Garmin Connect producing errors and not syncing in 2021.5.2
Another issue after updating from 2021.4.5 - Garmin Connect integration is not syncing data and logging the following error:
2021-05-11 21:11:01 ERROR (MainThread) [homeassistant.components.garmin_connect] Unknown error occurred during Garmin Connect get activity request
  File "/usr/local/lib/python3.8/site-packages/urllib3/connection.py", line 169, in _new_conn
    conn = connection.create_connection(
  File "/usr/local/lib/python3.8/site-packages/urllib3/util/connection.py", line 73, in create_connection
    for res in socket.getaddrinfo(host, port, family, socket.SOCK_STREAM):
  File "/usr/local/lib/python3.8/socket.py", line 918, in getaddrinfo
    for res in _socket.getaddrinfo(host, port, family, type, proto, flags):
socket.gaierror: [Errno -3] Try again
  File "/usr/local/lib/python3.8/site-packages/urllib3/connectionpool.py", line 699, in urlopen
    httplib_response = self._make_request(
  File "/usr/local/lib/python3.8/site-packages/urllib3/connectionpool.py", line 382, in _make_request
    self._validate_conn(conn)
  File "/usr/local/lib/python3.8/site-packages/urllib3/connectionpool.py", line 1010, in _validate_conn
    conn.connect()
  File "/usr/local/lib/python3.8/site-packages/urllib3/connection.py", line 353, in connect
    conn = self._new_conn()
  File "/usr/local/lib/python3.8/site-packages/urllib3/connection.py", line 181, in _new_conn
    raise NewConnectionError(
urllib3.exceptions.NewConnectionError: <urllib3.connection.HTTPSConnection object at 0x7fa8d78028e0>: Failed to establish a new connection: [Errno -3] Try again
  File "/usr/local/lib/python3.8/site-packages/requests/adapters.py", line 439, in send
    resp = conn.urlopen(
  File "/usr/local/lib/python3.8/site-packages/urllib3/connectionpool.py", line 755, in urlopen
    retries = retries.increment(
  File "/usr/local/lib/python3.8/site-packages/urllib3/util/retry.py", line 574, in increment
    raise MaxRetryError(_pool, url, error or ResponseError(cause))
urllib3.exceptions.MaxRetryError: HTTPSConnectionPool(host='connect.garmin.com', port=443): Max retries exceeded with url: /proxy/usersummary-service/usersummary/daily/msandstr?calendarDate=2021-05-11 (Caused by NewConnectionError('<urllib3.connection.HTTPSConnection object at 0x7fa8d78028e0>: Failed to establish a new connection: [Errno -3] Try again'))
  File "/usr/src/homeassistant/homeassistant/components/garmin_connect/__init__.py", line 93, in async_update
    self.data = await self.hass.async_add_executor_job(
  File "/usr/local/lib/python3.8/concurrent/futures/thread.py", line 57, in run
  File "/usr/local/lib/python3.8/site-packages/garminconnect/__init__.py", line 197, in get_stats_and_body
    return ({**self.get_stats(cdate), **self.get_body_composition(cdate)['totalAverage']})
  File "/usr/local/lib/python3.8/site-packages/garminconnect/__init__.py", line 207, in get_stats
    response = self.req.get(summaryurl, headers=self.headers)
  File "/usr/local/lib/python3.8/site-packages/requests/sessions.py", line 555, in get
    return self.request('GET', url, **kwargs)
  File "/usr/local/lib/python3.8/site-packages/requests/sessions.py", line 542, in request
    resp = self.send(prep, **send_kwargs)
  File "/usr/local/lib/python3.8/site-packages/requests/sessions.py", line 655, in send
    r = adapter.send(request, **kwargs)
  File "/usr/local/lib/python3.8/site-packages/requests/adapters.py", line 516, in send
    raise ConnectionError(e, request=request)
requests.exceptions.ConnectionError: HTTPSConnectionPool(host='connect.garmin.com', port=443): Max retries exceeded with url: /proxy/usersummary-service/usersummary/daily/msandstr?calendarDate=2021-05-11 (Caused by NewConnectionError('<urllib3.connection.HTTPSConnection object at 0x7fa8d78028e0>: Failed to establish a new connection: [Errno -3] Try again'))
I am also having issues in connecting.
The integration will not currently accept valid user credentials to connect anymore for me.
Same here, updated to 2021.5.5 today but still not working =(
Worked great prior.
Same problem here. Removed integration and re-added but does not work. Alway fails authentication when doing the initial integration setup.
Working again in 2021.6.1 but not working in 2021.6.2
Errr… I removed the integration because I was trying to reset it and now I cannot add it back…
In 2021.6.3 it is working for me.
