Garmin Watch and Actionable Notifications
As the title suggests… I’ve just switched from an Apple Watch to a Garmin epix. I was under the impression that actionable notifications work on the Garmin range. But at the moment all I’m getting is the text of the message, no options to then trigger an event.
Anyone else here with a Garmin?
not any experience with actionable notifications.
But well some good experience with controlling light and switches with the Garmin: GitHub - hatl/hasscontrol: Simple garmin widget to control home assistant scenes
and also reading the sensors from the Garmin in to HA: GitHub - cyberjunky/home-assistant-garmin_connect: The Garmin Connect integration allows you to expose data from Garmin Connect to Home Assistant.
Both works just fine :wink:
I have both Android and iPhone. it works on android with garmin , but not on iPhone and Garmin… it’s a bummer
Did you get further on this one by chance? Same situation although I get no text at all for actionable notifications just standard ones.
