Dear Home Assistant users.
I have a Gardena Sileno City robotic mower. This one works only on Bluetooth.
Can I then use Bluetooth - proxy to give commands to my robotic mower from another country (while travelling)? In other words, can I then use the app on my Android Phone to control my robotic mower?
I am under the impression that you can only control on or off switches, relays. Or should I buy a smart city robotic mower that has wifi? This is because I want to remotely (not at home) change my settings on the robotic mower.
As far as I can tell there is no Home Assistant integration available that allows to operate the bluetooth Gardena mower. If there was, and Home Assistant is opened to the internet (for instance through Nabu Casa subscription or by other means) then it would have been possible to operate it from anywhere in the world. But unless someone knows of the right integration for Home Assistant, you are out of luck with only bluetooth.
No you can’t. You need to have a Gardena Smart gateway with a compatible robot.
Make sure to have proper titles in your threads, this makes it easier for others to help you.
It’s done. Thanks.
