I am trying to set up Gardena Bluetooth integration. As soon as I select it from the integrations list, I get an empty dialog window titled “Gardena Bluetoot” with a “close” button at the bottom. No other options are available, and I do not see anything in the system log.
Did anyone experience similar issue? How can I proceed from here?
Kind regards,
Vilius
Hey,
You found a bug, made a fix for it here (Add missing translation key to Gardena Bluetooth by joostlek · Pull Request #97855 · home-assistant/core · GitHub). Basically this means that there was no device found to setup.
What device are you trying to integrate?
