I’ve been working on a simple integration to pull information from one or more Garmin MapShare profiles, and I think it’s finally feature-complete enough to share with the world.
You can check out the full description over at the GitHub repository, or keep reading below for a README excerpt.
Screenshots
Description
Given a user’s MapShare link name and (if required) password, this custom component will periodically pull data from their KML feed and create a handful of entities in Home Assistant based on the state reported from an inReach satellite communicator.
Please note: This does not use the username and password that the Garmin owner uses to log in. Instead, it uses the data from the user’s MapShare profile on https://share.garmin.com/ assuming the owner has turned the MapShare feature “on” and shared the link with you.
This allows you, as a friend or family member of one or more inReach owners, to track their status centrally without having to use the MapShare web interface (or to create automations based on Zones, for example).
Installation
Add this repository using HACS:
https://github.com/BHSPitMonkey/homeassistant-garmin-mapshare
After a successful installation and restart, you should now be able to add Garmin MapShare from the Integrations page in Home Assistant (one or more times).
Current Limitations
- MapShare profiles containing multiple inReach devices are not yet correctly supported (though this shouldn’t be too hard to fix).
- Some public MapShare profiles do not work at all with this integration because the server provides an empty KML feed; I’m not sure why.
