else %}
        {{ states(input.text.averagelap) }}
        {% endif %}
    data_template:
      value: >
        {% if sec < 10 %}
        {% set sec ="0" + sec|string %}
        {% endif %}
        {% set min5 ="0" +  min4|string + ":" + sec|string %}
        {{min5}}
  - service: notify.lannouncertts
    data_template:
      message: >
        {% set media = states('input_number.averageminutes') | float * 60 | float + states('input_number.averageseconds') | int  %}
        {% set marg = states('input_number.delay')| int %}
        {% if min4 == 0 %}
        {% set min4 = '' + sec|string + " seconds"%}
        {% elif min4 == 1 %}
        {% set min4 = min4|string + ' minute and ' + sec|string + " seconds" %}
        {% else %}
        {% set min4 = min4|string + ' minutes and ' + sec|string + " seconds" %}
        {% endif %}
        {% if states('counter.revcounter') | float > 2 %}
        lap {{ states('counter.revcounter') }}... Time {{min4}} .
        {% endif %}
        {% if is_state('input_boolean.motivator', 'on') %}
        {% if is_state('counter.revcounter', '1') and is_state('input_boolean.averagelap', 'on') %}
        now go at a regular pace that I take your time
        {% endif %}
        your reference time {{min4}}
        {% endif %}
        {% if is_state('input_text.averagelap', '0') %}
        {% else %}
        {% set media = states('input_text.averagelap')| int %}
        {% endif %}
        {% if sectot < media| float -marg %}
        {{["great, you are doing well", "today nobody beats you", "great time" ] | random}}
        {% elif sectot > media| float +marg %}
        {{["Can you do any better", "you look like a snail", "you are slowing down a bit" ] | random}}
        {% else %}
        {{["regular pace", "you are average" ] | random}}
        {% endif %}
        {% endif %}
        {% endif %}
  - data:
  - data:
  initial_state: 'off'
LOVELACE CARDs
PICTURE ELEMENTS:
elements:
  - entity: input_boolean.revcounter
    image: /local/images/runner.gif
    state_image:
      'off': /local/images/revcounteroff.png
    style:
      left: 50%
      top: 40%
      width: 30%
    tap_action:
      action: toggle
    type: image
    image: /local/images/null.png
    state_image:
      'on': /local/images/stopwatch.gif
    style:
      left: 15%
      top: 25%
      width: 15%
    tap_action:
      action: none
    type: image
  - entity: counter.revcounter
    style:
      font-size: 22px
      left: 80%
      top: 25%
    tap_action:
      action: null
    type: state-badge
  - entity: input_text.timelap
    style:
      font-size: 16px
      left: 80%
      top: 35%
    type: state-label
  - entity: input_boolean.averagelap
    image: /local/images/averagelapon.png
    state_image:
      'off': /local/images/averagelapoff.png
    style:
      left: 16%
      top: 70%
      width: 20%
    tap_action:
      action: toggle
    type: image
  - entity: input_boolean.motivator
    image: /local/images/ttson.png
    state_image:
      'off': /local/images/ttsoff.png
    style:
      left: 80%
      top: 70%
      width: 20%
    tap_action:
      action: toggle
    type: image
image: /local/images/race.jpg
type: picture-elements
CONDITIONAL CARD
card:
  entities:
    - entity: input_number.delay
  type: entities
conditions:
    state: 'on'
type: conditional
card:
  entities:
    - entity: input_number.averageminutes
    - entity: input_number.averageseconds
  type: entities
conditions:
    state: 'off'
    state: 'on'
type: conditional
averagelapoff averagelapon null revcounteroff runner stopwatch ttsoff ttson
